3398|1
6892
分享SDRAM到DMA 的程序代码 [复制链接]
**********实现sdram到flash的数据传输******************/
#include <stdio.h>
#include <stdlib.h>
#include <sys/alt_dma.h>
#include "system.h"
static volatile int rx_done = 0;
alt_u8 i;
int rc;
alt_dma_txchan txchan;
alt_dma_rxchan rxchan;
void* tx_data = (void*) 0x02002000; /* 源地址,0x02002000是sdram的某一起始地址 */
void* rx_buffer = (void*) 0x04402000; /* 目标地址,0x04010000为flash的某一起始地址*/
//DMA传输结束回调函数
static void done_t(void* handle, void* data)//done_t()是DMA完成后被调用的回调函数
   rx_done++;
int main (int argc, char* argv[], char* envp[])
    alt_u8 *p=tx_data;
    alt_u8 *q=rx_buffer;
    printf("Welcome!\n");
    for(i=0;i<128;i++)
         *p++=i;
    printf ("1\n");
/* 打开发送通道 */
  if (!(txchan = alt_dma_txchan_open("/dev/DMA")))
    printf ("Failed to open transmit channel\n");
    exit (1);
/* 打开接收通道 */
  if (!(rxchan = alt_dma_rxchan_open("/dev/DMA")))
    printf ("Failed to open receive channel\n");
    exit (1);
/* 开始发送数据 */
  if ((rc = alt_dma_txchan_send (txchan,  //选用transport通道
                                 tx_data,  //a pointer to the start of the data to send.
                                 128,       //the length of the data to send in bytes.
                                 NULL,
                                 NULL)) < 0)
    printf ("Failed to post transmit request, reason = %i\n", rc);
    exit (1);
/* 开始接收数据*/
  if ((rc = alt_dma_rxchan_prepare (rxchan,   //选中recieve通道
                                    rx_buffer,//目标地址
                                    128,    //the maximum length of the data to receive
                                    done_t,  //done_t()是DMA完成后被调用的回调函数
                                    NULL)) < 0)
    printf ("Failed to post read request, reason = %i\n", rc);
    exit (1);
/* 等待传输结束 ,即等待rx_done的值变为1,等待回调函数的执行*/
   printf ("2\n");
  while (!rx_done);
  printf ("Transfer successful!\n");
     printf ("3\n");
    p=tx_data;
    q=rx_buffer;
      for(i=0;i<128;i++)
         printf(" flash%x=%x\n", *q++);
         printf(" sdram%x=%x\n", *p++);
  return 0;
此帖出自FPGA/CPLD论坛
DDDD:D :D  详情 回复 发表于 2014-9-14 17:39
个人签名一个为理想不懈前进的人,一个永不言败人!
欢迎光临网上店铺!
DDDD:D :D
此帖出自FPGA/CPLD论坛
