8257|34
GPRS编程 [复制链接]
最近要做一个在LINUX平台下用ARM开发板开发一个GPRS数据传输的题目,以前没有接触过GPRS之类的东西,
特像各位大侠要点关于GPRS编程的材料,有实例更好
我QQ:380953301
Email:380953301@qq.com
怎么我标记一下,版主都说我在恶意灌水?!我标记是为了自己将来好找。  详情 回复 发表于 2008-12-6 08:56
给你传一个GPRS的软件包吧!发到你的邮箱了!
77
谢谢
1楼的大哥 能不能给我也传一个
我的邮箱ljw111111@163.com
多谢了
81
1楼大哥,能不能也给我一份
我的邮箱WJL5766@163.COM
谢谢了
59
我也想要一份,能发到我邮箱吗  vitoreyu@163.com
多谢了
75
呵呵,一楼的,GPRS软件包?
你连楼主用的是什么模块都不问,就直接说给他GPRS软件包?
而且,你的GPRS软件包是什么东西?
不好意思,我还没听说过哦。
佩服。。。
58
General Information
This is GPRS 0.0.0.
GPRS is the application for GPRS connection/disconnection.
Dependency                  Available from
Installation
See the file 'INSTALL'
How to report bugs
Patches
Simple install procedure
  % tar zxvf GPRS.tar.gz  # unpack the sources
  % cd GPRS                 # change to the toplevel directory
1. Compile cms92init
$ cd cms92init
$ make
cms92init is used to init the Multiplexer function, it should be run before the gsmmux and phoneserver
usage:
$ ./cms92init
2. Compile gsmmux
First download the gsmmux-alpha-2.tar.gz package from
http://prdownload.berlios.de/gsmmux/gsmmux-alpha-2.tar.gz
Then unzip the package,
tar zxvf gsmmux-alpha-2.tar.gz
Apply the patch:
Attention:
The reason of adding patch:
1). Cellon device uses non-standard frame size
2). Special AT commands used for CMS92-M Modem, such as AT+PPMUX instead of AT+CMUX
3). other reasons refer to the patch file
So, this patch is suitable for those who use the CMS92-M modem.
If other types of modem is used, patch is not necessary.
$ cd gsmmux-alpha-2
($ patch -p1 < ./gsmmux-alpha-2-cellon-lf.patch)(depends)
$ export PATH=/usr/local/arm-linux/bin:$PATH
$ make
gsmmux is used for multiplexer, after running, there will be a usable multiplexed control channel at /dev/pts/0 and
a data channel at /dev/pts/1
usage:
$ ./gsmMuxd -d -p /dev/ttyS0 -m cms92 -f 128 -b 115200 -c /dev/ptmx /dev/ptmx &
3. Compile connect
$ cd connect
$ make
connect is used for connect to GPRS
disconnect is used for disconnect from GPRS
usage:
$ ./connect
$ ./disconnect
4. put everything to the 8090
5. Create a new ppp configuration file at /etc/ppp/peers/gprsmux, containing
the following:
novj
novjccomp
noaccomp
nopcomp
/dev/pts/1
115200
-detach
defaultroute
usepeerdns
lcp-echo-failure 10
lcp-echo-interval 60
crtscts
6. On the device , run cms92init, gsmMuxd, phoneserver in order
7. When necessary, run connect/disconnect to connect to/disconnect from GPRS.
77
网泥,我给的是在前一段时间,我们在linux下面是用ppp的时候,在网上收索到的一个软件包。不知道这样说是不是有歧义×……呵呵!
66
yinjinzhong大哥,如果我是用vb的,有没有类似的编程或实例可以分享给我呢?
电邮:nigege20@yahoo.com
先谢过你了。
79
我也正在学习中,能给我发一份吗?小弟不胜感激
isshf@126.com
86
上面的这个软件包在网上人搜索到的!
什么软件包???
79
我也要:gci8thlzs@tom.com
也给我一份吧.谢谢了.mlrfid@163.com
61
放到什么地方共享一下吧,我也想要一个
63
给我一份吧 tcf.c@163.com
谢谢!!!
86
我也要一份吧
abc_321c@126.com
65
麻烦给我也传一份吧!
82
邮箱:mouse_live@126.com
