5471|8
61
926EJ的处理器能否用tornado2.2 for arm开发? [复制链接]
如题
此帖出自ARM技术论坛
我收回我在4楼说的话,按照5楼和8楼的说法,我又google了一下,找到了这个BSP,但是由于我的帐号权限不够,只能够看到这个BSP,不允许我下载。 airman926ej Board Manufacturer: Fujitsu BSP Sales Contact: Wind River Download tor221_airman926ej_1_2_0.zip! Product availability: Online Support BSP Tech Support: Professional Services (Ref# FUJ03) Expires Apr 2007 Wind River Architecture: ARM9   Processor: ARM926EJ   Processor revision details:    Board name: airman926ej/Fujitsu SoC 802.16 Reference Kit   Board revision details:    BSP name: airman926ej   BSP revision details: 1.2   Board form factor: Custom Processors on board: 1   DSPs on board: 0   NPs on board: 0   FPGA on board: 0   Host support: WindView - Analyzer Windows Host Installation Solaris Host Installation   Please see release notes for complete list of hosts and versions. Board short description: TBD    Product version: VxWorks: 5.5.1 - Tornado Tools 2.2.1   Vertical Market: Networking   Supported WindRiver Middleware: DOS FS    TCP/IP Networking Stack    10/100 Megabit Ethernet Device Support    Serial UART device support    Endian: Little    Debug port used: JTAG   Wind River certification: Not Supported Supported Board features: -ARM926EJ core -32 MB SDRAM -4 MB Flash -Timer -Memory Controller -Interrupt Controller -Ethernet -Serial port -I2C -SPI -Watchdog -GPIO Not Supported Board features: -ADC -DAC -Radio Control Known Problem 1:  VxWorks ROM images are not supported    Entry last updated: 03-FEB-09     详情 回复 发表于 2010-4-30 20:30
75
支持下面的这些核
integrator720t_t
integrator720t
integrator740t_t
integrator740t
integrator7t_t
integrator7t
integrator920t_t
integrator920t
integrator940t_t
integrator940t
integrator946es_t
integrator946es
ntegrator966es_t
integrator966es
wrSbcArm7_be
wrSbcArm7_tbe
wrSbcArm7_t
wrSbcArm7
不支持926EJ
此帖出自ARM技术论坛
66
那哪个版本能支持926EJ的内核?
此帖出自ARM技术论坛
83
楼上的高人,好像已经说了 不支持926EJ。
此帖出自ARM技术论坛
81
bullshit, there is the ARM926EJS patch for Tornado 2.2.1 from Wind River.
此帖出自ARM技术论坛
89
能给出926ejs patch下载链接吗? 想试试。
此帖出自ARM技术论坛
你认为能下的到嘛?直接用6.x版本吧,自带926ejs bsp的
此帖出自ARM技术论坛
78
五楼说的没错,2.2.1是可以支持926EJ-S的。我已经在两个此内核的SOC上做过BSP了,运行的很好啦!
此帖出自ARM技术论坛
75
airman926ej
Expires Apr 2007
Wind River
Architecture: ARM9
Processor: ARM926EJ
DSPs on board: 0
NPs on board: 0
FPGA on board: 0
Endian: Little
-32 MB SDRAM
-4 MB Flash
-Timer
-Memory Controller
-Ethernet
-Serial port
-I2C
-SPI
-Watchdog
-GPIO
-DAC
-Radio Control
此帖出自ARM技术论坛
