;******************** (C) COPYRIGHT 2003 STMicroelectronics ******************** ;* File Name : 71x_vect.s ;* Author : MCD Application Team ;* Date First Issued : 16/05/2003 ;* Description : This file used to initialize the exception and IRQ ;* vectors, and to enter/return to/from exceptions handlers. ;******************************************************************************* ;* History: ;* 13/01/2006 : V3.1 ;* 24/05/2005 : V3.0 ;* 30/11/2004 : V2.0 ;* 14/07/2004 : V1.3 ;* 01/01/2004 : V1.2 ;******************************************************************************* ; THE PRESENT SOFTWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS WITH ; CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME. ; AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT, INDIRECT ; OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE CONTENT ; OF SUCH SOFTWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING INFORMATION ; CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS. ;*******************************************************************************/
;******************************************************************************* ; ?RESET ; Reset Vector. ; Normally, segment INTVEC is linked at address 0. ; For debugging purposes, INTVEC may be placed at other ; addresses. ; A debugger that honors the entry point will start the ; program in a normal way even if INTVEC is not at address 0. ;*******************************************************************************
;******************************************************************************* ; Import the __program_start address from 71x_init.s ;*******************************************************************************
;******************************************************************************* ;* Macro Name : SaveContext ;* Description : This macro used to save the context before entering ; an exception handler. ;* Input : The range of registers to store. ;* Output : none ;*******************************************************************************
SaveContext MACRO reg1,reg2
STMFD sp!,{reg1-reg2,lr} ; Save The workspace plus the current return ; address lr_ mode into the stack. MRS r1,spsr ; Save the spsr_mode into r1. STMFD sp!,{r1} ; Save spsr. ENDM
;******************************************************************************* ;* Macro Name : RestoreContext ;* Description : This macro used to restore the context to return from ; an exception handler and continue the program execution. ;* Input : The range of registers to restore. ;* Output : none ;*******************************************************************************
RestoreContext MACRO reg1,reg2
LDMFD sp!,{r1} ; Restore the saved spsr_mode into r1. MSR spsr_cxsf,r1 ; Restore spsr_mode. LDMFD sp!,{reg1-reg2,pc}^; Return to the instruction following... ; ...the exception interrupt. ENDM
;******************************************************************************* ;* Function Name : UndefinedHandler ;* Description : This function called when undefined instruction ; exception is entered. ;* Input : none ;* Output : none ;******************************************************************************* UndefinedHandler SaveContext r0,r12 ; Save the workspace plus the current ; return address lr_ und and spsr_und. ldr r0,=Undefined_Handler ldr lr,=Undefined_Handler_end bx r0 ; Branch to Undefined_Handler Undefined_Handler_end: RestoreContext r0,r12 ; Return to the instruction following... ; ...the undefined instruction.
;******************************************************************************* ;* Function Name : SWIHandler ;* Description : This function called when SWI instruction executed. ;* Input : none ;* Output : none ;*******************************************************************************
SWIHandler SaveContext r0,r12 ; Save the workspace plus the current ; return address lr_ svc and spsr_svc. ldr r0,=SWI_Handler ldr lr,=SWI_Handler_end
bx r0 ; Branch to SWI_Handler. SWI_Handler_end: RestoreContext r0,r12 ; Return to the instruction following... ; ...the SWI instruction.
;******************************************************************************* ;* Function Name : IRQHandler ;* Description : This function called when IRQ exception is entered. ;* Input : none ;* Output : none ;*******************************************************************************
IRQHandler SUB lr,lr,#4 ; Update the link register SaveContext r0,r12 ; Save the workspace plus the current ; return address lr_ irq and spsr_irq. LDR lr, =ReturnAddress ; Read the return address. LDR r0, =EIC_base_addr LDR r1, =IVR_off_addr ADD pc,r0,r1 ; Branch to the IRQ handler. ReturnAddress: ; Clear pending bit in EIC (using the proper IPRx) LDR r0, =EIC_base_addr LDR r2, [r0, #CICR_off_addr] ; Get the IRQ channel number. MOV r3,#1 MOV r3,r3,LSL r2 STR r3,[r0, #IPR_off_addr] ; Clear the corresponding IPR bit. RestoreContext r0,r12 ; Restore the context and return to the... ; ...program execution.
;******************************************************************************* ;* Function Name : PrefetchAbortHandler ;* Description : This function called when Prefetch Abort ; exception is entered. ;* Input : none ;* Output : none ;*******************************************************************************
PrefetchAbortHandler SUB lr,lr,#4 ; Update the link register. SaveContext r0,r12 ; Save the workspace plus the current ; return address lr_abt and spsr_abt. ldr r0,=Prefetch_Handler ldr lr,=Prefetch_Handler_end
bx r0 ; Branch to Prefetch_Handler. Prefetch_Handler_end: RestoreContext r0,r12 ; Return to the instruction following that... ; ...has generated the prefetch abort exception.
;******************************************************************************* ;* Function Name : DataAbortHandler ;* Description : This function is called when Data Abort ; exception is entered. ;* Input : none ;* Output : none ;*******************************************************************************
DataAbortHandler SUB lr,lr,#8 ; Update the link register. SaveContext r0,r12 ; Save the workspace plus the current ; return address lr_ abt and spsr_abt. ldr r0,=Abort_Handler ldr lr,=Abort_Handler_end
bx r0 ; Branch to Abort_Handler. Abort_Handler_end: RestoreContext r0,r12 ; Return to the instruction following that... ; ...has generated the data abort exception.
;******************************************************************************* ;* Function Name : FIQHandler ;* Description : This function is called when FIQ ; exception is entered. ;* Input : none ;* Output : none ;*******************************************************************************
FIQHandler SUB lr,lr,#4 ; Update the link register. SaveContext r0,r7 ; Save the workspace plus the current ; return address lr_ fiq and spsr_fiq. ldr r0,=FIQ_Handler ldr lr,=FIQ_Handler_end
bx r0 ; Branch to FIQ_Handler. FIQ_Handler_end: RestoreContext r0,r7 ; Restore the context and return to the... ; ...program execution.
;******************************************************************************* ;* Macro Name : IRQ_to_SYS ;* Description : This macro used to switch form IRQ mode to SYS mode ;* Input : none. ;* Output : none ;******************************************************************************* IRQ_to_SYS MACRO MSR cpsr_c,#0x1F ; Switch to SYS mode STMFD sp!,{lr} ; Save the link register. ENDM ;******************************************************************************* ;* Macro Name : SYS_to_IRQ ;* Description : This macro used to switch from SYS mode to IRQ mode ; then to return to IRQHnadler routine. ;* Input : none. ;* Output : none. ;******************************************************************************* SYS_to_IRQ MACRO LDMFD sp!,{lr} ; Restore the link register. MSR cpsr_c,#0xD2 ; Switch to IRQ mode. MOV pc,lr ; Return to IRQHandler routine to clear the ; pending bit. ENDM ;******************************************************************************* ;* Function Name : T0TIMIIRQHandler ;* Description : This function used to switch to SYS mode before entering ; the T0TIMI_IRQHandler function located in 71x_it.c. ; Then to return to IRQ mode after the ; T0TIMI_IRQHandler function termination. ;* Input : none. ;* Output : none. ;******************************************************************************* T0TIMIIRQHandler IRQ_to_SYS ldr r0,=T0TIMI_IRQHandler ldr lr,=T0TIMI_IRQHandler_end bx r0 T0TIMI_IRQHandler_end: SYS_to_IRQ ;******************************************************************************* ;* Function Name : FLASHIRQHandler ;* Description : This function used to switch to SYS mode before entering ; the FLASH_IRQHandler function located in 71x_it.c. ; Then to return to IRQ mode after the ; FLASH_IRQHandler function termination. ;* Input : none ;* Output : none ;******************************************************************************* FLASHIRQHandler IRQ_to_SYS ldr r0,=FLASH_IRQHandler ldr lr,=FLASH_IRQHandler_end bx r0 FLASH_IRQHandler_end: SYS_to_IRQ ;******************************************************************************* ;* Function Name : RCCUIRQHandler ;* Description : This function used to switch to SYS mode before entering ; the RCCU_IRQHandler function located in 71x_it.c. ; Then to return to IRQ mode after the ; RCCU_IRQHandler function termination. ;* Input : none ;* Output : none ;******************************************************************************* RCCUIRQHandler IRQ_to_SYS ldr r0,=RCCU_IRQHandler ldr lr,=RCCU_IRQHandler_end bx r0 RCCU_IRQHandler_end: SYS_to_IRQ ;******************************************************************************* ;* Function Name : RTCIRQHandler ;* Description : This function used to switch to SYS mode before entering ; the RTC_IRQHandler function located in 71x_it.c. ; Then to return to IRQ mode after the ; RTC_IRQHandler function termination. ;* Input : none ;* Output : none ;******************************************************************************* RTCIRQHandler IRQ_to_SYS ldr r0,=RTC_IRQHandler ldr lr,=RTC_IRQHandler_end bx r0 RTC_IRQHandler_end: SYS_to_IRQ ;******************************************************************************* ;* Function Name : WDGIRQHandler ;* Description : This function used to switch to SYS mode before entering ; the WDG_IRQHandler function located in 71x_it.c. ; Then to return to IRQ mode after the ; WDG_IRQHandler function termination. ;* Input : none ;* Output : none ;******************************************************************************* WDGIRQHandler IRQ_to_SYS ldr r0,=WDG_IRQHandler ldr lr,=WDG_IRQHandler_end bx r0 WDG_IRQHandler_end: SYS_to_IRQ ;******************************************************************************* ;* Function Name : XTIIRQHandler ;* Description : This function used to switch to SYS mode before entering ; the XTI_IRQHandler function located in 71x_it.c. ; Then to return to IRQ mode after the ; XTI_IRQHandler function termination. ;* Input : none ;* Output : none ;******************************************************************************* XTIIRQHandler IRQ_to_SYS ldr r0,=XTI_IRQHandler ldr lr,=XTI_IRQHandler_end bx r0 XTI_IRQHandler_end: SYS_to_IRQ ;******************************************************************************* ;* Function Name : USBHPIRQHandler ;* Description : This function used to switch to SYS mode before entering ; the USBHP_IRQHandler function located in 71x_it.c. ; Then to return to IRQ mode after the ; USBHP_IRQHandler function termination. ;* Input : none ;* Output : none ;******************************************************************************* USBHPIRQHandler IRQ_to_SYS ldr r0,=USBHP_IRQHandler ldr lr,=USBHP_IRQHandler_end bx r0 USBHP_IRQHandler_end: SYS_to_IRQ ;******************************************************************************* ;* Function Name : I2C0ITERRIRQHandler ;* Description : This function used to switch to SYS mode before entering ; the I2C0ITERR_IRQHandler function located in 71x_it.c. ; Then to return to IRQ mode after the ; I2C0ITERR_IRQHandler function termination. ;* Input : none ;* Output : none ;******************************************************************************* I2C0ITERRIRQHandler IRQ_to_SYS ldr r0,=I2C0ITERR_IRQHandler ldr lr,=I2C0ITERR_IRQHandler_end bx r0 I2C0ITERR_IRQHandler_end: SYS_to_IRQ ;******************************************************************************* ;* Function Name : I2C1ITERRIRQHandler ;* Description : This function used to switch to SYS mode before entering ; the I2C1ITERR_IRQHandler function located in 71x_it.c. ; Then to return to IRQ mode after the ; I2C1ITERR_IRQHandler function termination. ;* Input : none ;* Output : none ;******************************************************************************* I2C1ITERRIRQHandler IRQ_to_SYS ldr r0,=I2C1ITERR_IRQHandler ldr lr,=I2C1ITERR_IRQHandler_end bx r0 I2C1ITERR_IRQHandler_end: SYS_to_IRQ ;******************************************************************************* ;* Function Name : UART0IRQHandler ;* Description : This function used to switch to SYS mode before entering ; the UART0_IRQHandler function located in 71x_it.c. ; Then to return to IRQ mode after the ; UART0_IRQHandler function termination. ;* Input : none ;* Output : none ;******************************************************************************* UART0IRQHandler IRQ_to_SYS ldr r0,=UART0_IRQHandler ldr lr,=UART0_IRQHandler_end bx r0 UART0_IRQHandler_end: SYS_to_IRQ ;******************************************************************************* ;* Function Name : UART1IRQHandler ;* Description : This function used to switch to SYS mode before entering ; the UART1_IRQHandler function located in 71x_it.c. ; Then to return to IRQ mode after the ; UART1_IRQHandler function termination. ;* Input : none ;* Output : none ;******************************************************************************* UART1IRQHandler IRQ_to_SYS ldr r0,=UART1_IRQHandler ldr lr,=UART1_IRQHandler_end bx r0 UART1_IRQHandler_end: SYS_to_IRQ ;******************************************************************************* ;* Function Name : UART2IRQHandler ;* Description : This function used to switch to SYS mode before entering ; the UART2_IRQHandler function located in 71x_it.c. ; Then to return to IRQ mode after the ; UART2_IRQHandler function termination. ;* Input : none ;* Output : none ;******************************************************************************* UART2IRQHandler IRQ_to_SYS ldr r0,=UART2_IRQHandler ldr lr,=UART2_IRQHandler_end bx r0 UART2_IRQHandler_end: SYS_to_IRQ ;******************************************************************************* ;* Function Name : UART3IRQHandler ;* Description : This function used to switch to SYS mode before entering ; the UART3_IRQHandler function located in 71x_it.c. ; Then to return to IRQ mode after the ; UART3_IRQHandler function termination. ;* Input : none ;* Output : none ;******************************************************************************* UART3IRQHandler IRQ_to_SYS ldr r0,=UART3_IRQHandler ldr lr,=UART3_IRQHandler_end bx r0 UART3_IRQHandler_end: SYS_to_IRQ ;******************************************************************************* ;* Function Name : BSPI0IRQHandler ;* Description : This function used to switch to SYS mode before entering ; the BSPI0_IRQHandler function located in 71x_it.c. ; Then to return to IRQ mode after the ; BSPI0_IRQHandler function termination. ;* Input : none ;* Output : none ;******************************************************************************* BSPI0IRQHandler IRQ_to_SYS ldr r0,=BSPI0_IRQHandler ldr lr,=BSPI0_IRQHandler_end bx r0 BSPI0_IRQHandler_end: SYS_to_IRQ ;******************************************************************************* ;* Function Name : BSPI1IRQHandler ;* Description : This function used to switch to SYS mode before entering ; the BSPI1_IRQHandler function located in 71x_it.c. ; Then to return to IRQ mode after the ; BSPI1_IRQHandler function termination. ;* Input : none ;* Output : none ;******************************************************************************* BSPI1IRQHandler IRQ_to_SYS ldr r0,=BSPI1_IRQHandler ldr lr,=BSPI1_IRQHandler_end bx r0 BSPI1_IRQHandler_end: SYS_to_IRQ ;******************************************************************************* ;* Function Name : I2C0IRQHandler ;* Description : This function used to switch to SYS mode before entering ; the I2C0_IRQHandler function located in 71x_it.c. ; Then to return to IRQ mode after the ; I2C0_IRQHandler function termination. ;* Input : none ;* Output : none ;******************************************************************************* I2C0IRQHandler IRQ_to_SYS ldr r0,=I2C0_IRQHandler ldr lr,=I2C0_IRQHandler_end bx r0 I2C0_IRQHandler_end: SYS_to_IRQ ;******************************************************************************* ;* Function Name : I2C1IRQHandler ;* Description : This function used to switch to SYS mode before entering ; the I2C1_IRQHandler function located in 71x_it.c. ; Then to return to IRQ mode after the ; I2C1_IRQHandler function termination. ;* Input : none ;* Output : none ;******************************************************************************* I2C1IRQHandler IRQ_to_SYS ldr r0,=I2C1_IRQHandler ldr lr,=I2C1_IRQHandler_end bx r0 I2C1_IRQHandler_end: SYS_to_IRQ ;******************************************************************************* ;* Function Name : CANIRQHandler ;* Description : This function used to switch to SYS mode before entering ; the CAN_IRQHandler function located in 71x_it.c. ; Then to return to IRQ mode after the ; CAN_IRQHandler function termination. ;* Input : none ;* Output : none ;******************************************************************************* CANIRQHandler IRQ_to_SYS ldr r0,=CAN_IRQHandler ldr lr,=CAN_IRQHandler_end bx r0 CAN_IRQHandler_end: SYS_to_IRQ ;******************************************************************************* ;* Function Name : ADC12IRQHandler ;* Description : This function used to switch to SYS mode before entering ; the ADC12_IRQHandler function located in 71x_it.c. ; Then to return to IRQ mode after the ; ADC12_IRQHandler function termination. ;* Input : none ;* Output : none ;******************************************************************************* ADC12IRQHandler IRQ_to_SYS ldr r0,=ADC12_IRQHandler ldr lr,=ADC12_IRQHandler_end bx r0 ADC12_IRQHandler_end: SYS_to_IRQ ;******************************************************************************* ;* Function Name : T1TIMIIRQHandler ;* Description : This function used to switch to SYS mode before entering ; the T1TIMI_IRQHandler function located in 71x_it.c. ; Then to return to IRQ mode after the ;
