3439|5
92
nand flash autoload 问题!! [复制链接]
搞了一天了,不得已才发问的555 环境:2410+64ram+64nand+wince 6.0
注册表:[HKEY_LOCAL_MACHINE\System\StorageManager\AutoLoad\SMFLASH]
    "DriverPath"="Drivers\\BuiltIn\\SMFLASH"
    "LoadFlags"=dword:1
    "BootPhase"=dword:0
[HKEY_LOCAL_MACHINE\Drivers\BuiltIn\SMFLASH]
    "Prefix"="DSK"
    "Dll"="smflash.dll"
    "Index"=dword:1
    "Order"=dword:0
    "Profile"="SMFLASH"
    "IClass"="{A4E7EDDA-E575-4252-9D6B-4195D48BB865}"
   "Flags"= dword:1000            ;;;;;;;;;;
[HKEY_LOCAL_MACHINE\System\StorageManager\Profiles\SMFLASH]
    "DefaultFileSystem"="BINFS"
    "AutoPart"=dword:1
    "AutoMount"=dword:1
    "PartitionDriver"="mspart.dll"
    "Name"="Microsoft Flash Disk"
    "Folder"="ResidentFlash"
    "BootPhase"=dword:0
注:把AUTOLAOD 项去掉,让设备管理器加载又没问题,让FILESYS。EXE的加载出问题
信息如下:
FILESYS: RAM File System FSD_MountDisk registering folder "Object Store"
4294769325 PID:400002 TID:680002 FSDMGR!MountTable_t::RegisterVolumeName: Registered "Object Store" at index 4
PB Debugger Loaded symbols for 'F:\WINCE600\OSDESIGNS\TEST3\TEST3\RELDIR\TEST2_ARMV4I_DEBUG\PM.DLL'
4294769325 PID:400002 TID:680002 FSDMGR!MountTable_t::RegisterVolume: Registered volume at index 4 (Name="", MountFlags=0x46)
4294769331 PID:400002 TID:930002 FSDMGR!PNPThread: Using PNPUnloadDelay of 4096
4294769334 PID:400002 TID:930002 FSDMGR!PNPThread: PNPThread starting!
4294769336 PID:400002 TID:680002 FSDMGR!AutoLoadFileSystem: CurrentBootPhase=0, RootKey=System\StorageManager\AutoLoad, FileSystem_t=SMFLASH
4294769337 PID:400002 TID:680002 FSDMGR!AutoLoadBlockDevice: Auto-loading block driver from "Drivers\BuiltIn\SMFLASH"
4294769338 PID:400002 TID:680002 FSDMGR!MountStore: Attaching new storage device "SMFLASH"
4294769346 PID:400002 TID:680002 FSDMGR!MountStore: Failed mounting store "SMFLASH"; error=126
4294769346 PID:400002 TID:680002 FSDMGR!StoreDisk_t::~StoreDisk_t: deleting store (D00426B0)
4294769347 PID:400002 TID:680002 FSDMGR!AutoLoadFileSystems: Unable to auto-load HKLM\System\StorageManager\AutoLoad\SMFLASH; error=126
4294769351 PID:400002 TID:680002 FSDMGR!STOREMGR_StartBootPhase BootPhase=1 (PrevBootPhase=0)
4294769351 PID:400002 TID:680002 FSDMGR!AutoLoadFileSystems: CurrentBootPhase=1, LoadFlags=1
汗,解决了,原来是我的FLASH驱动加载错了  详情 回复 发表于 2009-9-18 15:46
67
不知道楼主想问什么?
77
up
Unable to auto-load HKLM\System\StorageManager\AutoLoad\SMFLASH 这个问题.
88
//  The specified module could not be found.
#define ERROR_MOD_NOT_FOUND              126L
56
