4491|6
如何让驱动不自动加载? [复制链接]
WINCE下如何能让驱动不在启动时加载,是修改注册表还是有什么其它的方法?我想在应用程序里用ActivateDeviceEx手动加载。
你没有BSP的吗?你道德得保证重启之后注册表能保存。  详情 回复 发表于 2008-11-1 09:16
Windows中是把驱动程序注册表键中的Start值设置为3,CE不知道是否相同。
82
你把驱动从注册表中HKEY_Local_Machine/Drivers/BuiltIn下面拿掉。应该就不会被自动加载了。
103
从HKEY_Local_Machine/Drivers/BuiltIn下删除后重启又自动加载了,而且BuiltIn下又出现了该驱动的键值,不知为何。而且我的驱动每次加载运行到KernelIoControl函数都会出现Data Abort数据中止异常,请高手们指教。我的GIO_Init()函数代码如下:
        g_DmaBuffer = (DWORD *)VirtualAlloc(0, DMA_Buffer_Size, MEM_RESERVE, PAGE_NOACCESS);
        if (g_DmaBuffer == NULL)
                RETAILMSG(1,(TEXT("For g_DmaBuffer : VirtualAlloc failed! error code %d\r\n"),GetLastError()));
        else
                if (!VirtualCopy((PVOID)g_DmaBuffer, (PVOID)(DMA_Buffer_PA>> 8),
                        TOTAL_LENGTH, PAGE_PHYSICAL | PAGE_READWRITE | PAGE_NOCACHE))
                        RETAILMSG(1,(TEXT("For g_DmaBuffer: VirtualCopy failed!\r\n")));
        RETAILMSG(1,(TEXT("DMA Buffer Pointer g_DmaBuffer: 0x%08X\r\n"),g_DmaBuffer));
        RETAILMSG(1,(TEXT("Set DMA/CAM Clock Register\r\n")));
        unsigned int dmaclk;
        clkdiv1 = (clkdiv1 & ~(0xf<<26))|((CAMDIV & 0xf)<< 26);
        dmaclk = 96000000/(CAMDIV+1);
        RETAILMSG(1,(TEXT("DMA Clock(Hz):%d\r\n"),dmaclk));
        hclkcon |= (1<<8)|(0x3F<<0); //DMA channel 0~6 HCLK enable//HCLK into camera enable
        sclkcon |= (1<<11); // Camera clock enable
        misccr  = (misccr & ~(7<<8))|(3<<8);
        RETAILMSG(1,(TEXT("MISCCR Register output: 0x%08X\r\n"),misccr));
        g_dwDMAIrq = IRQ_DMA5;
        if (!KernelIoControl(IOCTL_HAL_REQUEST_SYSINTR, &g_dwDMAIrq, sizeof(UINT32),
            (LPVOID)(g_vDmaISTData->g_dwDMASysIrq), sizeof(UINT32), NULL))
                RETAILMSG(1, (TEXT("ERROR: GIO_INIT: Failed to request sysintr value for DMA interrupt.\r\n")));
                return FALSE;
        RETAILMSG(1,(TEXT("INFO: GIO_INIT: Mapped Irq 0x%x to SysIntr 0x%x.\r\n"), g_dwDMAIrq, g_vDmaISTData->g_dwDMASysIrq));
        InitializeCriticalSection(&dma_Lock);
        RETAILMSG(1,(TEXT("[GIO_Init]: Initialize Critical Section.\r\n")));
        g_vDmaISTData->abort = TRUE;
        RETAILMSG(1,(TEXT("Start to request sysintr\r\n")));
        if (!InitDmaInterrupt())
        //RETAILMSG(1,(TEXT("Fail to initialize DMA interrupt event\r\n")));
        return FALSE;
63
你从哪里拿掉的?直接从设备上?
你从你的.reg文件里面把它去掉,然后重新Build image。
你没有BSP的吗?
闂佸搫琚崕鍐诧耿閸涙潙瀚夋い鎺嗗亾缂佹锕㈠畷妤呭Ω閳轰礁濮ら柣鐘遍檷閸斿繘顢欓幋锔芥櫖鐎光偓閸愭儳娈�闂佽皫鍡╁殭缂傚稄鎷�闂佺懓鐡ㄩ悧鐐哄焵椤掑﹥瀚�濠电偛顦崝宀勫船閿燂拷
有奖直播:当AI遇见仿真,会有什么样的电子行业革新之路?
首场直播:Simcenter AI 赋能电子行业研发创新
直播时间:04月15日14:00-14:50
