4020|3
atmel usb转串 使用通用驱动问题 [复制链接]
芯片atmel9260
使用atmel提供的usb CDC demo,windows端使用usbser.sys 通用驱动。
能认到设备,PC发送数据给终端很正常,终端发送数据给PC,必须发送了4096字节后sscom才显示收到4096字节的数据。
请教问题会出现在哪里?
inf如下。
; $Id: 6119.inf,v 1.1.2.1 2006/12/05 08:33:25 danielru Exp $
[Version]                                                       ; Version section
Signature="$CHICAGO$"
Class=Ports                                                     ; This is a serial port driver
ClassGuid={4D36E978-E325-11CE-BFC1-08002BE10318}                ; Associated GUID
Provider=%ATMEL%                                                ; Driver is provided by ATMEL
DriverVer=09/12/2006,1.1.1.5                                    ; Driver version 1.1.1.5 published on 23 February 2007
[DestinationDirs]                                               ; DestinationDirs section
DefaultDestDir=12                                               ; Default install directory is \drivers or \IOSubSys
[Manufacturer]                                                  ; Manufacturer section
%ATMEL%=AtmelMfg                                                ; Only one manufacturer (ATMEL), models section is named
        ; AtmelMfg
[AtmelMfg]                                                      ; Models section corresponding to ATMEL
%USBtoSerialConverter%=USBtoSer.Install,USB\VID_03EB&PID_6119   ; Identifies a device with ATMEL Vendor ID (03EBh) and
        ; Product ID equal to 6119h. Corresponding Install section
        ; is named USBtoSer.Install
[USBtoSer.Install]                                              ; Install section
include=mdmcpq.inf
CopyFiles=FakeModemCopyFileSection
AddReg=USBtoSer.AddReg                                          ; Registry keys to add are listed in USBtoSer.AddReg
[USBtoSer.AddReg]                                               ; AddReg section
HKR,,DevLoader,,*ntkern                                         ;
HKR,,NTMPDriver,,usbser.sys
HKR,,EnumPropPages32,,"MsPorts.dll,SerialPortPropPageProvider"
[USBtoSer.Install.Services]                                     ; Services section
AddService=usbser,0x00000002,USBtoSer.AddService                ; Assign usbser as the PnP driver for the device
[USBtoSer.AddService]                                           ; Service install section
DisplayName=%USBSer%                                            ; Name of the serial driver
ServiceType=1                                                   ; Service kernel driver
StartType=3                                                     ; Driver is started by the PnP manager
ErrorControl=1                                                  ; Warn about errors
ServiceBinary=%12%\usbser.sys                                   ; Driver filename
[Strings]                                                       ; Strings section
ATMEL="ATMEL Corp."                                             ; String value for the ATMEL symbol
USBtoSerialConverter="AT91 USB to Serial Converter"             ; String value for the USBtoSerialConverter symbol
USBSer="USB Serial Driver"                                      ; String value for the USBSer symbol
恭喜楼主,是不是USBtoSer的问题啊  详情 回复 发表于 2009-9-9 10:21
已解决。
75
真快啊,刚想说我的机器把GPS的数据通过USB的CDC可以正常发送到PC上边。
恭喜了!
95
