3311|5
75
音频问题 CETK测试 [复制链接]
今天我用cetk来测试我的驱动程序关于AUDIO部分的。
我的音频部分录音很放音平时在机器上测都没有问题。。。都用了很长时间了,起码有3个月了。。但是今天用cetk测试的结果是
*** vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv
*** TEST STARTING
*** Test Name:      Capture
*** Test ID:        3001
*** Library Path:   \wavetest.dll
*** Command Line:
*** Random Seed:    7758
*** Thread Count:   0
   BEGIN TEST: "Capture", Threads=0, Seed=7758
      INSTRUCTIONS:  This test case will attempt to record and playback a tone for all common formats
      INSTRUCTIONS:  Please listen to playback to ensure that a tone is played
      Attempting to record WAVE_FORMAT_1M08
      Resolution:  16000000 Start:  5715536000 Finish:  5734048000  Duration:  1157 Expected:  1000
      Playing back what has been recorded
      Attempting to record WAVE_FORMAT_1M16
      Resolution:  16000000 Start:  5769456000 Finish:  5787968000  Duration:  1157 Expected:  1000
      Attempting to record WAVE_FORMAT_1S08
      Resolution:  16000000 Start:  5823376000 Finish:  5843520000  Duration:  1259 Expected:  1000
      "ERROR:  expected capturetime is too long" ((expected>g_dwInAllowance)) [c:\mlqa\private\test\audio\wave\functional\wavetest\test_wavein.cpp:252]
      Possible Cause:  "Driver notifying the end of capture too late"
      Attempting to record WAVE_FORMAT_1S16
      Resolution:  16000000 Start:  5878992000 Finish:  5897504000  Duration:  1157 Expected:  1000
      Attempting to record WAVE_FORMAT_2M08
      Resolution:  16000000 Start:  5934368000 Finish:  5953856000  Duration:  1218 Expected:  1000
      Attempting to record WAVE_FORMAT_2M16
      Resolution:  16000000 Start:  5990768000 Finish:  6010272000  Duration:  1219 Expected:  1000
      Attempting to record WAVE_FORMAT_2S08
      Resolution:  16000000 Start:  6047264000 Finish:  6066752000  Duration:  1218 Expected:  1000
      Attempting to record WAVE_FORMAT_2S16
      Resolution:  16000000 Start:  6103712000 Finish:  6123216000  Duration:  1219 Expected:  1000
      Attempting to record WAVE_FORMAT_4M08
      Resolution:  16000000 Start:  6163008000 Finish:  6182512000  Duration:  1219 Expected:  1000
      Attempting to record WAVE_FORMAT_4M16
      Resolution:  16000000 Start:  6222336000 Finish:  6241856000  Duration:  1220 Expected:  1000
      Attempting to record WAVE_FORMAT_4S08
      Resolution:  16000000 Start:  6281712000 Finish:  6301216000  Duration:  1219 Expected:  1000
      Attempting to record WAVE_FORMAT_4S16
      Resolution:  16000000 Start:  6341152000 Finish:  6360656000  Duration:  1219 Expected:  1000
   END TEST: "Capture", FAILED, Time=42.580
请格纹大哥们帮忙看看是什么原因。。我确实无从查起了
哎。。。你很强了啊。。回答了这么多的问题。不管怎么也谢谢你啊。。 有没有知道的啊。。。。来定一下   详情 回复 发表于 2009-2-18 13:57
85
没有人顶啊
82
都不会用CEtk,还要向你学习才行,真的帮不了你哦。
78
是我老大测试的。。不是我测的。。拿出了这个报告。。就让我改。。都不知道从和下手。。。你很牛X啊
引用 3 楼 unsway123 的回复:
我就不要说了......感觉混的挺惨的。有这么好的老大教要好好把这些东西学会啊。我是自由摸索......经常郁闷。
引用 4 楼 gooogleman 的回复:
有没有知道的啊。。。。来定一下
ADI &文晔 探索季第一站,邀您在活动帖跟帖,ADI资深工程师将与您一道寻求解决之道! ...
春晚,最出圈当属穿着棉马甲跳秧歌的机器人”秧Bot”。
转手绢、飞手绢、变换队形,精准度和稳定性甚至超越人类,这背后少不了电机控制技术。
