3204|4
77
s3c2410开发板上跑WINCE想使用第二个串口驱动需要怎么改啊? [复制链接]
用的是广嵌的GEC2410,他们提供的串口驱动第二个串口居然不能用
如果要做第二个串口驱动需要怎么改啊?
看看Blog 里面有详细的步骤 和楼上一样   详情 回复 发表于 2008-7-5 12:17
82
WINCE5.0增加第二串口
――基于TE2410开发板平台(http://www.witech.com.cn)
需要修改的文件:
\INC\oalintr.h
\KERNEL\HAL\ARM\armint.c
\KERNEL\HAL\cfw.c
\DRIVERS\SERIAL\ser2410_hw.c
\DRIVERS\SERIAL\ser2410_ser.c
\FILES\platform.reg
1,中断源 \INC\oalintr.h
         添加:#define SYSINTR_SERIAL1  (SYSINTR_FIRMWARE+23)
         修改:
MapIrq2SysIntr(DWORD _Irq)
    if( _Irq<=23 )
        return ( SYSINTR_FIRMWARE + _Irq );
    else
        return (0xffffffff);
2,arminit.c
         在else if(IntPendVal == INTSRC_UART0)后添加如下代码:
else if(IntPendVal == INTSRC_UART1)
                   SubIntPendVal = s2410INT->rSUBSRCPND;
                   if(SubIntPendVal & INTSUB_ERR1)
                            s2410INT->rINTSUBMSK |= INTSUB_ERR1;
                   else if(SubIntPendVal & INTSUB_RXD1)
                            s2410INT->rINTSUBMSK |= INTSUB_RXD1;
                   else if(SubIntPendVal & INTSUB_TXD1)
                            s2410INT->rINTSUBMSK |= INTSUB_TXD1;
                   else
                            return(SYSINTR_NOP);
                   s2410INT->rINTMSK |= BIT_UART1;
                   if (s2410INT->rINTPND & BIT_UART1) s2410INT->rINTPND  = BIT_UART1;
                   return(SYSINTR_SERIAL1);
3,cfw.c
         分别在OEMInterruptEnable,OEMInterruptDisable,OEMInterruptDone三个函数中模仿串口0添加串口1的中断处理代码。
4,ser2410_hw.c(修改数据结构以根据注册表中的配置情况进行端口匹配)
         分别修改S2410_SetSerialIOP,SL_Init函数如下:
S2410_SetSerialIOP(PVOID   pHead)                 // @parm points to device head
         PS2410_UART_INFO   pHWHead   = (PS2410_UART_INFO)pHead;
         PSER_INFO     pHWHead1  = (PSER_INFO)pHead;
         RETAILMSG(DEBUGMODE, (TEXT("S2410_SetSerialIOP \r\n")));
         if(pHWHead1->dwIOBase == 0x50004000)
                   EnterCriticalSection(&(pHWHead->RegCritSec));
                   v_pIOPregs->rGPHCON &= ~(0x3<<8 | 0x3<<10 );
                   v_pIOPregs->rGPHCON |= (0x2<<8 | 0x2<<10 );
                   v_pIOPregs->rGPHCON |= (0x2<<0 | 0x2<<2 );
                   v_pIOPregs->rGPHUP  |= 0x03;
                   pHWHead->rDTRport = (volatile unsigned int *)&(v_pIOPregs->rGPHDAT);
                   pHWHead->rDSRport = (volatile unsigned int *)&(v_pIOPregs->rGPHDAT);
                   pHWHead->DtrPortNum = 0;
                   pHWHead->DsrPortNum = 1;
         else if(pHWHead1->dwIOBase == 0x50008000)
                   v_pIOPregs->rGPHCON &= ~( 0x3<<12 | 0x3<<14);
                   v_pIOPregs->rGPHCON |= ( 0x2<<12 | 0x2<<14);
                   v_pIOPregs->rGPHUP  &= ~0xc0;
         else
                   v_pIOPregs->rGPHCON &= ~(0x3<<0 | 0x3<<2 | 0x3<<4 | 0x3<<6);
                   v_pIOPregs->rGPHCON |= (0x2<<4 | 0x2<<6);
         LeaveCriticalSection(&(pHWHead->RegCritSec));
         SL_Init函数中:(修改两处)
if ( pHWHead->UseIrDA )
                   pHWHead->bINT = BIT_UART2;
                   pHWHead->bTxINT = INTSUB_TXD2;
                   pHWHead->bRxINT = INTSUB_RXD2;
                   pHWHead->bErrINT = INTSUB_ERR2;
                   pHWHead->s2410SerReg = (S2410_UART_REG *)v_pUART2regs;
                  pRegBase = (PUCHAR)pHWHead->s2410SerReg;
         else
                            pHWHead->bINT = BIT_UART1;
                            pHWHead->bTxINT = INTSUB_TXD1;
                            pHWHead->bRxINT = INTSUB_RXD1;
                            pHWHead->bErrINT = INTSUB_ERR1;
                            pHWHead->s2410SerReg = (S2410_UART_REG *)v_pUART1regs;
                   else
                            pHWHead->bINT = BIT_UART0;
                            pHWHead->bTxINT = INTSUB_TXD0;
                            pHWHead->bRxINT = INTSUB_RXD0;
                            pHWHead->bErrINT = INTSUB_ERR0;
                            pHWHead->s2410SerReg = (S2410_UART_REG *)v_pUART0regs;
                   pHWHead->pUFTXH = (volatile unsigned char *)&(v_pUART2regs->rUTXH);
                   pHWHead->pUFRXH = (volatile unsigned char *)&(v_pUART2regs->rURXH);
         else
                            pHWHead->pUFTXH = (volatile unsigned char *)&(v_pUART1regs->rUTXH);
                            pHWHead->pUFRXH = (volatile unsigned char *)&(v_pUART1regs->rURXH);
                   else
                            pHWHead->pUFTXH = (volatile unsigned char *)&(v_pUART0regs->rUTXH);
                            pHWHead->pUFRXH = (volatile unsigned char *)&(v_pUART0regs->rURXH);
78
5,ser2410_ser.c
在const HWOBJ IoObj{……}后面添加:
         const HWOBJ IoObj1 = {
         THREAD_AT_INIT,
         SYSINTR_SERIAL1,
         (PHW_VTBL) &IoVTbl
修改:
const PCHWOBJ HWObjects[] = {
         &IoObj,
         &IoObj1,
     &IrObj
         修改:
PHWOBJ GetSerialObject(DWORD DeviceArrayIndex)
     PHWOBJ pSerObj;
     RETAILMSG(DEBUGMODE,(TEXT("IRDA : GetSerialObject\r\n")));
     IRDA = DeviceArrayIndex;
     if ( DeviceArrayIndex == 0 )
              pSerObj = (PHWOBJ)(&IoObj);
     else if( DeviceArrayIndex == 1 )
              pSerObj = (PHWOBJ)(&IoObj1);
     else
              pSerObj = (PHWOBJ)(&IrObj);
     return (pSerObj);
6,注册表\FILES\platform.reg
                  在串口0后添加:
[HKEY_LOCAL_MACHINE\Drivers\BuiltIn\SER2410_1]
         "DeviceArrayIndex"=dword:1
         "Irq"=dword:17
         "IoBase"=dword:50004000
         "IoLen"=dword:2C
         "Prefix"="COM"
         "Dll"="SER2410.Dll"
         "Order"=dword:2
         "Priority"=dword:0
         "Port"="COM2:"
         "DeviceType"=dword:0  ; null modem
         "FriendlyName"="S2410 COM2"
;        "Index"=dword:2
         "IClass"="{A32942B7-920C-486b-B0E6-92A702A99B35}"
[HKEY_LOCAL_MACHINE\Drivers\BuiltIn\SER2410_1\Unimodem]
         "Tsp"="Unimodem.dll"
         "FriendlyName"="SER2410 UNIMODEM"
         "DevConfig"=hex: 10,00, 00,00, 05,00,00,00, 10,01,00,00, 00,4B,00,00, 00,00, 08, 00, 00, 00,00,00,00
7,注:
         由于TE2410开发板上没有红外,所以代码中红外部分是没有用的。
         启动后查看注册表[HKEY_LOCAL_MACHINE\Drivers\Active]可以看到刚添加的串口对应的设备名是COMX,可通过修改Order及Index的值来改变X的值(COM2被USB占用,最好设成COM3...)。
66
楼上正解,添加到3个也是用这种办法
