2758|1
自己写得采集卡驱动,每隔一段时间会蓝屏,我用windbg打开dmp文件,分析内容看不明白,大家帮我看看好吗?先谢谢了 [复制链接]
Microsoft (R) Windows Debugger Version 6.11.0001.404 X86
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\WINNT\Minidump\Mini073009-02.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
WARNING: Non-directory path: 'C:\WINNT\Minidump\Mini073009-02.dmp'
Symbol search path is: SRV*C:\Program Files\Debugging Tools for Windows (x86)\sym*http://msdl.microsoft.com/download/symbols
Executable search path is: C:\WINNT\Minidump\Mini073009-02.dmp
Unable to load image ntoskrnl.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
*** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe
Windows 2000 Kernel Version 2195 (Service Pack 4) MP (2 procs) Free x86 compatible
Machine Name:
Kernel base = 0x80400000 PsLoadedModuleList = 0x80484520
Debug session time: Thu Jul 30 16:36:49.187 2009 (GMT+8)
System Uptime: not available
Loading Kernel Symbols
Press ctrl-c (cdb, kd, ntsd) or ctrl-break (windbg) to abort symbol loads that take too long.
Run !sym noisy before .reload to track down problems loading symbols.
Loading User Symbols
Loading unloaded module list
*                        Bugcheck Analysis                                    *
Use !analyze -v to get detailed debugging information.
BugCheck A, {ffdf, 2, 1, 80004622}
***** Kernel symbols are WRONG. Please fix symbols to do analysis.
*** WARNING: Unable to verify timestamp for hal.dll
*** ERROR: Module load completed but symbols could not be loaded for hal.dll
Probably caused by : ntoskrnl.exe ( nt+6987c )
Followup: MachineOwner
剩余部分信息: 0: kd> !analyze -v ******************************************************************************* *        * *                        Bugcheck Analysis                                    * *        * ******************************************************************************* IRQL_NOT_LESS_OR_EQUAL (a) An attempt was made to access a pageable (or completely invalid) address at an interrupt request level (IRQL) that is too high.  This is usually caused by drivers using improper addresses. If a kernel debugger is available get the stack backtrace. Arguments: Arg1: 0000ffdf, memory referenced Arg2: 00000002, IRQL Arg3: 00000001, bitfield :         bit 0 : value 0 = read operation, 1 = write operation         bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status) Arg4: 80004622, address which referenced memory Debugging Details: ------------------ ***** Kernel symbols are WRONG. Please fix symbols to do analysis. ADDITIONAL_DEBUG_TEXT:   Use '!findthebuild' command to search for the target build information. If the build information is available, run '!findthebuild -s ; .reload' to set symbol path and load symbols. MODULE_NAME: nt FAULTING_MODULE: 80400000 nt DEBUG_FLR_IMAGE_TIMESTAMP:  3ee650b3 WRITE_ADDRESS: unable to get nt!MmPoolCodeEnd unable to get nt!MmSpecialPoolEnd unable to get nt!MmPagedPoolEnd unable to get nt!MmNonPagedPoolEnd unable to get nt!MmNonPagedPoolStart unable to get nt!MmSpecialPoolStart unable to get nt!MmPagedPoolStart unable to get nt!MmNonPagedPoolExpansionStart unable to get nt!MmPoolCodeStart 0000ffdf CURRENT_IRQL:  2 FAULTING_IP: hal+3622 80004622 ??              ??? CUSTOMER_CRASH_COUNT:  2 DEFAULT_BUCKET_ID:  DRIVER_FAULT BUGCHECK_STR:  0xA LAST_CONTROL_TRANSFER:  from 00000000 to 8046987c STACK_TEXT:   ae5e8b58 00000000 0000ffdf 00000002 00000001 nt+0x6987c STACK_COMMAND:  kb FOLLOWUP_IP: nt+6987c 8046987c ??              ??? SYMBOL_STACK_INDEX:  0 SYMBOL_NAME:  nt+6987c FOLLOWUP_NAME:  MachineOwner IMAGE_NAME:  ntoskrnl.exe BUCKET_ID:  WRONG_SYMBOLS Followup: MachineOwner --------- 0: kd> !analyze -v ******************************************************************************* *        * *                        Bugcheck Analysis                                    * *        * ******************************************************************************* IRQL_NOT_LESS_OR_EQUAL (a) An attempt was made to access a pageable (or completely invalid) address at an interrupt request level (IRQL) that is too high.  This is usually caused by drivers using improper addresses. If a kernel debugger is available get the stack backtrace. Arguments: Arg1: 0000ffdf, memory referenced Arg2: 00000002, IRQL Arg3: 00000001, bitfield :         bit 0 : value 0 = read operation, 1 = write operation         bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status) Arg4: 80004622, address which referenced memory Debugging Details: ------------------ ***** Kernel symbols are WRONG. Please fix symbols to do analysis. ADDITIONAL_DEBUG_TEXT:   Use '!findthebuild' command to search for the target build information. If the build information is available, run '!findthebuild -s ; .reload' to set symbol path and load symbols. MODULE_NAME: nt FAULTING_MODULE: 80400000 nt DEBUG_FLR_IMAGE_TIMESTAMP:  3ee650b3 WRITE_ADDRESS:  0000ffdf CURRENT_IRQL:  2 FAULTING_IP: hal+3622 80004622 ??              ??? CUSTOMER_CRASH_COUNT:  2 DEFAULT_BUCKET_ID:  DRIVER_FAULT BUGCHECK_STR:  0xA LAST_CONTROL_TRANSFER:  from 00000000 to 8046987c STACK_TEXT:   ae5e8b58 00000000 0000ffdf 00000002 00000001 nt+0x6987c STACK_COMMAND:  kb FOLLOWUP_IP: nt+6987c 8046987c ??              ??? SYMBOL_STACK_INDEX:  0 SYMBOL_NAME:  nt+6987c FOLLOWUP_NAME:  MachineOwner IMAGE_NAME:  ntoskrnl.exe BUCKET_ID:  WRONG_SYMBOLS Followup: MachineOwner --------- 0: kd> !analyze -v ******************************************************************************* *        * *                        Bugcheck Analysis                                    * *        * ******************************************************************************* IRQL_NOT_LESS_OR_EQUAL (a) An attempt was made to access a pageable (or completely invalid) address at an interrupt request level (IRQL) that is too high.  This is usually caused by drivers using improper addresses. If a kernel debugger is available get the stack backtrace. Arguments: Arg1: 0000ffdf, memory referenced Arg2: 00000002, IRQL Arg3: 00000001, bitfield :         bit 0 : value 0 = read operation, 1 = write operation         bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status) Arg4: 80004622, address which referenced memory Debugging Details: ------------------ ***** Kernel symbols are WRONG. Please fix symbols to do analysis. ADDITIONAL_DEBUG_TEXT:   Use '!findthebuild' command to search for the target build information. If the build information is available, run '!findthebuild -s ; .reload' to set symbol path and load symbols. MODULE_NAME: nt FAULTING_MODULE: 80400000 nt DEBUG_FLR_IMAGE_TIMESTAMP:  3ee650b3 WRITE_ADDRESS:  0000ffdf CURRENT_IRQL:  2 FAULTING_IP: hal+3622 80004622 ??              ??? CUSTOMER_CRASH_COUNT:  2 DEFAULT_BUCKET_ID:  DRIVER_FAULT BUGCHECK_STR:  0xA LAST_CONTROL_TRANSFER:  from 00000000 to 8046987c STACK_TEXT:   ae5e8b58 00000000 0000ffdf 00000002 00000001 nt+0x6987c STACK_COMMAND:  kb FOLLOWUP_IP: nt+6987c 8046987c ??              ??? SYMBOL_STACK_INDEX:  0 SYMBOL_NAME:  nt+6987c FOLLOWUP_NAME:  MachineOwner IMAGE_NAME:  ntoskrnl.exe BUCKET_ID:  WRONG_SYMBOLS Followup: MachineOwner --------- 0: kd> .symfix 0: kd> .reload Unable to load image ntoskrnl.exe, Win32 error 0n2 *** WARNING: Unable to verify timestamp for ntoskrnl.exe *** ERROR: Module load completed but symbols could not be loaded for ntoskrnl.exe Loading Kernel Symbols ............................................................... ............................... Loading User Symbols Loading unloaded module list ...................... 0: kd> !analyze -v ******************************************************************************* *        * *                        Bugcheck Analysis                                    * *        * ******************************************************************************* IRQL_NOT_LESS_OR_EQUAL (a) An attempt was made to access a pageable (or completely invalid) address at an interrupt request level (IRQL) that is too high.  This is usually caused by drivers using improper addresses. If a kernel debugger is available get the stack backtrace. Arguments: Arg1: 0000ffdf, memory referenced Arg2: 00000002, IRQL Arg3: 00000001, bitfield :         bit 0 : value 0 = read operation, 1 = write operation         bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status) Arg4: 80004622, address which referenced memory Debugging Details: ------------------ ***** Kernel symbols are WRONG. Please fix symbols to do analysis. *** WARNING: Unable to verify timestamp for hal.dll *** ERROR: Module load completed but symbols could not be loaded for hal.dll ADDITIONAL_DEBUG_TEXT:   Use '!findthebuild' command to search for the target build information. If the build information is available, run '!findthebuild -s ; .reload' to set symbol path and load symbols. MODULE_NAME: nt FAULTING_MODULE: 80400000 nt DEBUG_FLR_IMAGE_TIMESTAMP:  3ee650b3 WRITE_ADDRESS:  0000ffdf CURRENT_IRQL:  2 FAULTING_IP: hal+3622 80004622 ??              ??? CUSTOMER_CRASH_COUNT:  2 DEFAULT_BUCKET_ID:  DRIVER_FAULT BUGCHECK_STR:  0xA LAST_CONTROL_TRANSFER:  from 00000000 to 8046987c STACK_TEXT:   ae5e8b58 00000000 0000ffdf 00000002 00000001 nt+0x6987c STACK_COMMAND:  kb FOLLOWUP_IP: nt+6987c 8046987c ??              ??? SYMBOL_STACK_INDEX:  0 SYMBOL_NAME:  nt+6987c FOLLOWUP_NAME:  MachineOwner IMAGE_NAME:  ntoskrnl.exe BUCKET_ID:  WRONG_SYMBOLS Followup: MachineOwner --------- 0: kd> lmvm nt start    end        module name 80400000 8059dd00   nt       T (no symbols)                Loaded symbol image file: ntoskrnl.exe     Image path: ntoskrnl.exe     Image name: ntoskrnl.exe     Timestamp:        Wed Jun 11 05:42:11 2003 (3EE650B3)     CheckSum:         001A350E     ImageSize:        0019DD00     Translations:     0000.04b0 0000.04e4 0409.04b0 0409.04e4   详情 回复 发表于 2009-7-31 10:02
剩余部分信息:
0: kd> !analyze -v
Arguments:
Debugging Details:
MODULE_NAME: nt
0000ffdf
CURRENT_IRQL:  2
FAULTING_IP:
hal+3622
80004622 ??              ???
BUGCHECK_STR:  0xA
STACK_TEXT:
STACK_COMMAND:  kb
FOLLOWUP_IP:
nt+6987c
8046987c ??              ???
0: kd> !analyze -v
Arguments:
Debugging Details:
MODULE_NAME: nt
CURRENT_IRQL:  2
FAULTING_IP:
hal+3622
80004622 ??              ???
BUGCHECK_STR:  0xA
STACK_TEXT:
STACK_COMMAND:  kb
FOLLOWUP_IP:
nt+6987c
8046987c ??              ???
0: kd> !analyze -v
Arguments:
Debugging Details:
MODULE_NAME: nt
CURRENT_IRQL:  2
FAULTING_IP:
hal+3622
80004622 ??              ???
BUGCHECK_STR:  0xA
STACK_TEXT:
STACK_COMMAND:  kb
FOLLOWUP_IP:
nt+6987c
8046987c ??              ???
0: kd> .symfix
0: kd> .reload
0: kd> !analyze -v
Arguments:
Debugging Details:
MODULE_NAME: nt
CURRENT_IRQL:  2
FAULTING_IP:
hal+3622
80004622 ??              ???
BUGCHECK_STR:  0xA
STACK_TEXT:
STACK_COMMAND:  kb
FOLLOWUP_IP:
nt+6987c
8046987c ??              ???
0: kd> lmvm nt
    CheckSum:         001A350E
    ImageSize:        0019DD00
会议时间:3月18日(周二)09:30签到
参会奖励:电动螺丝刀套装、户外登山包、京东卡
