4582|4
83
香呼叫主,求救信号,有关pwm输入捕获的问题! [复制链接]
我的配置如下,但是我用信号发生器产生信号输入,根本就不进中断,但是我要是直接用导线给输入引脚引入高电平(相当于一个脉冲信号),就可以进中断,下面是我的程序,实在不明白原因!int void  void ICapture_Configuration(void)
      TIM_ICInitTypeDef  TIM_ICInitStructure;
        GPIO_InitTypeDef GPIO_InitStructure;
        // TIM3 clock enable
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);  //使能时钟TIM3,AFIO和引脚已经使能过了
        GPIO_PinRemapConfig(GPIO_FullRemap_TIM3, ENABLE);        //重映射
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;                        //TIM3 CH1  重映射功能
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_Init(GPIOC, &GPIO_InitStructure);
  TIM_ICInitStructure.TIM_Channel = TIM_Channel_1;
  TIM_ICInitStructure.TIM_ICPolarity = TIM_ICPolarity_Rising;
  TIM_ICInitStructure.TIM_ICSelection = TIM_ICSelection_DirectTI;
  TIM_ICInitStructure.TIM_ICPrescaler = TIM_ICPSC_DIV1;
  TIM_ICInitStructure.TIM_ICFilter = 0x0;
  TIM_PWMIConfig(TIM3, &TIM_ICInitStructure);
  /* Select the TIM3 Input Trigger: TI2FP2 */
  TIM_SelectInputTrigger(TIM3, TIM_TS_TI1FP1);
  /* Select the slave Mode: Reset Mode */
  TIM_SelectSlaveMode(TIM3, TIM_SlaveMode_Reset);
  /* Enable the Master/Slave Mode */
  TIM_SelectMasterSlaveMode(TIM3, TIM_MasterSlaveMode_Enable);
  /* TIM enable counter */
  TIM_Cmd(TIM3, ENABLE);
  /* Enable the CC2 Interrupt Request */
  TIM_ITConfig(TIM3, TIM_IT_CC2, ENABLE);
中断函数:
void TIM3_IRQHandler(void)
  /* Clear TIM3 Capture compare interrupt pending bit */
  TIM_ClearITPendingBit(TIM3, TIM_IT_CC2);
  /* Get the Input Capture value */
  IC2Value = TIM_GetCapture2(TIM3);
  if (IC2Value != 0)
    /* Duty cycle computation */
    DutyCycle = (TIM_GetCapture1(TIM3) * 100) / IC2Value;
    /* Frequency computation */
    Frequency = SystemCoreClock / IC2Value;
  else
    DutyCycle = 0;
    Frequency = 0;
并且弱弱的问一句TIM_TS_TI1FP1这个出发源是选择捕获通道1的时候就选择这个触发源吗?
此帖出自stm32/stm8论坛
PWM输入模式,TIM3如何工作滴,请大侠指教!  详情 回复 发表于 2012-5-19 10:36
91
                                 唉,版主睡着了,可能是最近比较累,自己先顶一个
此帖出自stm32/stm8论坛
哦  解决了!上面的程序是对的,留给大家参考把,但是这句IC2Value = TIM_GetCapture2(TIM3);
和DutyCycle = (TIM_GetCapture1(TIM3) * 100) / IC2Value;
写反了,不能误导大家,最低检测频率是1098Hz,以后会长发帖的!
此帖出自stm32/stm8论坛
此帖出自stm32/stm8论坛
此帖出自stm32/stm8论坛
有奖直播:当AI遇见仿真,会有什么样的电子行业革新之路?
首场直播:Simcenter AI 赋能电子行业研发创新
直播时间:04月15日14:00-14:50
