3024|7
66
到数据 [复制链接]
                                 会就是会不会就是不会,如果你会那你就把问题解决,别整天什么贴膏药,什么程序有问题净装B
此帖出自stm32/stm8论坛
                                     详情 回复 发表于 2008-11-13 16:51
又是贴药膏了!
此帖出自stm32/stm8论坛
78
贴药膏什么意思
正常来说如果
USART_SendData(USART1, TxBuffer[TxCounter++]);
那么在stm32芯片的pin_9脚上应该有电压输出是吗?
此帖出自stm32/stm8论坛
论坛里没人会
                                 晕呀
此帖出自stm32/stm8论坛
81
你要做什么都不说清楚,谁能够会?
此帖出自stm32/stm8论坛
请香主帮忙
问题已解决
此帖出自stm32/stm8论坛
64
请参考STM32固件库中提供的例程
那里有很多关于USART的例程
  DMA_Interrupt: Provide a basic communication between USART1 and USART2 using DMA capability, flags and interrupts.
  DMA_Polling: Provide a basic communication between USART1 and USART2 using DMA capability.
  HalfDuplex: Provide a basic communication between USART1 and USART2 in Half-Duplex mode using flags.
  HyperTerminal_HwFlowControl:  Use the USART with hardware flow control and communicate with the Hyperterminal.
  HyperTerminal_Interrupt: Use the USART1 interrupts to communicate with the hyperterminal.
  Interrupt: Provide a basic communication between USART1 and USART2 using interrupts.
  IrDA: Use IrDA mode. Two projects are provided: one for IrDA transmitter and the second for IrDA receiver
  MultiProcessor: Use the USART in multi-processor mode.
  Polling: Provide a basic communication between USART1 and USART2 using flags.
  Printf: Retarget the C library printf function to the USART.
  Smartcard: Use the USART in Smart Card mode.
  Synchronous: Provide a basic communication between USART1 (Synchronous mode) and SPI1 using flags.
对不起,我没有那么多时间帮你看程序,你自己对照例子研究一下吧。
此帖出自stm32/stm8论坛
75
我只是想知道这种现象的原因
此帖出自stm32/stm8论坛
