4044|5
198
初学edk,有两个问题请教。 [复制链接]
初学者,做了edk的6个实验,感觉对edk有了最初级的了解,有些问题想请教大家:
1.想打开别人的工程文件,结果总是不成功,提示错误是:
ERROR:EDK:1550 - IPNAME: microblaze, INSTANCE: microblaze_0 - E:\qiaodong\FPGA\test_edk0\sp3ekit_101\solutions\lab3\system.mhs line 42 - cannot find MPD for the pcore 'microblaze_v7_10_b' in any of the repositories.
ERROR:EDK:1550 - IPNAME: plb_v46, INSTANCE: mb_plb - E:\qiaodong\FPGA\test_edk0\sp3ekit_101\solutions\lab3\system.mhs line 56 - cannot find MPD for the pcore 'plb_v46_v1_02_a' in any of the repositories.
ERROR:EDK:1550 - IPNAME: mpmc, INSTANCE: DDR_SDRAM - E:\qiaodong\FPGA\test_edk0\sp3ekit_101\solutions\lab3\system.mhs line 130 - cannot find MPD for the pcore 'mpmc_v4_01_a' in any of the repositories.
ERROR:EDK:1550 - IPNAME: mdm, INSTANCE: debug_module - E:\qiaodong\FPGA\test_edk0\sp3ekit_101\solutions\lab3\system.mhs line 191 - cannot find MPD for the pcore 'mdm_v1_00_b' in any of the repositories.
ERROR:EDK:1552 - IPNAME:microblaze INSTANCE: microblaze_0 - E:\qiaodong\FPGA\test_edk0\sp3ekit_101\solutions\lab3\system.mhs line 42 - cannot find MPD for the pcore
ERROR:EDK:1552 - IPNAME:plb_v46 INSTANCE: mb_plb - E:\qiaodong\FPGA\test_edk0\sp3ekit_101\solutions\lab3\system.mhs line 56 - cannot find MPD for the pcore
ERROR:EDK:1552 - IPNAME:mpmc INSTANCE: DDR_SDRAM - E:\qiaodong\FPGA\test_edk0\sp3ekit_101\solutions\lab3\system.mhs line 130 - cannot find MPD for the pcore
ERROR:EDK:1552 - IPNAME:mdm INSTANCE: debug_module - E:\qiaodong\FPGA\test_edk0\sp3ekit_101\solutions\lab3\system.mhs line 191 - cannot find MPD for the pcore
INFO:EDK:397 - mpmc (DDR_SDRAM) version 4.03.a is now available, but it does not support the current architecture.
Done.
怎么解决?
2.用sdk中的debug,可以在memory中清楚的看到里面定义的变量值,但是当我想看一些外设的寄存器的时候,总是显示一堆问号。
比如说我想看GPIO的寄存器,在mhs中找到它的bassaddr  = 0x81420000,但是当我在memory中找到这个地址的时候,显示的是一堆问号。
这是什么原因?能解决么?(如果可以的话,edk的软件调试就像单片机一样方便,基本上用不到chipscope了)
请各位不吝赐教!
此帖出自FPGA/CPLD论坛
这个问题在于,本人不太会答,研究中.  详情 回复 发表于 2010-8-25 11:26
265
找找MPD吧,看库里有没有?
此帖出自FPGA/CPLD论坛
103
1、使用的ISE版本不一样,建议重新做实验
2、内存数值观察应该是你的操作有问题,你重新试一下
此帖出自FPGA/CPLD论坛
198
谢谢ls的回答,但我还是不明白。
1.现在的工程都讲究可移植性,如果软件版本不同就要重新搭建硬件,这岂不是一个大缺陷啊?软件升级后以前的工程就都不能用了?
2.我能用debug中的memory可以看到我在main函数中定义的变量,例如我在main中定义了count,我memory中找&count,就可以看到count的值,
但但是当我想看GPIO的寄存器时,我在mhs中找到它的bassaddr  = 0x81420000,但是当我在memory中找到这个地址的时候,显示的是一堆问号。
这是什么原因?
此帖出自FPGA/CPLD论坛
198
各位高人给点意见啊!
此帖出自FPGA/CPLD论坛
370
EDK用的不多
这个问题在于,本人不太会答,研究中.
此帖出自FPGA/CPLD论坛
