6615|8
tornado2.2.1_mips编译代码时出现"installation problem, cannot exec 'get_feature.exe': In [复制链接]
具体提示:
if exist D:/CCVIEW/CODE_S~1/SOURCE~1/Build/DCS-4500-26T-50T/dep/platform/zebos/pal.dep  rm -f D:/CCVIEW/CODE_S~1/SOURCE~1/Build/DCS-4500-26T-50T/dep
if exist D:/CCVIEW/CODE_S~1/SOURCE~1/Build/DCS-4500-26T-50T/dep/platform/zebos/pal.dep.x  rm -f D:/CCVIEW/CODE_S~1/SOURCE~1/Build/DCS-4500-26T-50T/d
"touch D:/CCVIEW/CODE_S~1/SOURCE~1/Build/DCS-4500-26T-50T/dep/platform/zebos/pal.dep.x file"
"begin make dep-pal_ctype.o dep-pal_inet.o dep-pal_kernel.o dep-plat_kernel_fwd_ctrl.o dep-pal_daemon.o dep-pal_log.o dep-pal_utils.o dep-pal_memory
.o dep-pal_socket.o dep-pal_stdlib.o dep-pal_string.o dep-pal_semaphore.o dep-pal_time.o dep-pal_sock_ll.o dep-pal_if_types.o dep-pal_if_stats.o dep
-pal_sock_raw.o dep-pal_sock_udp.o dep-plat_if_netlink.o dep-plat_rt_netlink.o dep-plat_rtread_netlink.o "
C:\Tornado221\host\x86-win32\bin\make.exe dep-pal_ctype.o dep-pal_inet.o dep-pal_kernel.o dep-plat_kernel_fwd_ctrl.o dep-pal_daemon.o dep-pal_log.o
dep-pal_utils.o dep-pal_memory.o dep-pal_socket.o dep-pal_stdlib.o dep-pal_string.o dep-pal_semaphore.o dep-pal_time.o dep-pal_sock_ll.o dep-pal_if_
types.o dep-pal_if_stats.o dep-pal_sock_raw.o dep-pal_sock_udp.o dep-plat_if_netlink.o dep-plat_rt_netlink.o dep-plat_rtread_netlink.o
make.exe[6]: Entering directory `D:\CCVIEW\CODE_S~1\SOURCE~1\MATRIX~1\ZebOS\pal\vxworks'
echo_cygwin.exe -n "D:/CCVIEW/CODE_S~1/SOURCE~1/Build/DCS-4500-26T-50T/obj/platform/zebos/pal/" >> D:/CCVIEW/CODE_S~1/SOURCE~1/Build/DCS-4500-26T-50
C:\Tornado221\host\x86-win32\bin\ccMIPS.exe -M  -I../.. -I../../pal/vxworks -I../../pal/api -I../../lib -I../../platform/vxworks   -I../../../includ
e -I../../../include/os_MIPS -I../../../include/public -DBROADCOM -DCONFIG_DEBUG_DUMP -I../../pal -I../../lib -I../../nsm -I../../imi -I../../l2_she
lld -nostdinc -fno-builtin -funsigned-char -fno-signed-char -fvolatile -fno-for-scope -DCPU=MIPS32 -DHAVE_ISO_MACRO_VARARGS -DMIPS32_BOARD -mips2 -D
WORDS_BIGENDIAN -DMULTIPATH_NUM=1  -O2 -DCPU=MIPS32 -DCPU_FAMILY=MIPS -DDCN  -DDCS4500   -DBE_HOST=1   -D__KERNEL__  -include D:/CCVIEW/CODE_S~1/SOU
RCE~1/Build/DCS-4500-26T-50T/dcnos_defines.h -DHAVE_MD5 -DHAVE_IMI -DHAVE_NSM -DHAVE_L2_SHELLD -DHAVE_NETLINK -DHAVE_SNMP -DHAVE_SNMP_RESTART -DHAVE
_MULTI_TOPOLOGY  -I../../nsm pal_ctype.c >> D:/CCVIEW/CODE_S~1/SOURCE~1/Build/DCS-4500-26T-50T/dep/platform/zebos/pal.dep.x
ccMIPS: installation problem, cannot exec `c:/Tornado221/host/x86-win32/bin/../lib/gcc-lib/mips-wrs-vxworks/2.96-mips3264-010729/get_feature.exe': I
nvalid argument
ccMIPS: installation problem, cannot exec `c:/Tornado221/host/x86-win32/bin/../lib/gcc-lib/mips-wrs-vxworks/2.96-mips3264-010729/cpp0.exe': Invalid
argument
make.exe[6]: *** [dep-pal_ctype.o] Error 0x1
make.exe[6]: Leaving directory `D:\CCVIEW\CODE_S~1\SOURCE~1\MATRIX~1\ZebOS\pal\vxworks'
make.exe[5]: *** [D:/CCVIEW/CODE_S~1/SOURCE~1/Build/DCS-4500-26T-50T/dep/platform/zebos/pal.dep] Error 0x2
make.exe[5]: Leaving directory `D:\CCVIEW\CODE_S~1\SOURCE~1\MATRIX~1\ZebOS\pal\vxworks'
make.exe[4]: *** [pal-vxworks-dep] Error 0x2
make.exe[4]: Leaving directory `D:\CCVIEW\CODE_S~1\SOURCE~1\MATRIX~1\ZebOS\pal'
make.exe[3]: *** [all-../../pal] Error 0x2
make.exe[3]: Leaving directory `D:\CCVIEW\CODE_S~1\SOURCE~1\MATRIX~1\ZebOS\platform\vxworks'
make.exe[2]: *** [all] Error 0x2
make.exe[2]: Leaving directory `D:\CCVIEW\CODE_S~1\SOURCE~1\MATRIX~1\ZebOS'
make[1]: *** [platform_zebos_all] Error 0x2
make[1]: Leaving directory `D:\CCVIEW\CODE_S~1\SOURCE~1\MATRIX~1'
make: *** [all] Error 0x2
lz要干嘛?  详情 回复 发表于 2008-4-30 21:41
59
这个可能是你系统没有配置好吧?
建议重新安装一次。。
64
已经重新安装过了,还是有同样的问题!不知到需要配置什么呢?
61
找一下这个目录下有没有这个执行程序
有!
执行C:\Tornado221\host\x86-win32\bin\ccMIPS.exe -M  -I../.. -I../../pal/vxworks -I../../pal/api -I../../lib -I../../platform/vxworks   -I../../../includ
时,ccmips会自己去调用get_feature.exe, 但是调用时出错了!
63
没有人遇到过这样的问题么?
路径中是不是包含了中文或者空格?
79
以后需再关注,现在先帮你顶一下
lz要干嘛?
有奖直播:当AI遇见仿真,会有什么样的电子行业革新之路?
首场直播:Simcenter AI 赋能电子行业研发创新
直播时间:04月15日14:00-14:50
