2383|3
77
问下删除注册表SubKey的问题 [复制链接]
我现在在WinCE的Local Machine下的software下建立了subkey,AA,然后我就行用代码删除subkey,用registrykey=registry.loacalmachine.openkey("software",true);然后registrykey.deletsubkey("AA"),老是提示没有权限去删除,请问该怎么做好?
你这是用什么语言操作注册表? 用CE提供的注册表操作Function肯定可以的,具体使用查一下帮助文档吧 RegCloseKey This function releases the handle of the specified key. RegCreateKeyEx This function creates the specified key. If the key already exists in the registry, the function opens it. RegDeleteKey This function deletes a named subkey from the specified registry key.   RegDeleteValue This function removes a named value from the specified registry key. RegEnumKeyEx This function enumerates subkeys of the specified open registry key. RegEnumValue This function enumerates the values for the specified open registry key. RegFlushKey This function writes all the attributes of the specified open registry key into the registry.   RegOpenKeyEx This function opens the specified key.   RegQueryInfoKey This function retrieves information about a specified registry key.   RegQueryValueEx This function retrieves the type and data for a specified value name associated with an open registry key.   RegSetValueEx This function stores data in the value field of an open registry key.     详情 回复 发表于 2008-11-15 00:02
79
怎么没人回答
人呢?
65
你这是用什么语言操作注册表?
