2331|2
62
LoadBitmap问题 [复制链接]
switch (wMsg)
    case   WM_CREATE:    hInstance = ((LPCREATESTRUCT) lParam)->hInstance ;
                         hBitmap = LoadBitmap (hInstance, MAKEINTRESOURCE(bitmap_point)) ;
                         GetObject (hBitmap, sizeof (BITMAP), &bitmap) ;
                         cxSource = bitmap.bmWidth ;
                         cySource = bitmap.bmHeight ;
                         return 0 ;
    case   WM_PAINT:     hdc = BeginPaint (hWnd, &ps) ;
                         hdcMem = CreateCompatibleDC (hdc) ;
                         SelectObject (hdcMem, hBitmap) ;
                         for (y = 0 ; y < cyClient ; y += cySource)
                            for (x = 0 ; x < cxClient ; x += cxSource)
                                 BitBlt (hdc, x, y, cxSource, cySource, hdcMem, 0, 0, SRCCOPY) ;
                         DeleteDC (hdcMem) ;
                         EndPaint (hWnd, &ps) ;
                         return 0 ;
        case   WM_SIZE:  cxClient = LOWORD (lParam) ;
                         cyClient = HIWORD (lParam) ;
                         return 0 ;
        case   WM_HIBERNATE:  DoHibernateMain (hWnd, wMsg, wParam, lParam);    //
                                  return 0 ;
        case   WM_ACTIVATE:   DoActivateMain (hWnd, wMsg, wParam, lParam); //发此消息给应用程序哪个窗口是激活的,哪个是非激活的;
                                                  return 0 ;
        case   WM_DESTROY:    DeleteObject (hBitmap) ;
                    //      PostQuitMessage (0);                         //一个窗口被销毁
                          return 0 ;
        case   WM_LBUTTONDOWN: bitmap_point = IDB_BITMAP1;
                           //hInstance = ((LPCREATESTRUCT) lParam)->hInstance ;
                                   InvalidateRect (hWnd, NULL, TRUE) ;
                                   return 0 ;
        return DefWindowProc (hWnd, wMsg, wParam, lParam);
可是不知道为什么?在case   WM_CREATE: 中,hBitmap = LoadBitmap (hInstance, MAKEINTRESOURCE(bitmap_point)) ;
有返回值,可在case   WM_LBUTTONDOWN:中,hBitmap = LoadBitmap (hInstance, MAKEINTRESOURCE(bitmap_point)) ;的返回值总是为0,请高手指点啊!!
LoadBitmap后没有释放??  详情 回复 发表于 2008-1-28 09:07
用GetLastError()看看具体的错误 是什么吧。
58
LoadBitmap后没有释放??
