21
串口终于通了...ADC是有漂移
这个结果是在EMSTM32V1上用ADC的例程得到的结果.
42;31m AD value = 0x0F41
 AD value = 0x0F44
 AD value = 0x0F53
 AD value = 0x0F42
 AD value = 0x0F44
 AD value = 0x0F46
 AD value = 0x0F41
 AD value = 0x0F45
 AD value = 0x0F44
 AD value = 0x0F45
 AD value = 0x0F42
 AD value = 0x0F40
 AD value = 0x0F42
 AD value = 0x0F46
 AD value = 0x0F45
 AD value = 0x0F30
 AD value = 0x0F41
 AD value = 0x0F43
 AD value = 0x0F43
 AD value = 0x0F3C
 AD value = 0x0F44
 AD value = 0x0F44
 AD value = 0x0F3B
 AD value = 0x0F45
 AD value = 0x0F45
 AD value = 0x0F45
 AD value = 0x0F45
 AD value = 0x0F45
 AD value = 0x0F45
 AD value = 0x0F46
家里没表,先来个估算吧.
假定Vref=3.30V. 12位ADC
vd1=0x0f30=3888
v1=vd1*Vref/2^12=3888*3.3/4096=3.132421875V
vd2=0x0f46=3910
v2=vd2*Vref/2^12=3910*3.3/4096=3.150146484375V
从这个结果可以看出有近18mV的漂移~~~
当然这个没加入软件滤波...
如果外电压在15V左右采用1/5分压电路后,会有90mV的漂移~~~
没看板子的采样保持电路,所以现在没有发言权~~~
此帖出自stm32/stm8论坛
75
22
看错了~~~还有个0x0f53,看来漂移还要大~~~
此帖出自stm32/stm8论坛
75
23
KAO 菜农!
你保重身体哦!你家网管出去玩去了?!哈哈
关键你假设的这个3.30V 在不同板子上由于3.30V的三端的离散性,同样的外部输入还要变!
TO 圈圈同学:
ADI这样的老牌模拟公司当然啦!它的都不好,没好的了~~
此帖出自stm32/stm8论坛
65
24
1/3处还不错~~~(网管让我一小时~~~)
42;31m AD value = 0x0662
 AD value = 0x0661
 AD value = 0x0663
 AD value = 0x0660
 AD value = 0x0660
 AD value = 0x0663
 AD value = 0x0662
 AD value = 0x0662
 AD value = 0x065E
 AD value = 0x0661
 AD value = 0x0662
 AD value = 0x0662
 AD value = 0x0662
 AD value = 0x0661
 AD value = 0x0662
 AD value = 0x0660
 AD value = 0x0661
 AD value = 0x0660
 AD value = 0x0662
 AD value = 0x0663
 AD value = 0x0663
 AD value = 0x0663
 AD value = 0x0662
此帖出自stm32/stm8论坛
谢谢~~~哈哈...1/2处也行~~~
42;31m AD value = 0x07FA
 AD value = 0x07FB
 AD value = 0x07FA
 AD value = 0x07FA
 AD value = 0x07FB
 AD value = 0x07FB
 AD value = 0x07F9
 AD value = 0x07F6
 AD value = 0x07F7
 AD value = 0x07FA
 AD value = 0x07F9
 AD value = 0x07F8
 AD value = 0x07FA
 AD value = 0x07F8
 AD value = 0x07F9
 AD value = 0x07F6
 AD value = 0x07F7
 AD value = 0x07FE
 AD value = 0x07FA
此帖出自stm32/stm8论坛
86
26
LED跑马
                                 TIM1 输出占空比不同的PWM,IIC放出去写EEPROM,使用最高的采用速率试试
此帖出自stm32/stm8论坛
27
几个月前我也做过ADC的测试
  几个月前也做过ADC的测试,对于测试结果的稳定性可以感到满意。我使用的是ST官方的DEMO板,测量结果比万利的和EMBEST的DEMO板好。我在0~3.3V间,选取了不同电压等级进行测量,过些时候可以贴出来让大家参考。
此帖出自stm32/stm8论坛
63
28
STM32的ADC-稳定性试验
  使用的是ST官方的STM32的DEMO板,测量的是DEMO板上的电位器电压,每次的测量结果由4次采样取平均值得到,采样时间设置为55.5 cycles。
  注:每个测量点都进行了>30秒的测量和统计,统计包括最大值、最小值和平均值。另外,每秒可以得到和统计多个测量结果,也就是说下面每个测量点的统计结果都是由上百个测量结果来的。
1)~4000
    min        4058
    max        4064
    avr        4060
2)~3000
    min        2952
    max        2956
    avr        2953
3)~2000
    min        2027
    max        2030
    avr        2028
4)~1000
    min        980
    max        982
    avr        981
5)~200
    min        216
    max        218
    avr        216
此帖出自stm32/stm8论坛
29
STM32的ADC-稳定性试验的结论
  根据楼上的测量试验,对照STM32 ADC的特性参数(Rev.4),可以相信它的
Total unadjusted error的典型值能达到3。
  说明,ST官方的STM32的DEMO板在VDDA和Vref+的电路连接为:VDD经过LC滤波接VDDA,L估计是10uH数量级,C为10uF并联10nF;VDDA经过RC滤波接Vref+,R为47欧,C为10nF。由此可见,ST官方的STM32的DEMO板用料更好些,但也没什么特别设计。
此帖出自stm32/stm8论坛
87
ijk 这试验效果真不错
不是用USB 供电的?
关于STM32的AD的设计,我也发了些噪声,呵呵,其实我的主要看法是在没有外接ref的情况下(非100Pin的),由于在板的时候,供电的3.3V一般是三端,这个三端本身的离散性是要考虑的,而不是针对一块板上本身的离散性,是生产时,由于不同板子上的3.3V(基准)完全可能有3%的离散性,那么对于外部输入的信号在不同板上转换结果将有3%的离散性。
此帖出自stm32/stm8论坛
63
31
哦 VDDA 有LC! 呵呵
                                 这就是老牌帝国主义和新兴力量的差距哈!
此帖出自stm32/stm8论坛
90
32
关于STM32的VDDA 有LC
                                   上面提到STM32官方DEMO板的VDDA 有LC滤波,但需要说明的是,使用的L实际上是很低廉的贴片封装的,尺寸可能是0603或0805,成本或许也就1毛钱人民币,并不希奇,呵呵
此帖出自stm32/stm8论坛
33
qihao
-------------qihao:这个好办,其实采样值都是相对值,还没考虑零漂,温漂,可以用软件重新整定,这个工作可以在设备完成后来做,设备完成后,在软件上加一个系统整定界面,设备外加允许输入的最大信号(标准信号源)这个测试的对应采样值就和外加标准信号的物理量对应起来了,然后找到零信号(输入端短接)对应的采样值,知道了满量程和零点的采样值,那么每个采样点对应的物理量就清楚了,至于温漂的整定,可以用补偿的方法。
此帖出自stm32/stm8论坛
61
34
ijk:你那里买的板子?多少钱?
此帖出自stm32/stm8论坛
STM32官方DEMO板的电源部分线路图
完整的线路图可在ST网站下载:http://www.st.com/stonline/products/literature/um/13472.pdf
此帖出自stm32/stm8论坛
83
36
建议楼主的问题还是要多些思考深入分析的好
STM32的12BIT ADC自身实际上是非常棒,可以负责任的说STM32自带的ADC实际上比大部分独立的12BIT ADC还要好,楼主说的数据跳动大的问题,还得具体问题具体分析。
     就我个人实地使用的情况,我用的板子是ST公司的评估版(ST网站上可以下到该板的PROTEL文件),电路板是四层板,板上有一个电位器可以来测试ADC,我在实地测试ADC的数据是非常稳定的,数据基本上是恒定的跳动不会超过1LSB的!用2根杜邦线引出ADC输入引脚和AGND引脚,直接去测量一节电池的电压,数值也是非常稳定的,变动也是不超过正负1LSB,实在是非常了不起的。对比之下我用12bit 的MAX1284这个独立ADC都得有2~3LSB,
    我在我发过的STM32做的示波器的帖子里有ADC采样的图形曲线
此帖出自stm32/stm8论坛
62
37
补充下,
绿色的那根线就是测试评估板上可调电位器输出的电压,可以看到直线是非常平直,非常稳定的的。读数跳动不会大于1LSB。
    看了楼上几位的数据,跟我这边的实验结果还是有很大差距的。个人觉得估计还是跟电源以及布线有很大关系,ST的官方评估板的布线水平还是相当高的,值得学习
此帖出自stm32/stm8论坛
83
38
可能是4层板的关系!
                                 这个显示程序是你做的?做得不错!是.net的吧,C# ?,不像是VC的~!
此帖出自stm32/stm8论坛
83
39
to 00:
ADI 的ARM内置的ADC是12bit分辨率和12bit精度的,当然很好的啦
一般集成的达不到的...
此帖出自stm32/stm8论坛
83
回40楼:
    程序是.NET的,用C#2005写的。个人认为如果要开发.NET的程序的话,最好还是用C#来做,用C++来开发.NET应用的话,感觉相对C#并没有什么优势,C#是.NET最佳的搭档,C#本身就是专门为.NET平台而度身定做。
     不过好像基于.NET的程序好像性能要比传统MFC的程序差些,同样的绘图程序用.NET开发的和用MFC做的相比CPU利用率要高不少,在老PIII850笔记本上.NET的要到60%,MFC的则不足30%。不过在双核的机器上好像始终都是零
此帖出自stm32/stm8论坛
直播时间:3月12日(周三)上午10:00
直播奖励:多功能榨汁机、蓝牙音箱、手机支架
