2966|3
求组!~~~ [复制链接]
   HELLOWIN.C -- Displays "Hello, Windows 98!" in client area
                 (c) Charles Petzold, 1998
#include
LRESULT CALLBACK WndProc (HWND, UINT, WPARAM, LPARAM) ;
int WINAPI WinMain (HINSTANCE hInstance, HINSTANCE hPrevInstance,
                    PSTR szCmdLine, int iCmdShow)
     static TCHAR szAppName[] = TEXT ("HelloWin") ;
     HWND         hwnd ;
     MSG          msg ;
     WNDCLASS     wndclass ;
     wndclass.style         = CS_HREDRAW | CS_VREDRAW ;
     wndclass.lpfnWndProc   = WndProc ;
     wndclass.cbClsExtra    = 0 ;
     wndclass.cbWndExtra    = 0 ;
     wndclass.hInstance     = hInstance ;
     wndclass.hIcon         = LoadIcon (NULL, IDI_APPLICATION) ;
     wndclass.hCursor       = LoadCursor (NULL, IDC_ARROW) ;
     wndclass.hbrBackground = (HBRUSH) GetStockObject (WHITE_BRUSH) ;
     wndclass.lpszMenuName  = NULL ;
     wndclass.lpszClassName = szAppName ;
     if (!RegisterClass (&wndclass))
          MessageBox (NULL, TEXT ("This program requires Windows NT!"),
                      szAppName, MB_ICONERROR) ;
          return 0 ;
     hwnd = CreateWindow (szAppName,                  // window class name
                          TEXT ("The Hello Program"), // window caption
                          WS_OVERLAPPEDWINDOW,        // window style
                          CW_USEDEFAULT,              // initial x position
                          CW_USEDEFAULT,              // initial y position
                          CW_USEDEFAULT,              // initial x size
                          CW_USEDEFAULT,              // initial y size
                          NULL,                       // parent window handle
                          NULL,                       // window menu handle
                          hInstance,                  // program instance handle
                          NULL) ;                     // creation parameters
     ShowWindow (hwnd, iCmdShow) ;
     UpdateWindow (hwnd) ;
     while (GetMessage (&msg, NULL, 0, 0))
          TranslateMessage (&msg) ;
          DispatchMessage (&msg) ;
     return msg.wParam ;
LRESULT CALLBACK WndProc (HWND hwnd, UINT message, WPARAM wParam, LPARAM lParam)
     HDC         hdc ;
     PAINTSTRUCT ps ;
     RECT        rect ;
     switch (message)
     case WM_CREATE:
          PlaySound (TEXT ("hellowin.wav"), NULL, SND_FILENAME | SND_ASYNC) ;
          return 0 ;
     case WM_PAINT:
          hdc = BeginPaint (hwnd, &ps) ;
          GetClientRect (hwnd, &rect) ;
          DrawText (hdc, TEXT ("Hello, Windows 98!"), -1, &rect,
                    DT_SINGLELINE | DT_CENTER | DT_VCENTER) ;
          EndPaint (hwnd, &ps) ;
          return 0 ;
     case WM_DESTROY:
          PostQuitMessage (0) ;
          return 0 ;
     return DefWindowProc (hwnd, message, wParam, lParam) ;
运行的出错,提示如下,麻烦帮忙改下,成功了马结贴!~~
d:\MyProjects\chp1\HelloMsg\HelloMsg.c(56): warning C4244: “return” : 从“WPARAM”转换到“int”,可能丢失数据
HelloMsg error LNK2019: 无法解析的外部符号 __imp__PlaySoundA@12 ,该符号在函数 _WndProc@16 中被引用
HelloMsg fatal error LNK1120: 1 个无法解析的外部命令
增加库,Winmm.lib   详情 回复 发表于 2007-7-14 11:17
return msg.wParam出于什么考虑?
找不到__imp__PlaySoundA 相关的库,
Use Winmm.lib
Alt + F7,在 Link里添加 Winmm.lib
增加库,Winmm.lib
