4045|7
sst39vf1601挂掉了。。。 [复制链接]
唉,sst39vf1601芯片坏了
jflash-s3c44b0x v1.0 (2003-8-26)
origin made by J.D&T Co.,Ltd ( You Young-chang )
origin made by ATMEL Co.,Ltd
modified by Yun Duck Bea
> FileName : bios.bin
Please select Flash Type:1: HY29LV160; 2: SST39VF1601
Flash Type: 2
> Init JTAG Interface...
> ARM7TDMI ID Test...
  The target's ID code is : 0x1F0F0F0F
> Change Debug Mode ARM7TDMI...
  The value in the debug status register is 0x00000009
  The ARM is in debug mode
> Setting Registers for S3C44B0X...
> Detect Flash ID
  SST39VF1601 Fail Get Manufacture Code :   F0
> Flash Write...
  Start Address : 0x00000
  Erase Start...
  Erase Blocks -> [11]
Erase Sector 0, range [0 ~ 7ff]HALF_WORD           |    0%
Erase Sector 1, range [800 ~ fff]HALF_WORD
Erase Sector 2, range [1000 ~ 17ff]HALF_WORD
Erase Sector 3, range [1800 ~ 1fff]HALF_WORD
Erase Sector 4, range [2000 ~ 27ff]HALF_WORD
Erase Sector 5, range [2800 ~ 2fff]HALF_WORD
Erase Sector 6, range [3000 ~ 37ff]HALF_WORD
Erase Sector 7, range [3800 ~ 3fff]HALF_WORD
Erase Sector 8, range [4000 ~ 47ff]HALF_WORD
Erase Sector 9, range [4800 ~ 4fff]HALF_WORD
Erase Sector 10, range [5000 ~ 57ff]HALF_WORD
  Erase Success...
  Write Start...
  Write Success...
  Flash Write End.....
  Verify Start...
  Verify Error 00003000 [E3A00000:E2000000]         /   29%
  Verify Success...
program end
那位高手能妙手回春,帮帮小弟一把。。。
可明明写着能擦写100000次啊,我离这个数字还远着呢!  详情 回复 发表于 2009-11-20 20:30
67
坏了 ,还想要做什么,呵呵
81
如果真的是坏了就没办法了,难道说一张纸被烧成灰还想让它重装变成一张纸吗?
79
楼主想要大家帮你做什么,可以说清楚点。如果是硬件坏了那只能换一片。
63
唉,看来芯片算是挂了。。。
我想弄清楚到底怎么坏了,给个原因啊,死也要弄个明白啊。。。
64
sst的片子是不太稳定
83
