3344|8
bmp位图文件程序 [复制链接]
#include
#include
#include
#include
#include
#ifndef _LOADBMP_H_
#define _LOADBMP_H_
typedef unsigned char    BYTE;
typedef unsigned short    WORD;
typedef unsigned long    DWORD;
typedef struct tagBITMAPFILEHEADER {
            WORD bfType;
            DWORD bfSize;
            WORD bfReserved1;
            WORD bfReserved2;
            DWORD bfOffBits;
} BITMAPFILEHEADER;
typedef struct tagBITMAPINFOHEADER{
           DWORD biSize;
           LONG biWidth;
           LONG biHeight;
           WORD biPlanes;
           WORD biBitCount
           DWORD biCompression;
           DWORD biSizeImage;
           LONG biXPelsPerMeter;
           LONG biYPelsPerMeter;
           DWORD biClrUsed;
           DWORD biClrImportant;
} BITMAPINFOHEADER;
typedef struct tagRGBTRIPLE {
          BYTE rgbtBlue;
          BYTE rgbtGreen;
          BYTE rgbtRed;
} RGBTRIPLE;
void main()
   BITMAPFILEHEADER bf;
   bf.bfType=0*4d42;
   bf.bfSize=size+sizeof(BMPFILEHEADER)+sizeof(BMPINFOHEADER);
   bf.bfReserved1=0;
   bf.bfReserved2=0;
   bf.bfOffBits=bf.bfSize-size;
   BITMAPINFOHEADER bi;
   bi.biSize=sizeof(BMPINFOHEADER);
   bi.biWidth=width;
   bi.biHeight=height;
   bi.biPlanes=1;
   bi.biBitCount=4;
   bi.biCompression=BI_RLE4;
   bi.biSizeImage=size;
   bi.biXPelsPerMeter=0;
   bi.biYPelsPerMeter=0;
   bi.biClrUsed=0;
   bi.biClrImportant=0;
写一个bmp位图文件要求:纯黑色(单色),压缩;
用的是c语言写的
各位高手指点迷津,谢谢
这个程序怎么运行有错误呢,
怎么把一个单色(只有黑,白色)bmp图象压缩  详情 回复 发表于 2008-8-4 11:24
77
什么错误呢?
#include "stdio.h"
#include "stdlib.h"
#include "string.h"
typedef long BOOL;
typedef long LONG;
typedef struct {
        WORD    bfType;
        DWORD   bfSize;
        WORD    bfReserved1;
        WORD    bfReserved2;
        DWORD   bfOffBits;
} BMPFILEHEADER_T;
struct BMPFILEHEADER_S{
        WORD    bfType;
        DWORD   bfSize;
        WORD    bfReserved1;
        WORD    bfReserved2;
        DWORD   bfOffBits;
typedef struct{
        DWORD      biSize;
        LONG       biWidth;
        LONG       biHeight;
        WORD       biPlanes;
        WORD       biBitCount;
        DWORD      biSizeImage;
        DWORD      biClrUsed;
} BMPINFOHEADER_T;
void Snapshot( int width, int height,  char * filename )
       int size = width*height*3;
       BMPFILEHEADER_T bfh;
       bfh.bfType = 0X4d42;
       bfh.bfSize = size +
                   sizeof(BMPFILEHEADER_T) +
                   sizeof(BMPINFOHEADER_T);
       bfh.bfReserved1 = 0;
       bfh.bfReserved2 = 0;
       bfh.bfOffBits = bfh.bfSize - size;
       BMPINFOHEADER_T bih;
       bih.biSize = sizeof(BMPINFOHEADER_T);
       bih.biWidth = width;
       bih.biHeight = height;
       bih.biPlanes = 1;
       bih.biBitCount = 1;
       bih.biCompression = 1;
       bih.biSizeImage = size;
       bih.biXPelsPerMeter = 0;
       bih.biYPelsPerMeter = 0;
       bih.biClrUsed = 0;
       bih.biClrImportant = 0;
       FILE * fp = fopen( filename,"wb" );
       if( !fp ) return;
       fwrite( &bfh, 1, sizeof(BMPFILEHEADER_T), fp );
       fwrite( &bih, 1, sizeof(BMPINFOHEADER_T), fp );
       fclose( fp );
void main()
       Snapshot(320,240, "c:\\rgb.bmp" );
这个程序是用c++写的,但是用c语言就有很多错误!
现在上面这个程序运行都没有毛病,就是 "c:\\rgb.bmp" 里的图片没有内容
79
你可以用hex的方式打开你的bmp文件,看看到底有没有写入内容。
你写入了bmp的文件头,内容呢也就是你的点阵?
没有bmp内容,你肯定看不到图片的。
确实,只写了头信息
63
#include "stdio.h"
#include "stdlib.h"
#include "string.h"
typedef long BOOL;
typedef long LONG;
#include
typedef struct {
        WORD    bfType;
        DWORD  bfSize;
        WORD    bfReserved1;
        WORD    bfReserved2;
        DWORD  bfOffBits;
} BMPFILEHEADER_T;
        WORD    bfType;
        DWORD  bfSize;
        WORD    bfReserved1;
        WORD    bfReserved2;
        DWORD  bfOffBits;
typedef struct{
        DWORD      biSize;
        LONG      biWidth;
        LONG      biHeight;
        WORD      biPlanes;
        WORD      biBitCount;
        DWORD      biSizeImage;
        DWORD      biClrUsed;
} BMPINFOHEADER_T;
void Snapshot( BYTE * pData, int width, int height,  char * filename )
      bfh.bfType = 0x4d42;
      bfh.bfSize = size  // data size
              + sizeof( BMPFILEHEADER_T ) // first section size
              + sizeof( BMPINFOHEADER_T ) // second section size
      bfh.bfReserved1 = 0; // reserved
      bfh.bfReserved2 = 0; // reserved
      // 位图第二部分,数据信息
      bih.biPlanes = 1;
      bih.biBitCount =1;
      bih.biCompression = 0;
      bih.biClrUsed = 0;
      FILE * fp = fopen( filename,"wb");
      if( !fp ) return;
      fwrite( pData, 1, size, fp );
      fclose( fp );
void main()
int pRGB[240][320]={{0000,0x00},{0xff,0000},{0000,0000,0000,0x00,0xff},{0xff,0xff,0x00}};
      Snapshot( ( BYTE*)pRGB, 320, 240, "C:\\rgb.bmp" );
这个程序出来了,可是现在main()里的数组初始化不知道怎么写了,最后的要求是,在黑色上有白点
晕,
你找个bmp图片,用hex方式(ultraedit)打开看一下怎么组织的吧。
84
BMP文件是格式,LZ清楚吗?
很久以前做过,现在只记得BMP文件的数据,是从最下面一行开始存贮,而不是BMP文件的第一行。且在数据组织方面,有一定的处理,如一行必须是8的倍数,不够补零等。
LZ在网上这相关的文章看看吧。
94
