3404|2
我用ATmega16控制LCD1602显示数数据,为什么无显示。但在仿真软件上却可以。单片机频率为4M [复制链接]
/*?????¨??RS*/
#define RS_CLR        PORTB&=~(1 << PB1)/*????????*/
#define RS_SET        PORTB|=(1 << PB1)/*????????*/
/*RW*/
#define RW_CLR        PORTC&=~(1 << PC5)/*????????*/
#define RW_SET        PORTC|=(1 << PC5)/*????????*/
/*E*/
#define  E_CLR        PORTC&=~(1 << PC4)/*????????*/
#define  E_SET        PORTC|=(1 << PC4)/*????????*/
#define  XS  PORTA
void busy()        //?ì?é??????
  unsigned char i,j;
   for(i=0;i<200;i++)
      for(j=0;j<10;j++);
void inorder(unsigned char order)                           //???ü??
      XS=order;
      RS_CLR;          //RS=0;
      RW_CLR;          //RW=0;
      E_SET;          //E=1;
      busy();
      E_CLR;          //E=0;
void indata(unsigned char datar)                            //??????
            XS=datar;
      RS_SET;                   //RS=1;
      RW_CLR;                   //RW=0;
          E_SET;         //E=1;
          busy();
          E_CLR        ;               //E=0;
void initlcd (void)
         inorder(0x01);
     inorder(0X38);                //8??2??5X7???ó
     inorder(0X0f);                //?????÷??????±ê??????????
     inorder(0X06);                //??×?????????±ê×???????
         inorder(0x01);                //??????
以上程序为"1602.h"文件
#include
#define  uchar        unsigned char
#define  uint        unsigned int
#include "1602.h"
void port_init(void)
                DDRA  = 0xFF;
                //PORTA = 0x00;
                DDRB  = 0xFF;
                //PORTB = 0x00;
                DDRC  = 0xFF;
                //PORTC = 0x00;
void main()
                 port_init();
                 initlcd ();
            inorder(0x80);                     //??±ê???òLCD???????×????
                  indata('A');                    //????
                indata('B');                    //????
                indata('C');                    //????
                indata('D');                    //????
                 inorder(0xc0);                    //??±ê???òLCD???????×????
                  indata(0x30);                    //????
                while(1);
记号.   详情 回复 发表于 2009-3-10 12:41
LCD1602操作时,对控制器每次读写之前,必须进行读写检测,确保STA7为0,防止lcd处于Busy状态。
75
记号.
