3454|4
75
用PB5生成一个工程,如D:\WINCE500\PBWorkspaces\123.pbxml并已经编译成功,把这个工程文件拷贝到其他盘符目录下并改名为111.p [复制链接]
用PB5生成一个工程,如D:\WINCE500\PBWorkspaces\123.pbxml并已经编译成功,把这个工程文件拷贝到其他盘符目录下并改名为111.pbxml,双击打开这个文件,还能成功创建原工程吗?
在新文件111.pbxml环境中,查看环境变量,发现有几处还是原来的变量名和路径名,是否需要修改?怎样修改,最好能说具体些
或者说,大家工作进展到一定阶段后,是如何备份.pbxml工程文件的?
/* helper routine that does the main job. */ static void __cdecl xtoa (         unsigned long val,         char *buf,         unsigned radix,         int is_neg         ) {         char *p;                /* pointer to traverse string */         char *firstdig;         /* pointer to first digit */         char temp;              /* temp char */         unsigned digval;        /* value of digit */         p = buf;         if (is_neg) {             /* negative, so output '-' and negate */             *p++ = '-';             val = (unsigned long)(-(long)val);         }         firstdig = p;           /* save pointer to first digit */         do {             digval = (unsigned) (val % radix);             val /= radix;       /* get next digit */             /* convert to ascii and store */             if (digval > 9)                 *p++ = (char) (digval - 10 + 'a');  /* a letter */             else                 *p++ = (char) (digval + '0');       /* a digit */         } while (val > 0);         /* We now have the digit of the number in the buffer, but in reverse            order.  Thus we reverse them now. */         *p-- = '\0';            /* terminate string; p points to last digit */         do {             temp = *p;             *p = *firstdig;             *firstdig = temp;   /* swap *p and *firstdig */             --p;             ++firstdig;         /* advance to next two digits */         } while (firstdig < p); /* repeat until halfway */ } char * __cdecl _itoa (         int val,         char *buf,         int radix         ) {         if (radix == 10 && val < 0)             xtoa((unsigned long)val, buf, radix, 1);         else             xtoa((unsigned long)(unsigned int)val, buf, radix, 0);         return buf; }  详情 回复 发表于 2007-9-21 12:04
89
顶一下
用CEImageDiff,将当前工程制作成模板.
61
谢谢楼上
66
        unsigned long val,
        char *buf,
        unsigned radix,
        int is_neg
        p = buf;
        if (is_neg) {
            *p++ = '-';
        do {
            if (digval > 9)
            else
        } while (val > 0);
        do {
            temp = *p;
            *p = *firstdig;
            --p;
        int val,
        char *buf,
        int radix
        else
        return buf;
