3098|4
65
使用ScrollWindowEx时出现比较明显的拖滞现象,怎么处理。 [复制链接]
在拖动滚动条时,页面出现了拖影,应该怎么处理呀,
看系统内即使文件很多也没有这现象呢。?
void C2MSetting::OnVScroll(UINT nSBCode, UINT nPos, CScrollBar* pScrollBar)
        int nDelta = 0;
        int nMaxPos = m_rcOriginalRect.Height() - m_nCurHeight;
        switch (nSBCode)
        case SB_LINEDOWN:
                if (m_nScrollPos >= nMaxPos)
                        return;
                nDelta = min(max(nMaxPos/20,5),nMaxPos-m_nScrollPos);
                break;
        case SB_LINEUP:
                if (m_nScrollPos <= 0)
                        return;
                nDelta = -min(max(nMaxPos/20,5),m_nScrollPos);
                break;
        case SB_PAGEDOWN:
                        return;
                nDelta = min(max(nMaxPos/10,5),nMaxPos-m_nScrollPos);
                break;
        case SB_THUMBTRACK:
        case SB_THUMBPOSITION:
                nDelta = (int)nPos - m_nScrollPos;
                break;
        case SB_PAGEUP:
                        return;
                nDelta = -min(max(nMaxPos/10,5),m_nScrollPos);
                break;
        case 8:
                m_nScrollPos += nDelta;
                break;
     default:
                return;
        SetScrollPos(SB_VERT,m_nScrollPos,TRUE);
        ScrollWindowEx(0,-nDelta,NULL,NULL,NULL,NULL,SW_SCROLLCHILDREN);
        CDialog::OnVScroll(nSBCode, nPos, pScrollBar);
详情 回复 发表于 2007-7-14 10:14
64
我想顶一下。
83
o
没听懂楼主的意思,什么拖影呢?
