5192|9
STR710在UCOS下跑飞是是么原因。 [复制链接]
                                 如题
此帖出自stm32/stm8论坛
                                 static void AppTaskKbd(void *p_arg){#if OS_CRITICAL_METHOD == 3                      /* Allocate storage for CPU status register           */    OS_CPU_SR  cpu_sr = 0;#endif    volatile int i,k;    int Key_ADValue;    int KeyTempValue[4];    int KeyValue[4];    int KeyDownInterval[4];    (void)p_arg;    KBD_Init();    Kbd_Status.KeyStatus=KeyStatus_Idle;    Kbd_Status.KeyValue=0;    for(i=0;i<4;i++)    {        KeyValue=0;        KeyTempValue=0;        KeyDownInterval=0;    }        while(1)    {        for(i=0;i<4;i++)        {            k=0;            OS_ENTER_CRITICAL();            Key_ADValue=do_ADC(i+4);            OS_EXIT_CRITICAL();            if((Key_ADValue>=AD_K1_Min)&&(Key_ADValue<=AD_K1_Max))                k=i*5+1;                if((Key_ADValue>=AD_K2_Min)&&(Key_ADValue<=AD_K2_Max))                k=i*5+2;                if((Key_ADValue>=AD_K3_Min)&&(Key_ADValue<=AD_K3_Max))                k=i*5+3;                if((Key_ADValue>=AD_K4_Min)&&(Key_ADValue<=AD_K4_Max))                k=i*5+4;                if((Key_ADValue>=AD_K5_Min)&&(Key_ADValue<=AD_K5_Max))                k=i*5+5;                if(k)        //有键按下,重复按键的判断            {                if(k==KeyTempValue)        //上次的按键                {                    KeyDownInterval+=20;                    if(KeyValue)                    //已处于按下状态                    {                        if(KeyDownInterval>400)                        {                            KeyDownInterval=0;                            Kbd_Status.KeyStatus=KeyStatus_Repeat;                            Kbd_Status.KeyValue=KeyValue;                            OSMboxPost(MBox_Key,(void*)&Kbd_Status);                            //sprintf(TxBuf,"%02x> ",KeyValue);                            //AT91F_US_SendFrame(AT91C_BASE_US1,TxBuf,5 ,0,0);                        }                    }                    else                            //尚没有键按下                     {                        if(KeyDownInterval>40)                        {                            KeyValue=KeyTempValue;                            KeyDownInterval=0;                            Kbd_Status.KeyStatus=KeyStatus_Down;                            Kbd_Status.KeyValue=KeyValue;                            OSMboxPost(MBox_Key,(void *)&Kbd_Status);                            //sprintf(TxBuf,"%02x> ",KeyValue);                            //AT91F_US_SendFrame(AT91C_BASE_US1,TxBuf,5 ,0,0);                        }                    }                }                else                        //新按键或组合按键(认为错误)                {                    if(KeyValue)            //已经认定有键按下,新键值不对?                    {                        KeyTempValue=KeyStatus_Idle;                        KeyDownInterval=0;                        Kbd_Status.KeyStatus=KeyStatus_Up;                        Kbd_Status.KeyValue=KeyValue;                        OSMboxPost(MBox_Key,(void *)&Kbd_Status);                        KeyValue=KeyStatus_Idle;                    }                    else                    //认定新键按下                    {                        KeyTempValue=k;                        KeyValue=KeyStatus_Idle;                        KeyDownInterval=0;                        //Kbd_Status.KeyStatus=Key_Error;                        //Kbd_Status.KeyValue=KeyValue;                        //OSMboxPost(MBox_Key,(void *)&Kbd_Status);                    }                                    }            }            else    //没有键按下或已抬起            {                if(KeyValue)                {                    Kbd_Status.KeyStatus=KeyStatus_Up;                    Kbd_Status.KeyValue=KeyValue;                    OSMboxPost(MBox_Key,(void *)&Kbd_Status);                }                KeyDownInterval=0;                KeyTempValue=KeyStatus_Idle;                KeyValue=KeyStatus_Idle;            }        }        OSTimeDly(20);    }}   详情 回复 发表于 2007-12-4 11:36
81
是程序的问题。
此帖出自stm32/stm8论坛
比较难找
有时候运行2个多小时,有时候又能运行10几个小时,总之时间不确定,后就死了。
我的代码中有一段ADC的程序,会不会是ADC引起的。代码如下:
         ADC12->CSR&=~ADC12_OR;
         ADC12_ConversionStart();
         while(ADC12_FlagStatus(ADC12_DA1)==RESET);
         while(ADC12_FlagStatus(ADC12_OR));
           ADC12_Value.i%=6;
           ADC12_Value.buff[ADC12_Value.i]=ADC12_ConversionValue(ADC12_CHANNEL1);
           ADC12->CSR &= ~ADC12_DA1;
           ADC12_Value.i++;
           ADC12_ConversionStop();
此帖出自stm32/stm8论坛
64
怀疑哪部分就先把哪部分关掉,然后再试
                                 另外,系统不响应有多种情况,有可能是死循环,有可能是程序跑飞(超出预想的范围),也有个能是正在等待什么事件,带操作系统时还有可能是死锁,等等。楼主应该先确定是什么状况,确定了状况再查找原因。
此帖出自stm32/stm8论坛
删除了上面的代码,运行了一天没有跑飞
                                 可我要测电池的电量,怎么办。STR710的ADC怎么用?
此帖出自stm32/stm8论坛
你的程序有点怪,请确认第4行后面的分号是有意加上的
如果分号是有意加上的,那么后面的两个大括号就是多余的。当然这不是错,我只是提醒,以防一个简单的错误害了大家。
我不会UCOS,没法想象是否与它有关。但我知道与OS扯上关系后,死锁或互斥区的保护是很头疼的问题,搞不好就会发生随机错误的状况。
还是我在4楼说的,你如何能确认是程序跑飞了,而不是操作系统中死锁了。即使是跑飞了也要确定是在哪里飞的,例如在几个关键点分别点亮几个LED,离开时关闭LED,在程序跑飞时看看哪个LED还在亮,大致可确认跑飞的范围。比如在你怀疑的读ADC的程序前点亮LED,读完ADC关闭LED。
刚看到你要测电池的电量,有一个问题,系统隔多长时间读一次ADC?
此帖出自stm32/stm8论坛
楼主可以只运行这段ADC的代码,循环运行
借此排除是这段程序的问题。
如果这段程序没有问题,那肯定是其它与这部分相关的程序间的配合有问题。
此帖出自stm32/stm8论坛
59
我每秒测一次ADC
                                 ADC/秒
此帖出自stm32/stm8论坛
87
去掉这段ADC代码程序正常了。
                                 运行了快30个小时了程序没有跑飞。
此帖出自stm32/stm8论坛
我的按键检测 20ms 4路AD 没问题
#endif
    volatile int i,k;
    int Key_ADValue;
    int KeyValue[4];
    (void)p_arg;
    KBD_Init();
    for(i=0;i<4;i++)
        KeyValue=0;
        KeyTempValue=0;
        KeyDownInterval=0;
    while(1)
        for(i=0;i<4;i++)
            k=0;
            OS_EXIT_CRITICAL();
                k=i*5+1;
                k=i*5+2;
                k=i*5+3;
                k=i*5+4;
                k=i*5+5;
                            KeyDownInterval=0;
                    else                            //尚没有键按下
                            KeyDownInterval=0;
                        KeyDownInterval=0;
                    else                    //认定新键按下
                        KeyTempValue=k;
                        KeyDownInterval=0;
            else    //没有键按下或已抬起
                if(KeyValue)
                KeyDownInterval=0;
        OSTimeDly(20);
此帖出自stm32/stm8论坛
