3129|2
SfGetObjectName这个方法在哪个偷文件下? [复制链接]
如题目.我照别人写的驱动程序搬都出错,请问谁知道SfGetObjectName()这个方法在哪个头文件下
这个函数是SFilter.c中自带的,你可以搜索一下,它的实现部分如下: VOID SfGetObjectName (     IN PVOID Object,     IN OUT PUNICODE_STRING Name     ) /*++ Routine Description:     This routine will return the name of the given object.     If a name can not be found an empty string will be returned. Arguments:     Object - The object whose name we want     Name - A unicode string that is already initialized with a buffer that            receives the name of the object. Return Value:     None --*/ {     NTSTATUS status;     CHAR nibuf[512];        //buffer that receives NAME information and name     POBJECT_NAME_INFORMATION nameInfo = (POBJECT_NAME_INFORMATION)nibuf;     ULONG retLength;     status = ObQueryNameString( Object, nameInfo, sizeof(nibuf), &retLength);     Name->Length = 0;     if (NT_SUCCESS( status )) {         RtlCopyUnicodeString( Name, &nameInfo->Name );     } }  详情 回复 发表于 2007-7-17 10:51
66
自己顶下
79
VOID
SfGetObjectName (
    IN PVOID Object,
Arguments:
Return Value:
    None
    NTSTATUS status;
    ULONG retLength;
    Name->Length = 0;
