3065|2
86
W77E58+RTL8019,不能对RTL8019的IMR和PAR0~PAR5不能操作 [复制链接]
对RTL8019初始化时,代码如下:
unsigned char xdata chRTLInitTmp;
        unsigned int i;
                //在RSTDRV从高电平回到低电平之后的100MS时,在对RTL8019做读写操作,以确保完全复位
        P35 = 1;
        for(i = 0;i < 400;i++);
        P35 = 0;
        for(i = 0;i < 4000;i++);
        /* reset: write to reset prot */
        WriteReg(0x18,0xaa);
        chRTLInitTmp = ReadReg(0x18);
        for(i = 0;i < 20;i++);
        /* init RTL registers*/
        WriteReg(0x00,0x21);
        chRTLInitTmp = 0x00;
        chRTLInitTmp = ReadReg(0x00);
        RTLPage(0);
        WriteReg(0x0a,0x00);    //清RBCR0
        WriteReg(0x0b,0x00);    //清RBCR1
        WriteReg(0x0c,0xe0);    //RCR,监视模式,不接收数据报
        WriteReg(0x0d,0xe2);    //TCR,loopback模式
         WriteReg(0x01,        0x4c);        /* Pstart        */
        WriteReg(0x02,        0x80);        /* Pstop        */
        WriteReg(0x03,        0x4c);        /* BNRY                */
        WriteReg(0x04,        0x40);        /* TPSR                */
        WriteReg(0x07,0xFF);        /* ISR: Interrupt Status Register,write FF to clear up all interrupt status */
        //WriteReg(0x0f,0x00);        /* IMR: Interrupt Mask Register,屏蔽掉所有中断 */
        WriteReg(0x0e,0xC8);        /* DCR: Data Configuration Register*/
        WriteReg(0x0c,0xCE);        /* RCR*/
        WriteReg(0x0d,0xE0);        /* TCR*/
        //To debug
        chRTLInitTmp = ReadReg(0x07);
        chRTLInitTmp = ReadReg(0x0f);
        RTLPage(1);
        WriteReg(0x07,0x4d); //CURR,设置为指向当前正在写的页的下一页
        /* MAR0 */
        WriteReg(0x08,0x00);
        WriteReg(0x09,0x41);
        WriteReg(0x0b,0x80);
        WriteReg(0x0c,0x00);
        WriteReg(0x0d,0x00);
        WriteReg(0x0e,0x00);
        /* set phisical address */
        RTLPage(1);
        WriteReg(1,0x00);
        WriteReg(2,0xe0);
        WriteReg(3,0x19);
        WriteReg(4,0x21);
        WriteReg(5,0x68);
        WriteReg(6,0x12);
        for(i = 0;i < 200;i++);
        //To debug
        chRTLInitTmp = ReadReg(0x08);
        chRTLInitTmp = ReadReg(0x09);
        chRTLInitTmp = ReadReg(0x0a);
        chRTLInitTmp = ReadReg(0x0b);
        chRTLInitTmp = ReadReg(0x0c);
        chRTLInitTmp = ReadReg(0x0d);
        chRTLInitTmp = ReadReg(0x0e);
        //chRTLInitTmp = ReadReg(0x0f);
        chRTLInitTmp = ReadReg(0x01);
        chRTLInitTmp = ReadReg(0x02);
        chRTLInitTmp = ReadReg(0x03);
        chRTLInitTmp = ReadReg(0x04);
        chRTLInitTmp = ReadReg(0x05);
        chRTLInitTmp = ReadReg(0x06);
        /* transimit start page */
        LastSendStartPage = SEND_START_PAGE0;
        StartPageOfPacket = RECEIVE_START_PAGE + 1;
        /* in the beginning, no packet is in sending */
        InSending = FALSE;
        RTLPage(0);
        /* initial over, start command and receive */
        WriteReg(0x0c,0xcc);                //将芯片置于正常模式,跟外部网络连接
        WriteReg(0x0d,0xe0);
        chRTLInitTmp = ReadReg(0x07);       //清除所有中断标志位
        WriteReg(0x00,0x22);
这里有成品板, 不知楼主是否有兴趣: http://auction1.taobao.com/auction/0/item_detail-0db2-638d11334228daa23cda5f3d85cb4d8b.jhtml?from_shop=true  详情 回复 发表于 2007-7-15 21:05
75
问题在于:当对复位寄存器0x18~0x1f、配置寄存器0x00及其他都操作正常,写进去的数与读出的数相等。但是对IMR(中断屏蔽寄存器)和PAR0~PAR5(物理地址寄存器)不能正常操作。
IMR的问题:执行WriteReg(0x0f,0x00);语句时,直接停止,不向下运行了,但是如果跟到函数里确实正常的,很莫名其妙。
PAR0~PAR5的问题:
执行
         RTLPage(1);
        WriteReg(1,0x00);
        WriteReg(2,0xe0);
        WriteReg(3,0x19);
        WriteReg(4,0x21);
        WriteReg(5,0x68);
        WriteReg(6,0x12);
再执行
读出的数根本不是写进去的值。
不知哪里出来问题,向各位高手求助!
这里有成品板,
不知楼主是否有兴趣:
