2974|3
78
请帮忙看看我的CE启动信息。 [复制链接]
Start = 0x81100004, range = (0x81100000,0x825eb4fb), format = SREC
YAMON> go 81100004
Windows CE Kernel for MIPS Built on Jun 24 2004 at 18:24:50
+OEMInit
AMD Alchemy Au1200/Db1200
Cold Boot
Using RTCTICK tick source
yan:start add args...
BootArgs are at A00FFC00, SIG = 544f4f42
Eshell Flags = 0x20, KitlTransport = 0x800c810
+OEMKitlInit
Starting KITL over Ethernet
LAN91C111: +OEMEthInit
LAN91C111: MAC Addr:D0:91:DC:F0:AE:02
LAN91C111: Starting Auto NegotiationKITL Ethernet interrupt mode. SYSINTR = 17
LAN91C111: -OEMEthInit
DeviceName: Q
MAC Addr: D0:91:DC:F0:AE:02
Calling EdbgInitDHCP
KITL using memory from 80006000 to 80026000
Using SysIntr 17
Sharing Ethernet using VMINI...
VBridge:: built on [Jun 26 2007] time [13:04:56]
.TX = [16384] bytes -- Rx = [16384] bytes
0xA2635480] to [0xA2639480].
Rx buffer [0xA26394A0] to [0xA263D4A0].
ge:: NK add MAC: [D0-91-DC-F0-AE-2]
Ethernet
-OEMKitlInit (Q)
!Kitl buffer specified by OAL is not required, ignore...
ApplyFilter: MULTICAST OFF
ApplyFilter: BROADCAST OFF
ApplyFilter: PROMISCUOUS OFF
ApplyFilter: ALL_MULTICAST OFF
什么原因导致没有继续启动下去了呢?
自己顶,顶到有人来回答为止。。。   详情 回复 发表于 2007-6-27 11:41
另外我的config.bib的配置如果下:
IF IMGFLASH !
    NK            9E000000  01C00000  RAMIMAGE
    RAM           81100000  05000000  RAM
ENDIF
IF IMGFLASH
ENDIF
IF IMGFLASH
    ROMSTART=9E000000
    ROMSIZE=01C00000
    ROMWIDTH=32
    ROMOFFSET=0
    SRE=ON
ENDIF
我的开发板有32MB FLASH
我在命令行下:set IMGFLASH=1
              makeimg
当写完sre文件后会产生一个错误,说rom前面有XXXXXX个字节,然后退出。这个XXXX数字相当巨大
请问这是什么原因呢?
makeimg产生的错误信息:
Compacting bin file...
Writing sre file...
Writing rom file...
First 3809476608 bytes of rom empty
makeimg: FATAL ERROR: Command returned non-zero exit code 3 (dec).
自己顶,顶到有人来回答为止。。。
