3833|6
51单片机移植uC/OS-II编译出错 [复制链接]
本人在编译uC/OS-II的时候,出现了一个比较难缠的编译错误,望高手指点!
先看OS_CPU.H文件,该头文件包含与cpu有关的定义
  1. typedef unsigned char  INT8U;         //无符号8位数
复制代码
OS_CFG.H文件,是uC/OS-II的配置文件
  1. #define OS_MAX_EVENTS             2
  2. #define OS_Q_EN                   1
  3. #define OS_MAX_QS                 2
  4. #define OS_MBOX_EN                1
  5. #define OS_SEM_EN                 1
  6. #define OS_MUTEX_EN               1
复制代码
uCOS_II.H文件
  1. #define  OS_EVENT_EN       (((OS_Q_EN > 0) && (OS_MAX_QS > 0))|| (OS_MBOX_EN > 0) || (OS_SEM_EN > 0) || (OS_MUTEX_EN > 0))
  2. #if (OS_EVENT_EN > 0) && (OS_MAX_EVENTS > 0)
  3. typedef struct {
  4.     INT8U   OSEventType;                   /* Type of event control block (see OS_EVENT_TYPE_???)      */
  5.     INT8U   OSEventGrp;                    /* Group corresponding to tasks waiting for event to occur  */
  6.     INT16U  OSEventCnt;                    /* Semaphore Count (not used if other EVENT type)           */
  7.     void   *OSEventPtr;                    /* Pointer to message or queue structure                    */
  8.     INT8U   OSEventTbl[OS_EVENT_TBL_SIZE]; /* List of tasks waiting for event to occur                 */
  9. } OS_EVENT;
  10. #endif
  11. #if OS_MBOX_EN > 0
  12. typedef struct {
  13.     void   *OSMsg;                         /* Pointer to message in mailbox                            */
  14.     INT8U   OSEventTbl[OS_EVENT_TBL_SIZE]; /* List of tasks waiting for event to occur                 */
  15.     INT8U   OSEventGrp;                    /* Group corresponding to tasks waiting for event to occur  */
  16. } OS_MBOX_DATA;
  17. #endif
  18. #if OS_MBOX_QUERY_EN > 0
  19. [color=#FF0000]INT8U         OSMboxQuery(OS_EVENT *pevent, OS_MBOX_DATA *pdata);[/color]
  20. #endif
复制代码
INCLUDES.H文件,包含所有的头文件
  1. #include
  2. #include
  3. #include
复制代码
APP.C文件:应用程序
  1. #include
  2. #define  TASK_STK_SIZE                 512       /* Size of each task's stacks (# of WORDs)            */
  3. OS_STK           TaskStartStk[TASK_STK_SIZE];
  4. void   TaskStart(void *data);                         /* Function prototypes of Startup task           */
  5. void main (void)
  6. {
  7.     OSInit();                                              /* Initialize uC/OS-II                      */
  8.     OSTaskCreate(TaskStart, (void *)0, &TaskStartStk[TASK_STK_SIZE - 1], 0);
  9.     OSStart();                                             /* Start multitasking                       */
  10. }
  11. void TaskStart (void *data)
  12. {
  13. }
复制代码
注意:限于篇幅,只贴出了与错误有关的代码!
编译时UCOS_II.H的INT8U OSMboxQuery(OS_EVENT *pevent, OS_MBOX_DATA *pdata);出现:..\SOURCE\UCOS_II.H(547): error C141: syntax error near ')'错误,本人不解,望高手指点,感激不尽!
呵呵,谢谢,正解,当时没有注意,已经解决了~~  详情 回复 发表于 2009-12-18 13:03
77
OS_MBOX_QUERY_EN ....这个符号定义了没有?
   51有必要移植系统吗。学习了,第一次看到。
很诡异.........
pdata........是C51关键字......改个名字就OK了..........
LS正解 你是照书上移植的吗 书上写了要改名字的啊
87
引用 4 楼 great_bug 的回复:
