3747|1
6892
分享我CRC校验的源代码给大家 [复制链接]
--版权所有:www.eeleader.com------------------------------------------------------------
--设计日期:2010.3.4--------------------------------------------------------------------------------
--设计人  :eeleader------------------------------------------------------------------------------------
--文件名  : Crc_Gen.vhd-------------------------------------------------------------------------
--顶层模块:Crc_Gen.Vhd--------------------------------------------------------------------------------
--模块名称:Crc_Gen-----------------------------------------------------------------------------
--模块功能:对输入的数据进行CRC校验,校验等式X15+X13+1--------------------------------------------------
--模块说明:输入数据有效,通过Data_En 高脉冲(宽度一个系统时钟脉冲);输出数据,通过Crc_Rdy高脉冲(宽度一个系统时钟脉冲)
--          参数说明:D_Width表示输入数据的位数,Byte_Num:表示输入数据的字节数
--修改记录:无
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_ARITH.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTITY Crc_Gen IS
 GENERIC (D_Width: POSITIVE:=8;Byte_Num:POSITIVE:=8;Module_En:STRING:="Enable");
 PORT
            Clk  : IN STD_LOGIC;
            Rst  : IN STD_LOGIC;
            Data_In: IN STD_LOGIC_VECTOR (D_Width-1 DOWNTO 0);
            Data_En: IN STD_LOGIC;
            Crc_Out: OUT STD_LOGIC_VECTOR(15 DOWNTO 0);
            Crc_Rdy: OUT STD_LOGIC
END Crc_Gen;
ARCHITECTURE Arch_Crc_Gen OF Crc_Gen IS
TYPE   Comp_Crc_State_Type IS (Idle,Crc_Comp,Shift);
SIGNAL Comp_Crc_State: Comp_Crc_State_Type;
SIGNAL Comp_Crc_Data_In_Reg :STD_LOGIC_VECTOR (D_Width-1 DOWNTO 0);
BEGIN
Crc_Gen:IF (Module_En="Enable")GENERATE
Comp_Crc: PROCESS (Clk,Rst)
VARIABLE  Comp_Crc_Result:STD_LOGIC_VECTOR(15 DOWNTO 0);
VARIABLE  Comp_Crc_Data_Reg:STD_LOGIC_VECTOR(7 DOWNTO 0);
VARIABLE  Comp_Crc_Flag:STD_LOGIC;
VARIABLE  Comp_Crc_Cnt: INTEGER RANGE 0 TO Byte_Num;
BEGIN
 IF(Rst='1') THEN
    Crc_Out<=(OTHERS=>'0') ;
    Crc_Rdy<='0';
    Comp_Crc_Data_In_Reg<=(OTHERS=>'0');
    Comp_Crc_Result:=(OTHERS=>'1');
    Comp_Crc_Data_Reg:=(OTHERS=>'1');
    Comp_Crc_Flag:='0';
    Comp_Crc_Cnt:=Byte_Num;
    Comp_Crc_State<=Idle;
 ELSIF Clk'EVENT AND Clk='1' THEN
       CASE  Comp_Crc_State  IS
   WHEN Idle=>
       Crc_Rdy<='0';
       IF (Data_En='1') THEN
           Comp_Crc_State<=Crc_Comp;
           Comp_Crc_Data_In_Reg<=Data_In;
       END IF;
   WHEN Crc_Comp=>
       Comp_Crc_Data_Reg:=Comp_Crc_Data_In_Reg(7 DOWNTO 0);
       Comp_Crc_Result:=Comp_Crc_Result XOR Comp_Crc_Data_Reg(7 DOWNTO 0);
       FOR  i IN 0 TO 7 LOOP
       Comp_Crc_Flag:=Comp_Crc_Result(0);
       Comp_Crc_Result:='0'& Comp_Crc_Result(15 DOWNTO 1);
       IF  (Comp_Crc_Flag='1') THEN
       Comp_Crc_Result:=Comp_Crc_Result XOR x"a001";
       END IF;
       END LOOP;
       Comp_Crc_Cnt:=Comp_Crc_Cnt-1;
       Comp_Crc_State<=Shift;
   WHEN Shift=>
       IF (Comp_Crc_Cnt=0) THEN
           Crc_Rdy<='1';
           Crc_Out<=Comp_Crc_Result;
       ELSE
           Comp_Crc_Data_In_Reg<=X"00" & Comp_Crc_Data_In_Reg(D_Width-1 DOWNTO 8);
       END IF;
   WHEN OTHERS=>
           Crc_Rdy<='0';
   END CASE;
END IF;
END PROCESS Comp_Crc;
END GENERATE Crc_Gen;
END Arch_Crc_Gen;
此帖出自FPGA/CPLD论坛
您好,求教一下CRC的编码,您的CRC_GEN在对8bit数据进行校验时,是正确的,但是对40bit,也就是多字节数据校验是错误的,不知道为什么,您能不能帮忙调一下   详情 回复 发表于 2016-8-16 16:58
个人签名一个为理想不懈前进的人,一个永不言败人!
欢迎光临网上店铺!
此帖出自FPGA/CPLD论坛
