5894|28
TO USB驱动开发的例程问题 [复制链接]
本人使用Cy7c68013A进行开发,其它例程都已经完成,控制传输找资料已经完成.
只是剩下   DriverObject->MajorFunction[IRP_MJ_WRITE] = Ezusb_Write;   //写入数据
   DriverObject->MajorFunction[IRP_MJ_READ] = Ezusb_Read;     //读取数据
这两个例程没有完成,本人没有写过此类例程,不知如何下手,有知道的朋友告知一下相关的消息也行,谢谢了.
实际上,在XP下也有问题的。只是屏幕没有显示而已! 试着My computer->property->Advanced->Startup and Recovery auto restart选项勾掉,看看是否能重现问题?   详情 回复 发表于 2008-1-4 18:49
61
NTSTATUS
Ezusb_Read(
    IN PDEVICE_OBJECT DeviceObject,
    IN PIRP           Irp
    PMDL                   mdl;
    PURB                   urb;
    ULONG                  totalLength;
    ULONG                  stageLength;
    ULONG                  urbFlags;
    BOOLEAN                read;
    NTSTATUS               ntStatus;
    ULONG_PTR              virtualAddress;
    PFILE_OBJECT           fileObject;
    PDEVICE_EXTENSION      deviceExtension;
    PIO_STACK_LOCATION     irpStack;
    PIO_STACK_LOCATION     nextStack;
    PBULKUSB_RW_CONTEXT    rwContext;
    PUSBD_PIPE_INFORMATION pipeInformation;
        PVOID IoBuffer;
    // initialize variables
    urb = NULL;
    mdl = NULL;
    rwContext = NULL;
    totalLength = 0;
    irpStack = IoGetCurrentIrpStackLocation(Irp);
    fileObject = irpStack->FileObject;
    read = (irpStack->MajorFunction == IRP_MJ_READ) ? TRUE : FALSE;
    deviceExtension = (PDEVICE_EXTENSION) DeviceObject->DeviceExtension;
    IoBuffer           = Irp->AssociatedIrp.SystemBuffer;
    if(fileObject && fileObject->FsContext) {
        pipeInformation = fileObject->FsContext;
        if((UsbdPipeTypeBulk != pipeInformation->PipeType) &&
           (UsbdPipeTypeInterrupt != pipeInformation->PipeType)) {
            ntStatus = STATUS_INVALID_HANDLE;
            goto BulkUsb_DispatchRead_Exit;
    else {
    rwContext = (PBULKUSB_RW_CONTEXT)
                ExAllocatePool(NonPagedPool,
                               sizeof(BULKUSB_RW_CONTEXT));
    if(rwContext == NULL) {
        ntStatus = STATUS_INSUFFICIENT_RESOURCES;
    if(Irp->MdlAddress) {
        totalLength = MmGetMdlByteCount(Irp->MdlAddress);
    if(totalLength > BULKUSB_TEST_BOARD_TRANSFER_BUFFER_SIZE) {
        ntStatus = STATUS_INVALID_PARAMETER;
        ExFreePool(rwContext);
    if(totalLength == 0) {
        ntStatus = STATUS_SUCCESS;
    urbFlags = USBD_SHORT_TRANSFER_OK;
    virtualAddress = (ULONG_PTR) MmGetMdlVirtualAddress(Irp->MdlAddress);
    if(read) {
        urbFlags |= USBD_TRANSFER_DIRECTION_IN;
    else {
        urbFlags |= USBD_TRANSFER_DIRECTION_OUT;
    // the transfer request is for totalLength.
    // we can perform a max of BULKUSB_MAX_TRANSFER_SIZE
    // in each stage.
    if(totalLength > BULKUSB_MAX_TRANSFER_SIZE) {
        stageLength = BULKUSB_MAX_TRANSFER_SIZE;
    else {
        stageLength = totalLength;
    mdl = IoAllocateMdl((PVOID) virtualAddress,
                        totalLength,
                        FALSE,
                        FALSE,
                        NULL);
    if(mdl == NULL) {
    // map the portion of user-buffer described by an mdl to another mdl
    IoBuildPartialMdl(Irp->MdlAddress,
                      mdl,
                      stageLength);
    urb = ExAllocatePool(NonPagedPool,
                         sizeof(struct _URB_BULK_OR_INTERRUPT_TRANSFER));
    if(urb == NULL) {
        IoFreeMdl(mdl);
    UsbBuildInterruptOrBulkTransferRequest(
                            urb,
                            sizeof(struct _URB_BULK_OR_INTERRUPT_TRANSFER),
                            pipeInformation->PipeHandle,
                            NULL,
                            mdl,
                            stageLength,
                            urbFlags,
                            NULL);
    // set BULKUSB_RW_CONTEXT parameters.
    rwContext->Urb             = urb;
    rwContext->Mdl             = mdl;
    rwContext->Length          = totalLength - stageLength;
    rwContext->Numxfer         = 0;
    rwContext->VirtualAddress  = virtualAddress + stageLength;
    rwContext->DeviceExtension = deviceExtension;
    // use the original read/write irp as an internal device control irp
    nextStack = IoGetNextIrpStackLocation(Irp);
    nextStack->MajorFunction = IRP_MJ_INTERNAL_DEVICE_CONTROL;
    nextStack->Parameters.Others.Argument1 = (PVOID) urb;
    nextStack->Parameters.DeviceIoControl.IoControlCode =
                                             IOCTL_INTERNAL_USB_SUBMIT_URB;
    IoSetCompletionRoutine(Irp,
                           (PIO_COMPLETION_ROUTINE)Ezusb_ReadWriteCompletion,
                           rwContext,
                           TRUE,
                           TRUE,
                           TRUE);
    // since we return STATUS_PENDING call IoMarkIrpPending.
    // This is the boiler plate code.
    // This may cause extra overhead of an APC for the Irp completion
    // but this is the correct thing to do.
    IoMarkIrpPending(Irp);
    //BulkUsb_IoIncrement(deviceExtension);
    ntStatus = IoCallDriver(deviceExtension->StackDeviceObject,
                            Irp);
    if(!NT_SUCCESS(ntStatus)) {
        // if the device was yanked out, then the pipeInformation
        // field is invalid.
        // similarly if the request was cancelled, then we need not
        // invoked reset pipe/device.
        if((ntStatus != STATUS_CANCELLED) &&
           (ntStatus != STATUS_DEVICE_NOT_CONNECTED)) {
            ULONG pipenum = *((PULONG) irpStack);
            /*ntStatus = UsbResetPipe(DeviceObject,
                                     pipeInformation);*/
                                     pipenum);
                //ntStatus = BulkUsb_ResetDevice(DeviceObject);
        else {
    // we return STATUS_PENDING and not the status returned by the lower layer.
    return STATUS_PENDING;
BulkUsb_DispatchRead_Exit:
    Irp->IoStatus.Status = ntStatus;
    Irp->IoStatus.Information = 0;
    IoCompleteRequest(Irp, IO_NO_INCREMENT);
    return ntStatus;
这是我找资料写的一个写例程.我用softIce进行调试时if(fileObject && fileObject->FsContext) 这里就没有往下执行,直接跳到
    else {
了,不知道为什么,我也只是从别的地方抄来的,肯定不对,请高手指正.
顶一个人都没有,极郁闷.叫我怎么结贴啊
78
顶个吧
75
顶呀
64
rzsheng(跑生活的男人) ( ) 信誉:100
你都5级了,也帮忙看看撒.晕
55
鏌ョ湅鏈笘鍏ㄩ儴璁ㄨ锛岃鐧诲綍鎴栬€�娉ㄥ唽
84
79
90
62
78
85
90
直播时间:3月12日(周三)上午10:00
直播奖励:多功能榨汁机、蓝牙音箱、手机支架
