4497|8
66
EVC4.0实现不规则窗口 [复制链接]
各位英雄:
我把VC下实现不规则窗口的代码移植到EVC4.0下,可是确看不到效果,对话框显示不出来!主要的函数如下:
void CBitmapDialog :: MakeWindowRgn ()
        if (!m_bTransparent)            //窗口不透明
                // Set the window region to the full window
                CRect rc;
                GetWindowRect (rc);
                CRgn rgn;
                rgn.CreateRectRgn (0, 0, rc.Width(), rc.Height());
                SetWindowRgn (rgn, TRUE);
        else                             //根据位图定制窗口形状
                // Set the region to the window rect minus the client rect
                CRect rcWnd;
                GetWindowRect (rcWnd);
                CRgn rgn;
                rgn.CreateRectRgn (rcWnd.left, rcWnd.top, rcWnd.right, rcWnd.bottom);
                CRect rcClient;
                GetClientRect (rcClient);
                ClientToScreen (rcClient);
                CRgn rgnClient;
                rgnClient.CreateRectRgn (rcClient.left, rcClient.top, rcClient.right,
                        rcClient.bottom);
                // Subtract rgnClient from rgn
                rgn.CombineRgn (&rgn, &rgnClient, RGN_XOR);
                // Get a DC for the bitmap
                CDC dcImage;
                dcImage.CreateCompatibleDC (NULL);
                CBitmap *pOldBitmap = dcImage.SelectObject (m_bmBitmap);          //根据位图形状来定制对话框形状
                // Get the bitmap for width and height information
                BITMAP bm;
                m_bmBitmap->GetBitmap (&bm);
                // Get window width and height
                CRect rc;
                GetClientRect (rc);
                // Use the minimum width and height
                int width = min (bm.bmWidth, rc.Width());
                int height = min (bm.bmHeight, rc.Height());
                // Use RLE (run-length) style because it goes faster.
                // Row start is where the first opaque pixel is found.  Once
                // a transparent pixel is found, a line region is created.
                // Then row_start becomes the next opaque pixel.
                int row_start;
                // Go through all rows
                for (int y=0; y                 {
                        // Start looking at the beginning
                        row_start = 0;
                        // Go through all columns
                        for (int x=0; x                         {
                                // If this pixel is transparent
                                if (dcImage.GetPixel(x, y) == m_colTrans)                  //透明底色
                                        // If we haven't found an opaque pixel yet, keep searching
                                        if (row_start == x) row_start ++;
                                        else
                                                // We have found the start (row_start) and end (x) of
                                                // an opaque line.  Add it to the region.
                                                CRgn rgnAdd;
                                                rgnAdd.CreateRectRgn (rcClient.left+row_start,
                                                        rcClient.top+y, rcClient.left+x, rcClient.top+y+1);
                                                rgn.CombineRgn (&rgn, &rgnAdd, RGN_OR);
                                                row_start = x+1;
                        // If the last pixel is still opaque, make a region.
                        if (row_start != x)
                                CRgn rgnAdd;
                                rgnAdd.CreateRectRgn (rcClient.left+row_start, rcClient.top+y,
可调用SetWindowRgn (rgn, TRUE);函数后就是无法显示对话框,即使我执行上述函数的if分支也无法显示。
恳请各位英雄指点迷津!
呵?自己画?可以自己画不规则的窗体吗? 我其实是想在EVC下制作一个类似google map上的比例尺控件,就是可以缩放、上下左右移动的那种控件。可是它是个不规则的形状,不知道该如何实现?于是我想到用对话框和位图来实现,也即根据位图的形状来定制对话框,这样就形成了类似google map的控件了! 奈何EVC却做不到根据位图定制不规则对话框!同样的代码我在VC下是完全可以实现的!郁闷啊!  详情 回复 发表于 2009-1-4 17:21
66
哪位英雄指点啊,小弟任务紧迫,期待中...
55
引用 1 楼 daigua04 的回复:
你真是什么都做啊?
你的什么内存扩大问题解决了?
这个试试 GetWindowRect (&rc);    后面的也是  GetWindowRect()里面的参数改为指针
呵,内存问题还没有解决,不过老板有新的要求,只能先放一边了!
对了,把GetWindowRect (&rc); 改成指针还是同样的结果,看不见对话框!我单步调试,在调用SetWindowRgn之前没有发现有任何异常,调用之后,对话框就看不见了!唉!
87
CE下不支持的,LZ放弃吧!
啊!!!!!!
痛苦.......我恨微软....
呵呵,恨它也没用啊,你可以自己画啊.
呵?自己画?可以自己画不规则的窗体吗?
