2579|1
MMU地址映射 [复制链接]
void mem_mapping_linear(void)
    unsigned long descriptor_index, section_base, sdram_base, sdram_size;
    sdram_base=0x30000000;
    sdram_size=0x 4000000;
    for (section _base= sdram_base,descriptor_index = section _base>>20;
         section _base < sdram_base+ sdram_size;
         descriptor_index+=1;section _base +=0x100000)
         *(mmu_tlb_base + (descriptor_index)) = (section _base>>20) | MMU_OTHER_SECDESC;
谁能帮我解释一下上面的代码,他是从虚拟的0x30000000~0x33f00000映射到物理的0x30000000~0x33f00000,我如果想映射到物理的0x00000000~0x00400000,改怎么做呢,谢谢啦。
void mem_mapping_linear(void)    {        unsigned long descriptor_index, section_base, sdram_base, sdram_size;        sdram_base=0x00000000;        sdram_size=0x04000000;        mmu_vbase = 0x30000000;     for (section _base= mmu_vbase, descriptor_index = section _base>>20;            section _base < mmu_vbase + sdram_size;            descriptor_index+=1, section _base +=0x100000)        {            *(mmu_tlb_base + (descriptor_index)) = (section _base>>20) | MMU_OTHER_SECDESC;        }    }    详情 回复 发表于 2008-10-24 09:36
