5596|5
编译bsp时报错:unsupported relocation type [复制链接]
编译提示信息:
ldppc -o tmp.o -X -N  -e sysGxClockInit sysGxClock.o \
    -Ttext 00C00000 bootConfig.o version.o sysALib.o sysLib.o    \
    --start-group -LD:\embed\Tornado2.2\target\lib\ppc\PPC440\gnu_x5 -LD:\embed\Tornado2.2
\target\lib\ppc\PPC440\common_x5 -LD:\embed\Tornado2.2\target\lib\ppc\PPC440\gnu -LD:\embe
d\Tornado2.2\target\lib\ppc\PPC440\common romExtras.a    -larch  -lcplus  -lgnucplus  -lvx
com  -larch  -lcommoncc  -ldcc  -ldrv  -lgcc  -lnet  -los  -lrpc  -ltffs  -lusb  -lvxfusio
n  -lvxmp  -lwdb  -lwind  -lwindview D:\embed\Tornado2.2\target\lib\libPPC440gnuvx.a --end
-group \
     -defsym wrs_kernel_rom_size=0x000100000  -T D:\embed\Tornado2.2\target\h\tool\gnu\lds
cripts\link.DOTBOOTRAM
romExtras.a(sysClkLib.o): In function `sysInByte':
sysClkLib.o(.text+0x0): multiple definition of `sysInByte'
sysLib.o(.text+0x2cdc): first defined here
\cygdrive\d\embed\Tornado2.2\host\x86-win32\bin\ldppc: Warning: size of symbol `sysInByte'
changed from 24 to 16 in sysClkLib.o
make.exe: *** [bootrom.Z.s] Error 0x1
Done.
麻烦哪位大侠给点思路.
Tornado需要安装补丁。  详情 回复 发表于 2009-2-13 18:04
上一个贴错了,这个才是:
ccppc -mcpu=440 -mstrict-align -ansi  -O2 -fvolatile -fno-builtin -I\h   -I. -IC:\Tornado2
.2\target\config\all -IC:\Tornado2.2\target\h -IC:\Tornado2.2\target\src\config -IC:\Torna
do2.2\target\src\drv -DCPU=PPC440 -DTOOL_FAMILY=gnu -DTOOL=gnu  -DROM_BASE_ADRS=0xfff00000
  -DRAM_HIGH_ADRS=0x00C00000 -DRAM_LOW_ADRS=0x00010000 -DROM_SIZE=0x00100000    -P -xassem
bler-with-cpp -c -o romInit.o romInit.s
\cygdrive\c\DOCUME~1\Sun\LOCALS~1\Temp\ccegAE9e.s: Assembler messages:
\cygdrive\c\DOCUME~1\Sun\LOCALS~1\Temp\ccegAE9e.s:10025: Error: unsupported relocation typ
e
\cygdrive\c\DOCUME~1\Sun\LOCALS~1\Temp\ccegAE9e.s:10026: Error: unsupported relocation typ
e
\cygdrive\c\DOCUME~1\Sun\LOCALS~1\Temp\ccegAE9e.s:10038: Error: unsupported relocation typ
e
make.exe: *** [romInit.o] Error 0x1
Done.
81
好像没那么简单,呵呵.
47
DMSUN,你的问题解决了吗?我也遇到同样的问题,请问你是如何解决的,
遇到同一问题,关注
Tornado需要安装补丁。
