2568|0
PB帮助文档内关于2D硬件加速部分的一处说明 [复制链接]
小弟现在正在做WINCE5.0显示驱动2D硬件加速部分的开发,对PB帮助文档内的一处说明不太理解,即
---Display Driver Extensions---Display Driver Recommendations的最后几行:
The following list shows the display hardware that can accelerate operations, in order of decreasing importance:
1)Solid color fills, specifically blit operations, the pbo->iSolidColor member is not 0xFFFFFFFF.
2)SRCCOPY blit operations.
3)Cursor display, if your run-time image uses a cursor.
4)Solid horizontal and vertical line drawing.
5)Solid line drawing with subpixel precision.
6)Masked SRCCOPY blit operations.
7)Solid general line drawing with subpixel resolution.
其中5和7条的意思,感觉都是画斜的实线,从字面上我看都一样啊。不知其背后有啥区别?有哪位高人朋友知道的话告诉一声,先谢谢了!
其他几条我的理解是:
1)实色填充
2)搬移操作
3)光标显示
4)画水平或垂直的实线
6)带透明色处理的搬移
不知准不准确。
