15160|28
2639
分享LM3S8962开发板SPI读取铁电代码 [复制链接]
前面很多网友提问LM3S的SPI不好用或者用不了,通常用GPIO模拟,经过我2天的调试,SPI完全能用,效率还不错,下面提供主要函数和代码,调试时根据布板情况先从低波特率往上加,我是从9600开始调,最高1M没有问题,再高有点不稳定因为我电路板是飞线的线有点长,后面附逻辑分析仪截图,我写的铁电型号是FM25L256
//SSI初始化
void SSIInit(void)
  SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA);//使能GPIOA
  SysCtlPeripheralEnable(SYSCTL_PERIPH_SSI0);//使能SSI
  SSIDisable(SSI0_BASE);
  GPIOPinTypeSSI(GPIO_PORTA_BASE, (GPIO_PIN_2 | GPIO_PIN_3 | GPIO_PIN_4 | GPIO_PIN_5));
  GPIODirModeSet(GPIO_PORTA_BASE, GPIO_PIN_3, GPIO_DIR_MODE_OUT);//配置片选管脚为输出
  GPIOPadConfigSet(GPIO_PORTA_BASE, GPIO_PIN_2 | GPIO_PIN_3 | GPIO_PIN_4 | GPIO_PIN_5, GPIO_STRENGTH_8MA, GPIO_PIN_TYPE_STD_WPU);
  SSIConfig(SSI0_BASE,SSI_FRF_MOTO_MODE_3, SSI_MODE_MASTER, 9600, 8);//配置SSI
  SSIEnable(SSI0_BASE);//使能SSI
//使能SPI
void SPIEnable()
    unsigned long ulTemp;
    SSIConfig(SSI0_BASE, SSI_FRF_MOTO_MODE_3, SSI_MODE_MASTER, 9600, 8);
    GPIOPinTypeSSI(GPIO_PORTA_BASE, GPIO_PIN_3);
    GPIOPadConfigSet(GPIO_PORTA_BASE, GPIO_PIN_3, GPIO_STRENGTH_8MA, GPIO_PIN_TYPE_STD_WPU);
    GPIOPinWrite(GPIO_PORTA_BASE, GPIO_PIN_3, ~GPIO_PIN_3);
    while(SSIDataGetNonBlocking(SSI0_BASE, &ulTemp) != 0)//清除FIFO
//禁止SPI
void SPIDisable()
    GPIOPinTypeGPIOOutput(GPIO_PORTA_BASE, GPIO_PIN_3);
    GPIOPinWrite(GPIO_PORTA_BASE, GPIO_PIN_3, GPIO_PIN_3);
//发送一个字节
void Send_Byte(unsigned char data)
   unsigned long NullData;
   SSIDataPut(SSI0_BASE, data);
   SSIDataGet(SSI0_BASE, &NullData);
//接收一个字节
unsigned char Get_Byte(void)
   unsigned long ReadData;
   SSIDataPut(SSI0_BASE, 0xff);//发送一个无效字节,以产生接收时钟
   SSIDataGet(SSI0_BASE, &ReadData);
   return (unsigned char)ReadData;
//----------main主函数------------------------------------
SSIInit();//初始化SPI
SPIEnable();//使能铁电
Send_Byte(0x3);//发送读命令
Send_Byte(0x0);//读取数据地址高字节
Send_Byte(0x0);//读取数据地址低字节
sfbuf[0]=Get_Byte();//读取数据
sfbuf[1]=Get_Byte();
sfbuf[2]=Get_Byte();
sfbuf[3]=Get_Byte();
SPIDisable();//禁止铁电
SysCtlDelay(100*(TheSysClock/3000));
SPIEnable();
Send_Byte(0x06);//发送写使能命令
SPIDisable();
SPIEnable();
Send_Byte(0x02);//发送字节数据烧写命令
Send_Byte(0x0);//发送2个字节的地址信息
Send_Byte(0x0);
Send_Byte(0x60);
Send_Byte(0x61);
Send_Byte(0x62);
Send_Byte(0x63);
SPIDisable();
SPIEnable();//使能铁电
SPIDisable();//禁止铁电
写铁电截图
读铁电截图
查看精华帖全部内容,请登录或者注册
新手学习了  详情 回复 发表于 2013-8-13 09:15
为什么每次DataPut之后,都要马上DataGet一下呢?这是TI的SSI模块的特殊规定么?原来我用SiLabs的单片机,就不需要这样的操作。不过既然DataGet没有进入死循环,那说明还真有数据接收了啊!  详情 回复 发表于 2012-9-28 15:58
978
你的逻辑分析仪很漂亮,介绍下??
640
专业水平
2639
就是论坛上介绍的DIY逻辑分析仪,好像98一样,很实惠,调试一下串口、SPI、I2C足够了
1412
淘宝上有卖这个逻辑分析仪
个人签名https://bbs.eeworld.com.cn/thread-471646-1-1.html
欢迎加入我的团队
2639
 很多啊
202
我确定LM3S的SPI跑铁电
能稳定跑到规格书的极限速度12.5M(50M/4)
[ 本帖最后由 mr.king 于 2010-8-30 20:55 编辑 ]
2639
高手啊,我只能稳定跑8M,再高不知道是什么原因片选时序有点异常
702
个人签名你好呀
2639
这么实用的源码没人敢兴趣吗?这可是我实际项目中的代码,下一步准备再分享一个I2C的代码:D
牛,顶!
1012
好!
1012
为什么我的只能单子节收发?不能连续?
enable信号都是发一个或收一个直接就升一次
谢谢楼主
我发现坛里最大的地主,技术也挺牛地
31
LZ是相当NB的!~
349
学习了
楼主啊,能否把全部文件发一下???
;P
4996
裸片初长成(初级)
不错,学习了。。。。。。
个人签名我的博客
我用楼主的代码,怎么SCLK没有波
强烈要求上原码????;P
这么好的资料怎么没人顶
有奖直播:当AI遇见仿真,会有什么样的电子行业革新之路?
首场直播:Simcenter AI 赋能电子行业研发创新
直播时间:04月15日14:00-14:50
