6013|7
1027
求助:Kernel panic [复制链接]
ibblpp> printenv
bootargs=noinitrd root=/dev/mtdblock3 init=/linuxrc console=ttySAC0
bootcmd=nand read.jffs2 0x30007FC0 kernel; bootm 0x30007FC0
bootdelay=2
baudrate=115200
ethaddr=08:00:3e:26:0a:5b
ipaddr=192.168.7.17
serverip=192.168.7.11
netmask=255.255.255.0
stdin=serial
stdout=serial
stderr=serial
mtdids=nand0=nandflash0
mtdparts=mtdparts=nandflash0:256k@0(bootloader),128k(params),2m(kernel),-(root)
partition=nand0,0
mtddevnum=0
mtddevname=bootloader
Environment size: 443/131068 bytes
ibblpp> boot
NAND read: device 0 offset 0x60000, size 0x200000
Reading data from 0x25f800 -- 100% complete.
 2097152 bytes read: OK
## Booting image at 30007fc0 ...
   Image Name:   linux_2.6.29
   Created:      2011-03-08  17:50:24 UTC
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    1378888 Bytes =  1.3 MB
   Load Address: 30008000
   Entry Point:  30008000
   Verifying Checksum ... OK
   XIP Kernel Image ... OK
Starting kernel ...
Uncompressing Linux......................................................................................... done, booting the kernel.
Linux version 2.6.29.4-FriendlyARM (root@bblpp) (gcc version 4.3.2 (Sourcery G++ Lite 2008q3-72) ) #11 Wed Mar 9 01:39:12 HKT 2011
CPU: ARM920T [41129200] revision 0 (ARMv4T), cr=c0007177
CPU: VIVT data cache, VIVT instruction cache
Machine: FriendlyARM Mini2440 development board
Memory policy: ECC disabled, Data cache writeback
CPU S3C2440A (id 0x32440001)
S3C24XX Clocks, (c) 2004 Simtec Electronics
S3C244X: core 283.200 MHz, memory 70.800 MHz, peripheral 35.400 MHz
CLOCK: Slow mode (1.500 MHz), fast, MPLL on, UPLL on
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 16256
Kernel command line: noinitrd root=/dev/mtdblock3 init=/linuxrc console=ttySAC0
irq: clearing pending ext status 00080000
irq: clearing subpending status 00000003
irq: clearing subpending status 00000002
PID hash table entries: 256 (order: 8, 1024 bytes)
Console: colour dummy device 80x30
console [ttySAC0] enabled
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 64MB = 64MB total
Memory: 61968KB available (2444K code, 302K data, 156K init)
SLUB: Genslabs=12, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Calibrating delay loop... 141.31 BogoMIPS (lpj=353280)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
S3C2440: Initialising architecture
S3C2440: IRQ Support
S3C24XX DMA Driver, (c) 2003-2004,2006 Simtec Electronics
DMA channel 0 at c4808000, irq 33
DMA channel 1 at c4808040, irq 34
DMA channel 2 at c4808080, irq 35
DMA channel 3 at c48080c0, irq 36
S3C244X: Clock Support, DVS off
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
yaffs Feb 28 2010 21:33:18 Installing.
msgmni has been set to 121
alg: No test for stdrng (krng)
io scheduler noop registered (default)
Console: switching to colour frame buffer device 30x20
fb0: s3c2410fb frame buffer device
backlight       initialized
leds    initialized
buttons initialized
pwm     initialized
adc     initialized
s3c2440-uart.0: s3c2410_serial0 at MMIO 0x50000000 (irq = 70) is a S3C2440
s3c2440-uart.1: s3c2410_serial1 at MMIO 0x50004000 (irq = 73) is a S3C2440
s3c2440-uart.2: s3c2410_serial2 at MMIO 0x50008000 (irq = 76) is a S3C2440
loop: module loaded
Linux video capture interface: v2.00
Driver 'sd' needs updating - please use bus_type methods
S3C24XX NAND Driver, (c) 2004 Simtec Electronics
s3c2440-nand s3c2440-nand: Tacls=2, 28ns Twrph0=5 70ns, Twrph1=2 28ns
NAND device: Manufacturer ID: 0xec, Chip ID: 0xd3 (Samsung NAND 1GiB 3,3V 8-bit)
Scanning device for bad blocks
Bad eraseblock 878 at 0x000006dc0000
Bad eraseblock 879 at 0x000006de0000
Bad eraseblock 2135 at 0x000010ae0000
Bad eraseblock 4072 at 0x00001fd00000
Bad eraseblock 4974 at 0x000026dc0000
Bad eraseblock 4975 at 0x000026de0000
Creating 4 MTD partitions on "NAND 1GiB 3,3V 8-bit":
0x000000000000-0x000000060000 : "supervivi"
0x000000060000-0x000000260000 : "Kernel"
0x000000260000-0x000040260000 : "root"
mtd: partition "root" extends beyond the end of device "NAND 1GiB 3,3V 8-bit" -- size truncated to 0x3fda0000
0x000000000000-0x000040000000 : "nand"
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
s3c2410-ohci s3c2410-ohci: S3C24XX OHCI
s3c2410-ohci s3c2410-ohci: new USB bus registered, assigned bus number 1
s3c2410-ohci s3c2410-ohci: irq 42, io mem 0x49000000
usb usb1: New USB device found, idVendor=1d6b, idProduct=0001
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: S3C24XX OHCI
usb usb1: Manufacturer: Linux 2.6.29.4-FriendlyARM ohci_hcd
usb usb1: SerialNumber: s3c24xx
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usbcore: registered new interface driver usbserial
usbserial: USB Serial Driver core
USB Serial support registered for pl2303
usbcore: registered new interface driver pl2303
pl2303: Prolific PL2303 USB to serial adaptor driver
mice: PS/2 mouse device common for all mice
s3c2410 TouchScreen successfully loaded
input: s3c2410 TouchScreen as /devices/virtual/input/input0
S3C24XX RTC, (c) 2004,2006 Simtec Electronics
s3c2410-rtc s3c2410-rtc: rtc disabled, re-enabling
s3c2410-rtc s3c2410-rtc: rtc core: registered s3c as rtc0
i2c /dev entries driver
s3c2440-i2c s3c2440-i2c: slave address 0x10
s3c2440-i2c s3c2440-i2c: bus frequency set to 368 KHz
s3c2440-i2c s3c2440-i2c: i2c-0: S3C I2C adapter
S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics
s3c2410-wdt s3c2410-wdt: watchdog inactive, reset disabled, irq enabled
mapped channel 0 to 0
s3c2440-sdi s3c2440-sdi: powered down.
s3c2440-sdi s3c2440-sdi: initialisation done.
s3c2440-sdi s3c2440-sdi: running at 0kHz (requested: 0kHz).
s3c2440-sdi s3c2440-sdi: running at 138kHz (requested: 138kHz).
usbcore: registered new interface driver usbhid
usbhid: v2.6:USB HID core driver
Advanced Linux Sound Architecture Driver Version 1.0.18a.
No device for DAI UDA134X
No device for DAI s3c24xx-i2s
S3C24XX_UDA134X SoC Audio driver
UDA134X SoC Audio Codec
asoc: UDA134X <-> s3c24xx-i2s mapping ok
ALSA device list:
  #0: S3C24XX_UDA134X (UDA134X)
s3c2410-rtc s3c2410-rtc: hctosys: invalid date/time
yaffs: dev is 32505859 name is "mtdblock3"
yaffs: passed flags ""
yaffs: Attempting MTD mount on 31.3, "mtdblock3"
yaffs: auto selecting yaffs2
block 879 is bad
block 880 is bad
block 2136 is bad
block 4073 is bad
block 4975 is bad
block 4976 is bad
yaffs_read_super: isCheckpointed 0
VFS: Mounted root (yaffs filesystem) on device 31:3.
Freeing init memory: 156K
Warning: unable to open an initial console.
Failed to execute /linuxrc.  Attempting defaults...
Kernel panic - not syncing: No init found.  Try passing init= option to kernel.
从你的出错信息中,busybox的init程序已经实调用了。 就看目标文件系统中有没有/dev/console    c 5 1 这是一个非常常见的问题。  详情 回复 发表于 2011-3-9 11:28
1027
现在发觉 如果没有烧文件系统 也依然出现上面的字符
应该是文件系统没有烧好吧。。。
因为搞的Uboot暂时还不支持usb下载,板子上也没有网络,uboot,内核以及文件系统等都是通过jlink烧写的,真是麻烦啊。。。
1027
uboot中 falsh分的四个区
将uboot和参数保存分开了
在内核中 分的是三个区
但是地址空间是一样的
应该没有影响吧?
2771
裸片初长成(中级)
根据我的经验,很可能是文件系统的问题,
一般是文件系统没有挂好.
不知道你用什么文件系统?
JFES2? YAFFS?还是其他?
地址空间不应该重叠.是分开的
2771
裸片初长成(中级)
这个可能问题不大
你应该是YAFFS文件系统
2771
裸片初长成(中级)
YAFFS比较特殊,一两句也说不清楚,请参考相关资料哈!
175
估计文件系统问题
这是一个非常常见的问题。
独自上路,径直潜行
1027
谢谢大家的回复
问题已解决
是因为文件系统写入的问题
在写文件系统的时候 调用的nand write的命令应该是:
nand write.yaffs
我跟写uboot和内核用的命令 nand write.jffs2一样了
所以 就出错啦、、、
赞赏
查看全部赞赏
