2535|3
TE4210升級內核到2.6.14啟動出錯 [复制链接]
S3C2410 DEVELOP KIT
VIVI version 0.1.4 (root@localhost.localdomain) (gcc version 2.95.2 20000516 (re
lease) [Rebel.com]) #0.1.4 媼 2堎 6 16:31:51 CST 2007
MMU table base address = 0x33DFC000
Succeed memory mapping.
NAND device: Manufacture ID: 0xec, Chip ID: 0x76 (Samsung K9D1208V0M)
Found saved vivi parameters.
CS8900 - type: 630e, rev: a00
CS8900 - status: ad6 (EEPROM present)
Setting MAC address...
Display format changed to VGA 640X480 mode
Press Return to start the LINUX now, any other key for vivi
Copy linux kernel from 0x00030000 to 0x30008000, size = 0x001c0000 ... done
zImage magic = 0x016f2818
Setup linux parameters at 0x30000100
linux command line is: "noinitrd root=/dev/mtdblock3 init=/linuxrc console=ttySA
C0,115200"
MACH_TYPE = 193
NOW, Booting Linux......
Uncompressing Linux.............................................................
...... done, booting the kernel.
Linux version 2.6.14 (root@mis-client) (gcc version 3.4.1) #1 Wed Nov 18 17:16:3
6 CST 2009
CPU: ARM920Tid(wb) [41129200] revision 0 (ARMv4T)
Machine: SMDK2410
ATAG_INITRD is deprecated; please update your bootloader.
Memory policy: ECC disabled, Data cache writeback
CPU S3C2410A (id 0x32410002)
S3C2410: core 200.000 MHz, memory 100.000 MHz, peripheral 50.000 MHz
S3C2410 Clocks, (c) 2004 Simtec Electronics
CLOCK: Slow mode (1.500 MHz), fast, MPLL on, UPLL on
USB Control, (c) 2006 sbc2410
CPU0: D VIVT write-back cache
CPU0: I cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets
CPU0: D cache: 16384 bytes, associativity 64, 32 byte lines, 8 sets
Built 1 zonelists
Kernel command line: noinitrd root=/dev/mtdblock3 init=/linuxrc console=ttySAC0,
115200
irq: clearing subpending status 00000003
irq: clearing subpending status 00000002
PID hash table entries: 512 (order: 9, 8192 bytes)
timer tcon=00000000, tcnt a2c1, tcfg 00000200,00000000, usec 00001eb8
Console: colour dummy device 80x30
Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Memory: 64MB = 64MB total
Memory: 62720KB available (1672K code, 347K data, 92K init)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
softlockup thread 0 started up.
NET: Registered protocol family 16
S3C2410: Initialising architecture
S3C2410 DMA Driver, (c) 2003-2004 Simtec Electronics
DMA channel 0 at c4800000, irq 33
DMA channel 1 at c4800040, irq 34
DMA channel 2 at c4800080, irq 35
DMA channel 3 at c48000c0, irq 36
NetWinder Floating Point Emulator V0.97 (double precision)
devfs: 2004-01-31 Richard Gooch (rgooch@atnf.csiro.au)
devfs: boot_options: 0x1
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
Console: switching to colour frame buffer device 80x25
fb0: Virtual frame buffer device, using 1024K of video memory
S3C2410 RTC, (c) 2004 Simtec Electronics
s3c2410_serial0 at MMIO 0x50000000 (irq = 70) is a S3C2410
s3c2410_serial1 at MMIO 0x50004000 (irq = 73) is a S3C2410
s3c2410_serial2 at MMIO 0x50008000 (irq = 76) is a S3C2410
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered
RAMDISK driver initialized: 16 RAM disks of 4096K size 1024 blocksize
S3C24XX NAND Driver, (c) 2004 Simtec Electronics
s3c2410-nand: mapped registers at c4980000
s3c2410-nand: timing: Tacls 10ns, Twrph0 40ns, Twrph1 10ns
NAND device: Manufacturer ID: 0xec, Chip ID: 0x76 (Samsung NAND 64MiB 3,3V 8-bit
NAND_ECC_NONE selected by board driver. This is not recommended !!
Scanning device for bad blocks
Creating 5 MTD partitions on "NAND 64MiB 3,3V 8-bit":
0x00000000-0x00020000 : "vivi"
0x00020000-0x00030000 : "param"
0x00030000-0x001f0000 : "kernel"
0x00200000-0x00600000 : "root"
0x00600000-0x04000000 : "usr"
mice: PS/2 mouse device common for all mice
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 4096 (order: 2, 16384 bytes)
TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP reno registered
TCP bic registered
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,3)
在這裡就死了.
重烧一次根文件系统试下。  详情 回复 发表于 2009-11-20 11:28
各位專家,以上为在把內核編譯好燒到板子後啟動提示錯誤,請各位抽點幫小弟看一下,在此感谢了。
58
好像意思是無法掛載root分區,請各位幫幫忙.
重烧一次根文件系统试下。
