3382|4
75
WinCE中nboot跳往eboot的地址 [复制链接]
nboot的main函数主要如下
main
  SetupCopySection(pTOC);
    MMU_EnableICache();
    Port_Init();
    Uart_Init();
    NF_Init();
    pCopyPtr = (BYTE *)LOAD_ADDRESS_PHYSICAL;
    ((PFN_IMAGE_LAUNCH)(LOAD_ADDRESS_PHYSICAL))();  //跳转去执行eboot代码
(#define  LOAD_ADDRESS_PHYSICAL  0x30038000)
这个0x3003_8000 是表示物理地址吧.我用的是cpu是三星的2440-a43,内置了64M的SDRAM,关于cpu物理地址的定义如下
; TABLE FORMAT
;       cached address, physical address, size
g_oalAddressTable
        DCD     0x80000000, 0x30000000, 64      ; 32 MB DRAM BANK 6
        DCD     0x84000000, 0x10000000, 32      ; nGCS2: PCMCIA/PCCARD
        DCD     0x86000000, 0x18000000, 32      ; 32 MB SROM(SRAM/ROM) BANK 3
        DCD     0x88000000, 0x20000000, 32      ; 32 MB SROM(SRAM/ROM) BANK 4
        DCD     0x8A000000, 0x28000000, 32      ; 32 MB SROM(SRAM/ROM) BANK 5
        DCD     0x8C000000, 0x08000000, 32      ; 32 MB SROM(SRAM/ROM) BANK 1
        DCD     0x90800000, 0x48000000,  1      ; Memory control register
        DCD     0x90900000, 0x49000000,  1      ; USB Host register
        DCD     0x90A00000, 0x4A000000,  1      ; Interrupt Control register
        DCD     0x90B00000, 0x4B000000,  1      ; DMA control register
        DCD     0x90C00000, 0x4C000000,  1      ; Clock & Power register
        DCD     0x90D00000, 0x4D000000,  1      ; LCD control register
        DCD     0x90E00000, 0x4E000000,  1      ; NAND flash control register
        DCD     0x90F00000, 0x4F000000,  1      ; Camera control register
        DCD     0x91000000, 0x50000000,  1      ; UART control register
        DCD     0x91100000, 0x51000000,  1      ; PWM timer register
        DCD     0x91200000, 0x52000000,  1      ; USB device register
        DCD     0x91300000, 0x53000000,  1      ; Watchdog Timer register
        DCD     0x91400000, 0x54000000,  1      ; IIC control register
        DCD     0x91500000, 0x55000000,  1      ; IIS control register
        DCD     0x91600000, 0x56000000,  1      ; I/O Port register
        DCD     0x91700000, 0x57000000,  1      ; RTC control register
        DCD     0x91800000, 0x58000000,  1      ; A/D convert register
        DCD     0x91900000, 0x59000000,  1      ; SPI register
        DCD     0x91A00000, 0x5A000000,  1      ; SD Interface register
        DCD     0x92000000, 0x00000000, 32      ; 32 MB SROM(SRAM/ROM) BANK 0
        DCD     0x00000000, 0x00000000,  0      ; end of table
那么是不是说我的板子上的内存是对应BANK6? 但是我在代码里没有找到选择Bank的代码,硬件上就是直接将相应的一个片选地址拉低,就是表示用片内的sdram了. 如果我外接了一个sdram,那么如何确定这个sdram是被分配到了哪一个bank呢?
知道的帮忙解答下了,现在对这个内存似懂非懂的,感觉很压抑啊...
此帖出自WindowsCE论坛
多谢楼上几位的答复,我找人要硬件图看看.只要能把地址对上就好^_^  详情 回复 发表于 2007-11-10 08:43
顶下LZ,对这个似懂非懂
此帖出自WindowsCE论坛
首先,2440上SDRAM只能使用Bank6/7,而且6和7必须有相同的大小,这是硬件决定的,2440的规格书上写的很清楚。。至于选择Bank,你问问你的硬件工程师就清楚了。
此帖出自WindowsCE论坛
看下硬件连接原理图中关于SDRAM的片选连接部份
代码中不用选择BANK,访问属于此BANK的地址时,此BANK的片选管脚会自动拉低
你可以在代码中找到初始化相关BANK的代码
此帖出自WindowsCE论坛
66
此帖出自WindowsCE论坛
