8492|16
65
关于单片机语言c51和c语言的区别 [复制链接]
在vc++6.0环境下编的树的结构程序在keil环境下却有错误。
如:
#include
#include
#include
char MenuOne_Date[3][14]={"1 Module Text","2 Tools","3 About Me"};
//这里和下面的MenuName[]改为unsigned 为什么有错?
char MenuTools_Date[4][11]={"1 SetTime","2 Dingshi","3 MiaoBiao","4 Book"};
struct NodeDate
        char seq;
        char MenuName[17];
struct MenuNode
        NodeDate data;       ///这里keil uvision说是有错误的
        struct MenuNode *parent;
        struct MenuNode *firstchild;
        struct MenuNode *nextbrd;
}*Previous,Module_Struct,Tools_Struct,AboutMe_Struct,SetTime_Struct,DingShi_Struct,MiaoBiao_Struct,Book_Struct;
void BuildNode(struct MenuNode * Self,struct MenuNode *Parent_Node,struct MenuNode *Firstchild_Node,
struct MenuNode *Nextbrd_Node,char seq,char MenuName[17])
        Self->parent=Parent_Node;
        Self->firstchild=Firstchild_Node;
        Self->nextbrd=Nextbrd_Node;
        Self->data.seq=seq;
        strcpy(Self->data.MenuName,MenuName);
void Initial_MenuStruct(void)
        //第一层Menu
        BuildNode(&Module_Struct,NULL,&SetTime_Struct,&Tools_Struct,10,MenuOne_Date[0]);
        BuildNode(&Tools_Struct,NULL,NULL,&AboutMe_Struct,11,MenuOne_Date[1]);
        BuildNode(&AboutMe_Struct,NULL,NULL,&Module_Struct,12,MenuOne_Date[2]);
        Previous=&Module_Struct;
        //Module子层Menu
        BuildNode(&SetTime_Struct,&Module_Struct,NULL,&DingShi_Struct,20,MenuTools_Date[0]);
        BuildNode(&DingShi_Struct,&Module_Struct,NULL,&MiaoBiao_Struct,21,MenuTools_Date[1]);
        BuildNode(&MiaoBiao_Struct,&Module_Struct,NULL,&Book_Struct,22,MenuTools_Date[2]);
        BuildNode(&Book_Struct,&Module_Struct,NULL,&SetTime_Struct,23,MenuTools_Date[3]);
void main(void)
        Initial_MenuStruct();
        for(int i=0;i<3;i++)
                //cout<data.MenuName<<"     "<data.seq<                 printf("%s\t%d\n",Previous->data.MenuName,Previous->data.seq);
                Previous=Previous->nextbrd;
        Previous=Module_Struct.firstchild;
        for(i=0;i<4;i++)
这个程序在vc是没问题的。
但在keil环境下 我删除了这里的main函数(我的工程在其他.c中是有main的),结构体没改,进行编译。出现错误:
struct MenuNode
        NodeDate data;
error 1: syntax error near 'NodeDate'
error 2: missing ';'before 'data'
请问是什么原因啊 在线等待
此帖出自编程基础论坛
NodeDate data;       ///这里keil uvision说是有错误的 “data”在KEIL uVension2的C51里是一种数据类型关键字  详情 回复 发表于 2007-3-7 18:34
C,不是C++
如果不用typedef 就得用struct MenuNode.
struct MenuNode{
};//这里得有个分号
此帖出自编程基础论坛
#include
KEIL里面没有这个库!!
单片机不是PC
此帖出自编程基础论坛
67
讲先看一下单片机体系结构再写程序,至少过一遍
C51里具体与标准的差异,请看安装目录下的HEL文件夹里的C51.PDF
里面有C51的完全说明...
此帖出自编程基础论坛
哦 先说明一下:
1  那c++的库iostream是我用vc做的 不好意思 发帖的时候没删掉!
2  struct MenuNode{}后面有';'了;
3  我就想知道那个错误在keil怎么改。其他与单片机参数接口问题我已经做好了。
此帖出自编程基础论坛
57
C51里得用struct NodeDate.
error 1: syntax error near 'NodeDate'//这个的话有可能是编译类型设置的问题,把项目设置成large模式看看
在option 里更改项目属性中的target里memory modle里进行设置...
此帖出自编程基础论坛
66
用了这个struct NodeDate data;造成很多错误。不好意思 我还是不懂。
不知道您能否在keil uvision中调试一下 在发那段代码来啊
谢谢了!
此帖出自编程基础论坛
64
我们做的菜单不是用你的这种组织方式...
呵呵
此帖出自编程基础论坛
86
struct NodeDate data;       ///这里keil uvision说是有错误的
帅哥,找着一个问题
data是C51里的一个关键字
此帖出自编程基础论坛
#include
//#include
#include
struct NodeDate
        char seq;
        char MenuName[17];
struct MenuNode
        struct NodeDate data1;       ///这里keil uvision说是有错误的
        Self->data1.seq=seq;
        strcpy(Self->data1.MenuName,MenuName);
        //第一层Menu
        //Module子层Menu
void main(void)
    int i=0;
        for(i=0;i<3;i++)
                //cout<data.MenuName<<"     "<data.seq<                 printf("%s\t%d\n",Previous->data1.MenuName,Previous->data1.seq);
        for(i=0;i<4;i++)
//这个编译通过了,要把设置成large模式.
此帖出自编程基础论坛
谢谢了 data是关键字 这真的没想过哦  笨死了 呵呵
struct NodeDate data1; 这个结构我刚才在网上下载的c51电子书说的却是跟c语言一样的。
把设置成large模式是因为我的程序和menu菜单占rom太大了?
我这个小工程是用的at89s52做的,除了这个程序外还有其他键盘lcd等程序的
4k的rom不知道能装下去不?
此帖出自编程基础论坛
92
装不下去就想办法压空间..
再不行就上ASM
再不行就只能减功能/换片子了...
此帖出自编程基础论坛
82
这个是RAM不够,ROM的4K还是没用完的...
此帖出自编程基础论坛
66
好 谢谢了
此帖出自编程基础论坛
85
到时候在设置一下优化代码,4k差不多
此帖出自编程基础论坛
mark~
此帖出自编程基础论坛
61
此帖出自编程基础论坛
