5157|5
99
STM8S103k3I2C问题 [复制链接]
STM8S103k3 I2C在STVD+cosmic下编译成功,
Debug时使用simulator程序正常,用ST—LINK链接到MCU时,
停在while(!I2C_CheckEvent(I2C_EVENT_MASTER_START_SENT))处;
刚接触ST芯片,很多东西都不了解。不知是何故,望高人指点!
uCHAR I2CWriteByte(uCHAR cDevAddr, uCHAR cReg,uCHAR cData)
  //I2cInit();
  I2C_GenerateSTART(ENABLE);
  /*EV5*/
  while(!I2C_CheckEvent(I2C_EVENT_MASTER_START_SENT));
  I2C_Send7bitAddress(cDevAddr,I2C_DIRECTION_TX );
     /* Test on EV6 and clear it */
   while(!I2C_CheckEvent(I2C_EVENT_MASTER_ADDRESS_ACKED));
   I2C_ClearFlag(I2C_FLAG_ADDRESSSENTMATCHED);
  I2C_SendData(cReg);
  while(!I2C_CheckEvent(I2C_EVENT_MASTER_BYTE_TRANSMITTED));
  I2C_SendData(cData);
  I2C_GenerateSTOP(ENABLE);
此帖出自stm32/stm8论坛
                                 版主怀疑是你的硬件连接问题,LZ还是把电路图贴出来看看吧  详情 回复 发表于 2010-6-10 10:21
56
STM8S103k3 I2C问题
  //I2cInit();
  /*EV5*/
  I2C_SendData(cReg);
此帖出自stm32/stm8论坛
81
STM8S103k3 I2C问题
  //I2cInit();
  /*EV5*/
  I2C_SendData(cReg);
此帖出自stm32/stm8论坛
                                 电路图?
此帖出自stm32/stm8论坛
77
因为硬件还没齐,所以只飞了几根线出来,调试I2C 。
两种环境下,flag1和flag2的值不同,在程序I2CWriteByte前;
除了初始化外;没有对I2C->SR1和I2C->SR2的其余操作,应该不会有硬件置位。
不知何故。望不吝赐教!
ErrorStatus I2C_CheckEvent(I2C_Event_TypeDef I2C_Event)
  u8 flag1 = 0;
  u8 flag2 = 0;
  ErrorStatus status = ERROR;
  /* Check the parameters */
  assert_param(IS_I2C_EVENT_OK(I2C_Event));
  flag1 = I2C->SR1;
  flag2 = I2C->SR2;
  /* Check which SRx register must be read */
  if (((u16)I2C_Event & (u16)0x0F00) == 0x0700)
    /* Check whether the last event is equal to I2C_EVENT */
    if (flag1 & (u8)I2C_Event)
      /* SUCCESS: last event is equal to I2C_EVENT */
      status = SUCCESS;
    else
      /* ERROR: last event is different from I2C_EVENT */
      status = ERROR;
  else /* Returns whether the status register to check is SR2 */
    if (flag2 & (u8)I2C_Event)
      status = SUCCESS;
    else
      status = ERROR;
  /* Return status */
  return status;
此帖出自stm32/stm8论坛
63
此帖出自stm32/stm8论坛
