7487|16
79
有没有兄弟做过ST32读LM75的程序吗?QQ438948011 [复制链接]
                                 我做个好几天,第一遍能读第二遍就死在检测等待死了
此帖出自stm32/stm8论坛
                                 我也碰到了这个问题 多次运行就不行了 开始几次 还行 也是死在   while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_MODE_SELECT))  /* EV5 */   {   } 一直检测不到 不知道咋回事儿 这硬件。。。。  详情 回复 发表于 2010-8-11 15:14
63
                                 用的是EK-ST32F开发板,用的是读2408示例程序
此帖出自stm32/stm8论坛
此帖出自stm32/stm8论坛
51
                                 楼主不能仿真看程序死在哪了吗
此帖出自stm32/stm8论坛
                                 看你还挺高兴的啊
此帖出自stm32/stm8论坛
                                 检测等待?哪个检测等待,能不能说具体点呢,或者把程序拿出来看看
此帖出自stm32/stm8论坛
83
u32 I2C_EE_BufferRead(u8* pBuffer, u8 ReadAddr, u16 NumByteToRead)
  /* Send START condition */
  I2C_GenerateSTART(I2C1, ENABLE);
  /* Test on EV5 and clear it */
此帖出自stm32/stm8论坛
void I2C_EE_BufferRead(u8* pBuffer, u8 ReadAddr, u16 NumByteToRead)
  while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_MODE_SELECT));
  /* In the case of a single data transfer disable ACK before reading the data */
  if(NumByteToRead==1)
    I2C_AcknowledgeConfig(I2C1, DISABLE);
  /* Send EEPROM address for write */
  I2C_Send7bitAddress(I2C1, EEPROM_ADDRESS, I2C_Direction_Transmitter);
  /* Test on EV6 and clear it */
  while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED));
  /* Clear EV6 by setting again the PE bit */
  I2C_Cmd(I2C1, ENABLE);
  /* Send the EEPROM's internal address to write to */
  I2C_SendData(I2C1, ReadAddr);
  /* Test on EV8 and clear it */
  while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_TRANSMITTED));
  /* Send STRAT condition a second time */
  /* Send EEPROM address for read */
  I2C_Send7bitAddress(I2C1, EEPROM_ADDRESS, I2C_Direction_Receiver);
  while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED));
  /* While there is data to be read */
  while(NumByteToRead)
    /* Test on EV7 and clear it */
    if(I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_RECEIVED))
      if(NumByteToRead == 2)
        /* Disable Acknowledgement */
      if(NumByteToRead == 1)
        /* Send STOP Condition */
        I2C_GenerateSTOP(I2C1, ENABLE);
      /* Read a byte from the EEPROM */
      *pBuffer = I2C_ReceiveData(I2C1);
      /* Point to the next location where the byte read will be saved */
      pBuffer++;
      /* Decrement the read bytes counter */
      NumByteToRead--;
  /* Enable Acknowledgement to be ready for another reception */
  I2C_AcknowledgeConfig(I2C1, ENABLE);
此帖出自stm32/stm8论坛
78
就这
此帖出自stm32/stm8论坛
63
后来改成这样了,但是还是只能读一次。LM75用GPIO模拟没有问题。
* Function Name  : I2C_EE_BufferRead
* Description    : Reads a block of data from the EEPROM.
* Input          : - pBuffer : pointer to the buffer that receives the data read
*                    from the EEPROM.
*                  - ReadAddr : EEPROM's internal address to read from.
*                  - NumByteToRead : number of bytes to read from the EEPROM.
* Output         : None
* Return         : None
          {TestI2C++;
          if(TestI2C==0xFF)
             return 1;
  TestI2C=0;
          {TestI2C++;if(TestI2C==0xFF)
        {return 2;}}
        TestI2C=0;
          {TestI2C++;if(TestI2C==0xFF){return 3;}}
         TestI2C=0;
          {TestI2C++;if(TestI2C==0xFF){return 4;}}
        TestI2C=0;
          {TestI2C++;if(TestI2C==0xFF){return 5;}}
        TestI2C=0;
       while(!I2C_CheckEvent(I2C1, I2C_EVENT_MASTER_BYTE_RECEIVED))
       {TestI2C++;if(TestI2C==0xFF){return 6;}}
        TestI2C=0;
      pBuffer++;
      NumByteToRead--;
  return 0;
此帖出自stm32/stm8论坛
55
                                 自己用IO口模拟的可以了。
此帖出自stm32/stm8论坛
63
                                 看来大公司的战略目的比信誉更重要。
此帖出自stm32/stm8论坛
                                 很明显,楼主的程序只能跑一次
此帖出自stm32/stm8论坛
79
                                 老问题了
此帖出自stm32/stm8论坛
83
                                 在调用I2C_EE_BufferRead,之前已经TestI2C=0;
此帖出自stm32/stm8论坛
89
我有些代码,可以读LM75,仅供参考(不保证能行):
#define LM75_Addr      0x90                // 7-bit address of LM75: left align to MSbit
#define LM75_Temp_Reg       0x00        // Temperature Register of LM75
#define LM75_Conf_Reg       0x01        // Configuration Register of LM75
#define LM75_Thyst_Reg      0x02        // Temperature Register of LM75
#define LM75_Tos_Reg        0x03        // Over-temp Shutdown threshold Register of LM75
#define Start_Bit        0x01
#define Address_Sent        0x02
#define BTF_Bit                0x04
#define Rx_Not_Empty                0x40
#define Ack_Failure                0x0400
#define Time_Out                0x4000
//   I2C_LM75(I2C1 of 1~2) initialization
void I2C_LM75_Init(void)
  I2C_InitTypeDef  I2C_InitStructure;
  GPIO_InitTypeDef GPIO_InitStructure;
  // Enable I2C1 and GPIOB & AFEN(Alternate Function) clocks
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1, ENABLE);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB | RCC_APB2Periph_AFIO, ENABLE);
  // Reset I2C1 IP
  RCC_APB1PeriphResetCmd(RCC_APB1Periph_I2C1, ENABLE);
  // Release reset signal of I2C1 IP
  RCC_APB1PeriphResetCmd(RCC_APB1Periph_I2C1, DISABLE);
  // Set PB6,7 as OD AF - I2C1_SCL, I2C1_SDA
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;        // standard: 100k, fast: 400k
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
  // Set PB5 as PU in - TemperatureSensor_INT
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
  // I2C1 configuration
  I2C_InitStructure.I2C_Mode = I2C_Mode_I2C;
  I2C_InitStructure.I2C_ClockSpeed = 50000;                // 50k baud
  I2C_InitStructure.I2C_DutyCycle = I2C_DutyCycle_2;
  I2C_InitStructure.I2C_OwnAddress1 = 0x00;                // 7-bit own-address: right align to LSbit
  I2C_InitStructure.I2C_Ack = I2C_Ack_Disable;
  I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
  I2C_Init(I2C1, &I2C_InitStructure);
  // Enable I2C1
//   Read Tos register of LM75
u16 I2C_LM75_Tos_Read(void)
  u16 u;
  u = 0xffff;                                        // init an invalid value
  // Generate START condition
  while( !(I2C_ReadRegister(I2C1, I2C_Register_SR1) & Start_Bit) )
  // Send 7bit Address
  I2C_Send7bitAddress(I2C1, LM75_Addr, I2C_Direction_Transmitter);
  while( !(I2C_ReadRegister(I2C1, I2C_Register_SR1) & Address_Sent) )
    if( I2C_ReadRegister(I2C1, I2C_Register_SR1) & Ack_Failure )
      return u;
  // Read SR2 to clear ADDR bit in SR1
  I2C_ReadRegister(I2C1, I2C_Register_SR2);
  // Send data: pointer (Tos_Reg)
  I2C_SendData(I2C1, LM75_Tos_Reg);
  while( !(I2C_ReadRegister(I2C1, I2C_Register_SR1) & BTF_Bit) )
    if( I2C_ReadRegister(I2C1, I2C_Register_SR1) & (Time_Out | Ack_Failure) )
      return u;
  // Generate STOP condition
  I2C_Send7bitAddress(I2C1, LM75_Addr, I2C_Direction_Receiver);
      return u;
  // Receive data: high byte (Tos_Reg) and ACK
  while( !(I2C_ReadRegister(I2C1, I2C_Register_SR1) & Rx_Not_Empty) )
  u = I2C_ReceiveData(I2C1) << 8;
  // Receive data: low byte (Tos_Reg) and NAK
  u |= I2C_ReceiveData(I2C1);
  // return correct result
  return u;
//   Read Temperature register of LM75
u16 I2C_LM75_Temp_Read(void)
  u16 u;
  // Send data: pointer (Temp_Reg)
  I2C_SendData(I2C1, LM75_Temp_Reg);
  // Receive data: high byte (Temp_Reg) and ACK
  // Receive data: low byte (Temp_Reg) and NAK
  // return correct result - Temp_Reg low 5 bits have no meaning
  return (u>>5);
此帖出自stm32/stm8论坛
79
也是死在
此帖出自stm32/stm8论坛
