180|2
459
【AG32VH407开发板】创建FreeRTOS系统 [复制链接]
在项目中创建FreeRTOS系统。
一、复制文件
将AgRV_pio\platforms\AgRV\examples\freeRTOS\src\FreeRTOSConfig.h 文件复制到AgRV_pio\platforms\AgRV\examples\example目录下。
测试的工程在AgRV_pio\platforms\AgRV\examples\example目录
二、程序部分
2.1、修改paltform.ini
在此此处增加支持的FreeRTOS 系统
2.2、fun_task.c
测试FreeRTOS任务程序
  • #include "example.h"
  • #include "led/led.h"
  • #include "key/key.h"
  • #include "timer/mtimer.h"
  • #include "lcd/jlx12864g.h"
  • #include "oled/oled.h"
  • #include "FreeRTOS.h"
  • #include "task.h"
  • #include "queue.h"
  • #include "timers.h"
  • #include "semphr.h"
  • #define START_TASK_PRO 1
  • #define START_STK_SIZE 128
  • TaskHandle_t StartTask_Handler;
  • #define TASK1_PRIO 4
  • #define TASK1_STK_SIZE 128
  • static TaskHandle_t Task1Task_Handler = NULL;
  • #define TASK2_PRIO 3
  • #define TASK2_STK_SIZE 128
  • static TaskHandle_t Task2Task_Handler = NULL;
  • void start_task(void *pvParameters);
  • void task1(void *pvParameters);
  • void task2(void *pvParameters);
  • void task_create(void)
  • //start_task
  • xTaskCreate((TaskFunction_t )start_task,
  • (const char* )"start_task",
  • (uint16_t )START_STK_SIZE,
  • (void* )NULL,
  • (UBaseType_t )START_TASK_PRO,
  • (TaskHandle_t* )&StartTask_Handler);
  • vTaskStartScheduler();
  • taskENTER_CRITICAL();
  • //task1
  • xTaskCreate((TaskFunction_t )task1,
  • (const char* )"task1",
  • (uint16_t )TASK1_STK_SIZE,
  • (void* )NULL,
  • (UBaseType_t )TASK1_PRIO,
  • (TaskHandle_t* )&Task1Task_Handler);
  • //task2
  • xTaskCreate((TaskFunction_t )task2,
  • (const char* )"task2",
  • (uint16_t )TASK2_STK_SIZE,
  • (void* )NULL,
  • (UBaseType_t )TASK2_PRIO,
  • (TaskHandle_t* )&Task2Task_Handler);
  • taskEXIT_CRITICAL();
  • vTaskDelete(StartTask_Handler);
  • //task1
  • while (1)
  • printf("task1 run ...\r\n");
  • vTaskDelay(200);
  • //task2
  • while (1)
  • printf("task2 run ...\r\n");
  • vTaskDelay(100);
  • void vApplicationTickHook(void)
  • return;
  • void vApplicationGetIdleTaskMemory(StaticTask_t **ppxIdleTaskTCBBuffer,
  • StackType_t **ppxIdleTaskStackBuffer,
  • uint32_t *pulIdleTaskStackSize)
  • static StaticTask_t xIdleTaskTCB;
  • static StackType_t uxIdleTaskStack[configMINIMAL_STACK_SIZE];
  • *ppxIdleTaskTCBBuffer = &xIdleTaskTCB;
  • *ppxIdleTaskStackBuffer = uxIdleTaskStack;
  • *pulIdleTaskStackSize = configMINIMAL_STACK_SIZE;
  • void vApplicationGetTimerTaskMemory(StaticTask_t **ppxTimerTaskTCBBuffer,
  • StackType_t **ppxTimerTaskStackBuffer,
  • uint32_t *pulTimerTaskStackSize)
  • static StaticTask_t xTimerTaskTCB;
  • static StackType_t uxTimerTaskStack[configTIMER_TASK_STACK_DEPTH];
  • *ppxTimerTaskTCBBuffer = &xTimerTaskTCB;
  • *ppxTimerTaskStackBuffer = uxTimerTaskStack;
  • *pulTimerTaskStackSize = configTIMER_TASK_STACK_DEPTH;
2.3、fun_task.h
2.4、example.c
三、运行结果
编译后,下载ve和code代码后,串口输出如下
使用官方的SDK包中的FreeRTOS系统还是比较方便的,官方已经把底层都移植好了,只需要编写应用程序。
把配置文件都给配好了,那就相当的方便,不知道他是如何感知文件路径的。   详情 回复 发表于 昨天 04:59
赞赏
查看全部赞赏
点赞 关注(1)
7181
在paltform.ini文件中有定义文件路径  详情 回复 发表于 昨天 10:29
459
lugl4313820 发表于 2025-3-18 04:59 把配置文件都给配好了,那就相当的方便,不知道他是如何感知文件路径的。
猜你喜欢
报名最后2天:ADI 最新低功耗 MCU 及其解决方案详解
直播时间:3月20日(本周四) 上午10:00
活动奖励:双肩包、充电宝、小夜灯
