41
哈哈,我不会用C#.
                                 我只会VC!老了,不想再学C#了!幸好wince 还可以用EVC开发,不过将来估计是.net的天下,不管了,到时候再说!
此帖出自stm32/stm8论坛
42
工业上用到ADC的地方,软件滤波几乎是标配了……
此帖出自stm32/stm8论坛
84
43
AD还可以拉
                                 MCU内部的AD和外部专用的AD虽然都号称12位,但内部的AD实际精度要差不少,我用过TMS320F280X系列的内部12位AD做电力产品,精度能达到0.1%,当然需要处理,刚拿到万利的评估板,AD测试结果和楼主差不多,估计真正的产品也能达到0.1%,目前刚开始做,准备用在单相电力测量仪表中,希望可以和一些朋友进行交流。
此帖出自stm32/stm8论坛
89
44
完全同意楼上的看法
此帖出自stm32/stm8论坛
45
ST PK F020
ST 12位AD与C8051F020的12位比怎样?
以前用过F020
此帖出自stm32/stm8论坛
90
46
哈哈~~~这个PK很现实~~~
此帖出自stm32/stm8论坛
79
47
转载老外做的STM32 ADC试验
这个老外用ST的STM32官方评估板做到了+/- 1LSB,而且没有使用软件滤波:
more news, compared the KEIL MCBSTM32 board and
the ST board STM32F10F10X-128K-EVAL to really cool one with TFT LCD
the ST board have TONS more ADC noise, removed LCD and have now IMPRESSIVE low noise !
only +/- one LSB wow !!
so the switchmode supply on the back side of the LCD is one nasty noise source to the ADC :-)
be warned if you design with switchmodes and need a clean ADC, add extra coils and caps near the noise source to isoilate it.
Now I am investigating the KEIL board, the capacitors for VDDA and analog GND are placed too far away from IC,
this gives poor decoubling to the analog section, it is hard to fix on that board.
链接:http://www.stm32circle.com/forum/viewtopic.php?id=161
其中还有图形
此帖出自stm32/stm8论坛
