2948|1
编译错误在VS2005,但是OK在VC6 [复制链接]
Dear all,
recently I transform my project from vc6 to vs2005, it occur to the following error:
d:\Program Files\Microsoft Visual Studio 8\VC\ce\include\xtree(1172) : error C3848: expression having type 'const CFormatter::ltwsz' would lose some const-volatile qualifiers in order to call 'bool CFormatter::ltwsz::operator ()(const wchar_t *,const wchar_t *)'
        d:\Program Files\Microsoft Visual Studio 8\VC\ce\include\xtree(1167) : while compiling class template member function 'std::_Tree_nod<_Traits>::_Node *std::_Tree<_Traits>::_Lbound(const wchar_t *const &) const'
        with
            _Traits=std::_Tmap_traits>,false>
        d:\Program Files\Microsoft Visual Studio 8\VC\ce\include\map(82) : see reference to class template instantiation 'std::_Tree<_Traits>' being compiled
        with
        d:\ccm_wa\jethzh\nav_sdk#arbrbg#1-jethzh#uida35611\tovs2005\nav_sdk\source\hmi\Formatter.h(201) : see reference to class template instantiation 'std::map<_Kty,_Ty,_Pr>' being compiled
        with
            _Kty=const wchar_t *,
            _Ty=std::wstring,
            _Pr=CFormatter::ltwsz
my source code as follows:
#ifndef __FORMATTER_H__
#define __FORMATTER_H__
#ifdef _MT
#  undef _MT
#  include
#  define _MT 1
#else
#  include
#endif
#include
#include
#include "ResourceManager.h"
#include "Utils.h"
class CFormatter : public CUtils
  public:
        CFormatter() {}
        /** @brief Constructor, setting format from string ID. */
        template
        CFormatter(FormatType format)
                SetFormat(format);
        inline CFormatter& SetFormat(const wchar_t* format)
                m_fmt = format;
                return *this;
        inline CFormatter& SetFormat(std::wstring format)
                m_fmt = format;
                return *this;
        inline CFormatter& SetFormat(UINT format)
                m_fmt = (LPCTSTR)(CResourceManager::GetInstance()->GetString(format));
                return *this;
        operator const std::wstring();
        operator const wchar_t*();
        void Get(CString& strResult);
        template
        CFormatter& Add(LPCTSTR key, LPCTSTR format, ValueType value)
                CString buf;
                buf.Format(format, value);
                m_map[key] = buf;
                return *this;
        template
        CFormatter& Add(LPCTSTR key, ValueType value)
                m_map[key] = ToWString(value);
                return *this;
  private:
        void Format();
        struct ltwsz
                bool operator()(const wchar_t* left, const wchar_t* right)
                        return wcscmp(left, right) < 0;
        std::wstring m_fmt;
        std::map m_map;
        std::wstring m_res;
#endif //__FORMATTER_H__
see msdn: A variable with a specified const-volatile type can only call member functions defined with same or greater const-volatile qualifications. please modify your code.  详情 回复 发表于 2008-2-16 13:24
see msdn:
