3659|9
sd卡驱动 [复制链接]
在SD卡驱动程序中有这样一个定义:WCHAR *szRegKey_SDMMC = L"Drivers\\SDCARD\\ClientDrivers\\Class\\SDMemory_Class";
在中断线程中,通过这条语句调用szRegKey_SDMMC:
hDevice = ActivateDeviceEx(szRegKey_SDMMC, NULL, 0, NULL); /* 加载SD/MMC卡驱动 */
整个中断线程函数如下:
static DWORD WINAPI  SDMMCDetectThread(LPVOID pArgument)
RETAILMSG(1, (TEXT("Entering SDMMCDetectThread done.\r\n")));
Sleep (1000); // Same as CF driver, wait for 1 sencond to avoid data abort.
while(1)
Sleep(20);
if (((v_pIOPregs->GPGDAT & (0x01 < < 10)) != 0) && (SDMMC_DETECT == 1))
RETAILMSG(1, (TEXT("INFO: SD/MMC Card is removed.\r\n")));
SDMMC_DETECT = 0;
DeactivateDevice(hDevice); /* 卸载SD/MMC卡驱动 */
InterruptDone(g_CardInsertSysIntr); /* 中断结束 */
if ((SDMMC_DETECT == 0) && ((v_pIOPregs->GPGDAT & (0x01 < < 10)) == 0))
RETAILMSG(1, (TEXT("INFO: SD/MMC Card is detected.\r\n")));
SDMMC_DETECT = 1;
else
WaitForSingleObject(hSDEvent, INFINITE); /* 等待卡的下一次插入/拨出事件 */
return 1;
WCHAR *szRegKey_SDMMC = L"Drivers\\SDCARD\\ClientDrivers\\Class\\SDMemory_Class"; 这个是注册表信息吧
我搜到的注册表信息如下:
[HKEY_LOCAL_MACHINE\Drivers\SDCARD\ClientDrivers\Class\SDMemory_Class]
  "Dll"="SDMemory.dll"
  "Prefix"="DSK"
  "FSD"="FATFS.DLL"
  "IOCTL"=dword:4            ; DISK_IOCTL_INITIALIZE, sent to driver by DeviceManager
  "BlockTransferSize"=dword:40 ; Send no more than 64 blocks of data per bus transfer
  ;"SingleBlockWrites"=dword:1 ; alternatively force the driver to use single block access
  "Profile"="SDMemory"
  "IClass"=multi_sz:"{A4E7EDDA-E575-4252-9D6B-4195D48BB865}",
                    "{A32942B7-920C-486b-B0E6-92A702A99B35}"
    ; MMC Storage Class Driver
[HKEY_LOCAL_MACHINE\Drivers\SDCARD\ClientDrivers\Class\MMC_Class]
  "Prefix"="DSK"
  "FSD"="FATFS.DLL"
  "Profile"="MMC"
  ; setting for SD bus driver to load driver
[HKEY_LOCAL_MACHINE\Drivers\SDCARD\HostControllers\SDSC]
  "Dll"="SDCSDCard.dll"
  "Prefix"="SDC"
请问大家:
1、是不是我在驱动程序SDMMCDetectThread中定义WCHAR *szRegKey_SDMMC = L"Drivers\\SDCARD\\ClientDrivers\\Class\\
为WCHAR *szRegKey_SDMMC = L"Drivers\\SDCARD\\ClientDrivers\\Class\\MMC_Class
那么就调用加载SDMemory.dll这个文件了??
2、SDMemory.dll、SDMemory.dll、SDCSDCard.dll这三个流驱动的原文件在哪里呢???
UP!!!!!!!!!!  详情 回复 发表于 2008-7-19 14:25
up
95
1.是的,但是sd和mmc用的是同一个dll,定义哪个都一样
2.在\WINCE500\PUBLIC\COMMON\OAK\DRIVERS\SDCARD下面
如果我需要用一个SD的无线网卡
需要选哪个呢?
是不是应该是这个:
  "Prefix"="SDC"
也就是在驱动程序的WCHAR *szRegKey_SDMMC = L"Drivers\\SDCARD\\ClientDrivers\\Class\\XXX
改为:WCHAR *szRegKey_SDMMC = L"Drivers\\SDCARD\\ClientDrivers\\Class\\SDSC
然后添加上无线网卡的驱动??
谢谢!
1. 不一定是。
你看Class\\下面还有三个分支,分别对应SD Memory, MMC Memroy, SD Card。其中SD Memory和MMC Memory是一样的,就是我们通常说的MMC卡,SD卡,存储用的。这个都是加载SDMemroy.dll.
而SD Card其实是指SDIO接口的功能卡,比如网卡,DVB无线电视卡之类的。这些驱动和SD Memory的驱动不完全一样,所以需要加载SDCSDCard.dll
2. 位置如2楼所说,这是通用的标准定义。
如果我把驱动改为:
WCHAR *szRegKey_SDMMC = L"Drivers\\SDCARD\\ClientDrivers\\Class\\SDSC";
while(1)
Sleep(20);
SDMMC_DETECT = 0;
SDMMC_DETECT = 1;
else
return 1;
那我的这个驱动加载的不就是SDIO了吗??
是这样吗?
另:我要用SD的无线网卡是不是需要首先加载SDIO这个驱动,然后安装无线网卡的驱动才可以??
谢谢大家!
81
查看本帖全部讨论,请登录或者注册
查看本帖全部讨论,请登录或者注册
75
查看本帖全部讨论,请登录或者注册
77
查看本帖全部讨论,请登录或者注册
