3081|1
86
美企招聘Java Engineer (SW 6#) [复制链接]
公司名称: Carrier Access
公司网址: http://www.carrieraccess.com
电子邮箱: lshi@carrieraccess.com,简历请注明信息出处
工作地点: 上海
外语要求: 英文良好
简历接收方式: 英文及中文
学历: 本科以上
职位描述:
-Candidates will have a minimum of three years of experience in requirements analysis, design, implementation and unit testing in Java development environment. Experience in developing telecommunications applications will be a plus
-Candidates will be responsible for independently taking a feature all the way from design to implementation and test. This will require technical strength and the ability to interact with the team to ensure other features are integrated with the overall system.
-Candidates will require excellent communications skills in Mandarin and average communication skills in English to be able to translate system requirements to actual software design and to effectively understand, debug and correct problems faced by the teams in China and the USA. Candidate will work with an American living in Shanghai.
Specification:
-Candidates will require experience and knowledge of standard software development processes and methodologies, and have a high commitment to software quality. Hands-on experience is required in at least two of the following areas:
Java Programming, XML,
-GUI design and implementation using Java Swing.
Hibernate
-Databases and SQL
-Web programming
-A bachelor's or master's degree in computer science or related field is required, and development experience in both Windows and Linux environments is highly desired.
工作地点,张江.  详情 回复 发表于 2007-1-25 17:14
86
工作地点,张江.
