; SD Memory Storage class driver
[HKEY_LOCAL_MACHINE\Drivers\SDCARD\ClientDrivers\Class\SDMemory_Class]
"Dll"="SDMemory.dll"
"Prefix"="DSK"
"BlockTransferSize"=dword:40 ; send no more than 64 blocks of data per bus transfer
"Profile"="SDMemory"
"IClass"=multi_sz:"{A4E7EDDA-E575-4252-9D6B-4195D48BB865}",
"{A32942B7-920C-486b-B0E6-92A702A99B35}"
我是在CE6下,路径是\PUBLIC\COMMON\OAK\DRIVERS\BLOCK\MSFLASHFMD\SDNPCI\SDNPCID,有一个reg文件,内容如下
; Copyright (c) Microsoft Corporation. All rights reserved.
; Use of this sample source code is subject to the terms of the Microsoft
; license agreement under which you licensed this sample source code. If
; you did not accept the terms of the license agreement, you are not
; authorized to use this sample source code. For the terms of the license,
; please see the license agreement between you and Microsoft or, if applicable,
; see the LICENSE.RTF on your install media or the root of your tools installation.
; THE SAMPLE SOURCE CODE IS PROVIDED "AS IS", WITH NO WARRANTIES.
; This file is to be included in platform.reg if required.
[HKEY_LOCAL_MACHINE\Drivers\BuiltIn\PCI\Instance\NAND_Flash]
"Profile"="MSFlash"
"Order"=dword:0
"FriendlyName"="SD NAND FLASH Driver"
"Dll"="sdnpcid.dll"
"Prefix"="DSK"
