2911|2
66
转发: step into and step over do same thing in AG_GoStep in apntex_173 [复制链接]
i am writing a AGDI Driver for the uVision Debugger base on apntex_173.
my chip is using Cortex-M0, many functions (r/w registers, r/w memory, start/stop debug session, run, run to cursor line, step out of current function, breakpoint and so on) have realized. only one thing makes me confused, as follow:
i compile a project and then debug it, when arrive a subroutine, F10 and F11(step and step over) do same thing, they both go into subrountine, F10 should execute step over but execute step into .
i track souce, when F10 and F11, they both go into AG_GoStep, parameters nCode is 2, nSteps always is 1(only execute a step), F10 should execute n step. Somebody can give me some advice?
Thans a lot!!!
哥们也玩过AGDI?  详情 回复 发表于 2010-1-24 14:32
52
很少用F11,通常是用F10和F8,具体也不清楚F11使用的过程会如何
哥们也玩过AGDI?
