[兆易GD32H759I-EVAL]3.熟悉I2C、SPI操作EEPROM和SPI FLASH,移植FlashDB数据库
1、I2C
GD32H759系列MCU搭载了4个I2C通讯接口模块;支持主从机模式;支持7位地址、10位地址和广播地址;作为从机时,还支持多个7位从机地址的配置;通讯速率上支持100kHz的标速、400kHz的快速和1MHz的高速这3种通讯速率,同时还兼容SMBus3.0和PMBus1.3等功能。
2.原理图
GD32H759I-EVAL板载了一颗I2C接口的EEPROM芯片,型号为AT24C02C-SSHM-T;与MCU的I2C1接口连接通讯,分配的引脚为PH4和PB11,如下所示:
3.EEPROM功能代码
- #include "bsp_eeprom.h"
- #include "platform.h"
- void bsp_EepromInit(void)
- rcu_periph_clock_enable(RCU_GPIOB);
- rcu_periph_clock_enable(RCU_GPIOH);
- rcu_periph_clock_enable(RCU_I2C1);
- gpio_af_set(GPIOH, GPIO_AF_4, GPIO_PIN_4);
- gpio_af_set(GPIOB, GPIO_AF_4, GPIO_PIN_11);
- gpio_mode_set(GPIOH, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_4);
- gpio_output_options_set(GPIOH, GPIO_OTYPE_OD, GPIO_OSPEED_60MHZ, GPIO_PIN_4);
- gpio_mode_set(GPIOB, GPIO_MODE_AF, GPIO_PUPD_PULLUP, GPIO_PIN_11);
- gpio_output_options_set(GPIOB, GPIO_OTYPE_OD, GPIO_OSPEED_60MHZ, GPIO_PIN_11);
- i2c_timing_config(I2C1, 0x01, 0x07, 0x00);
- i2c_master_clock_config(I2C1, 0x2D, 0x87);
- i2c_enable(I2C1);
- void bsp_EepromI2cBusReset()
- GPIO_BC(GPIOH) |= GPIO_PIN_4;
- GPIO_BC(GPIOB) |= GPIO_PIN_11;
- gpio_mode_set(GPIOH, GPIO_MODE_OUTPUT, GPIO_PUPD_NONE, GPIO_PIN_4);
- gpio_output_options_set(GPIOH, GPIO_OTYPE_PP, GPIO_OSPEED_60MHZ, GPIO_PIN_4);
- gpio_mode_set(GPIOB, GPIO_MODE_OUTPUT, GPIO_PUPD_NONE, GPIO_PIN_11);
- gpio_output_options_set(GPIOB, GPIO_OTYPE_PP, GPIO_OSPEED_60MHZ, GPIO_PIN_11);
- __NOP();
- __NOP();
- __NOP();
- __NOP();
- __NOP();
- GPIO_BOP(GPIOH) |= GPIO_PIN_4;
- __NOP();
- __NOP();
- __NOP();
- __NOP();
- __NOP();
- GPIO_BOP(GPIOB) |= GPIO_PIN_11;
- void bsp_EepromWritePage(uint8_t *p_buffer, uint8_t write_address, uint8_t number_of_byte)
- i2c_process_enum state = I2C_START;
- uint16_t timeout = 0;
- uint8_t end_flag = 0;
- while (!end_flag)
- switch (state)
- case I2C_START:
- i2c_master_addressing(I2C1, 0xA0, I2C_MASTER_TRANSMIT);
- i2c_transfer_byte_number_config(I2C1, number_of_byte + 1);
- I2C_STAT(I2C1) |= I2C_STAT_TBE;
- i2c_automatic_end_enable(I2C1);
- while (i2c_flag_get(I2C1, I2C_FLAG_I2CBSY) && (timeout < 20000))
- timeout++;
- if (timeout < 20000)
- i2c_start_on_bus(I2C1);
- timeout = 0;
- state = I2C_SEND_ADDRESS;
- else
- bsp_EepromI2cBusReset();
- timeout = 0;
- state = I2C_START;
- printf("i2c bus is busy in page write!\n");
- break;
- case I2C_SEND_ADDRESS:
- while ((!i2c_flag_get(I2C1, I2C_FLAG_TBE)) && (timeout < 20000))
- timeout++;
- i2c_data_transmit(I2C1, write_address);
- timeout = 0;
- state = I2C_TRANSMIT_DATA;
- else
- timeout = 0;
- printf("i2c master sends address timeout in page write!\n");
- break;
- case I2C_TRANSMIT_DATA:
- while (number_of_byte--)
- while ((!i2c_flag_get(I2C1, I2C_FLAG_TI)) && (timeout < 20000))
- timeout++;
- i2c_data_transmit(I2C1, *p_buffer);
- p_buffer++;
- timeout = 0;
- state = I2C_STOP;
- else
- timeout = 0;
- printf("i2c master sends data timeout in page write!\n");
- return;
- break;
- case I2C_STOP:
- while ((!i2c_flag_get(I2C1, I2C_FLAG_STPDET)) && (timeout < 20000))
- timeout++;
- i2c_flag_clear(I2C1, I2C_FLAG_STPDET);
- timeout = 0;
- state = I2C_END;
- end_flag = 1;
- else
- timeout = 0;
- printf("i2c master sends stop signal timeout in page write!\n");
- break;
- default:
- end_flag = 1;
- timeout = 0;
- printf("i2c master sends start signal in page write!\n");
- break;
- void bsp_EepromReadBuffer(uint8_t *p_buffer, uint8_t read_address, uint16_t number_of_byte)
- uint32_t nbytes_reload = 0;
- uint32_t timeout = 0;
- uint8_t restart_flag = 0;
- uint8_t first_reload_flag = 1;
- uint8_t last_reload_flag = 0;
- while (!end_flag)
- switch (state)
- case I2C_START:
- if (0 == restart_flag)
- i2c_transfer_byte_number_config(I2C1, 1);
- i2c_automatic_end_disable(I2C1);
- timeout++;
- timeout = 0;
- else
- timeout = 0;
- printf("i2c bus is busy in read!\n");
- else
- restart_flag = 0;
- break;
- timeout++;
- i2c_data_transmit(I2C1, read_address);
- timeout = 0;
- state = I2C_RESTART;
- else
- timeout = 0;
- printf("i2c master sends data timeout in read!\n");
- break;
- case I2C_RESTART:
- while ((!i2c_flag_get(I2C1, I2C_FLAG_TC)) && (timeout < 20000))
- timeout++;
- i2c_master_addressing(I2C1, 0xA0, I2C_MASTER_RECEIVE);
- i2c_reload_enable(I2C1);
- timeout = 0;
- state = I2C_RELOAD;
- restart_flag = 1;
- else
- timeout = 0;
- printf("i2c master sends EEPROM's internal address timeout in read!\n");
- break;
- case I2C_RELOAD:
- if (number_of_byte > 255)
- number_of_byte = number_of_byte - 255;
- nbytes_reload = 255;
- else
- nbytes_reload = number_of_byte;
- last_reload_flag = 1;
- if (1 == first_reload_flag)
- i2c_transfer_byte_number_config(I2C1, nbytes_reload);
- if (1 == last_reload_flag)
- last_reload_flag = 0;
- if (number_of_byte <= 255)
- i2c_reload_disable(I2C1);
- first_reload_flag = 0;
- else
- while ((!i2c_flag_get(I2C1, I2C_FLAG_TCR)) && (timeout < 20000))
- timeout++;
- timeout = 0;
- else
- timeout = 0;
- printf("i2c master reload data timeout in read!\n");
- break;
- timeout++;
- while (nbytes_reload)
- if (i2c_flag_get(I2C1, I2C_FLAG_RBNE))
- *p_buffer = i2c_data_receive(I2C1);
- p_buffer++;
- nbytes_reload--;
- timeout = 0;
- if (I2C_CTL1(I2C1) & I2C_CTL1_RELOAD)
- timeout = 0;
- else
- timeout = 0;
- state = I2C_STOP;
- else
- timeout = 0;
- printf("i2c master read data timeout in read!\n");
- break;
- case I2C_STOP:
- timeout++;
- timeout = 0;
- state = I2C_END;
- end_flag = 1;
- else
- timeout = 0;
- printf("i2c master sends stop signal timeout in read!\n");
- break;
- default:
- end_flag = 1;
- timeout = 0;
- printf("i2c master sends start signal in read!\n");
- break;
- void bsp_EepromWriteBuffer(uint8_t *p_buffer, uint8_t write_address, uint16_t number_of_byte)
- uint8_t number_of_page = 0, number_of_single = 0, address = 0, count = 0;
- address = write_address % 8;
- count = 8 - address;
- number_of_page = number_of_byte / 8;
- number_of_single = number_of_byte % 8;
- if (0 == address)
- while (number_of_page--)
- bsp_EepromWritePage(p_buffer, write_address, 8);
- PLATFORM_DelayMs(5);
- write_address += 8;
- p_buffer += 8;
- if (0 != number_of_single)
- bsp_EepromWritePage(p_buffer, write_address, number_of_single);
- else
- if (number_of_byte < count)
- bsp_EepromWritePage(p_buffer, write_address, number_of_byte);
- else
- number_of_byte -= count;
- if (0 != count)
- bsp_EepromWritePage(p_buffer, write_address, count);
- write_address += count;
- p_buffer += count;
- p_buffer += 8;
- void bsp_EepromTest(void)
- uint8_t EepromWriteBuffer[256];
- uint8_t EepromReadBuffer[256];
- printf("\r\n");
- printf("\r\nEEPROM Writing...");
- for (uint16_t i = 0; i < 256; i++)
- if ((i % 16) == 0)
- printf("\r\n");
- EepromWriteBuffer[i] = i;
- printf("0x%02X ", EepromWriteBuffer[i]);
- bsp_EepromWriteBuffer(EepromWriteBuffer, 0, 256);
- printf("\r\n");
- printf("\r\nEEPROM Reading...");
- bsp_EepromReadBuffer(EepromReadBuffer, 0, 256);
- printf("\r\n");
- if (EepromReadBuffer[i] != EepromWriteBuffer[i])
- printf("0x%02X ", EepromReadBuffer[i]);
- printf("\r\nError : data read and write aren't matching!!!");
- return;
- printf("\r\n");
- printf("\r\nEEPROM Test Pass!!!");
4.EEPROM运行结果
5.SPI
GD32H759系列MCU搭载了最多6个SPI通讯接口模块和2个OSPI通讯接口模块;对于SPI接口,具有全双工、半双工、以及单工的主、从工作模式;支持4到32位的数据帧格式,有独立的发送和接收FIFO缓冲区,还支持多主机和多从机的通讯组网;OSPIM全称是OSPI I/O管理器,支持对OSPI全IO矩阵引脚进行分配管理,它支持2个SPI的单线、双线、四线和八线接口方式,支持两个端口进行引脚分配,完全可编程IO矩阵,可按功能能引脚进行配置
6.原理图
GD32H759I-EVAL板载了一颗8线SPI接口的SPI FLASH芯片,型号为GD25X512MEBIRY;与MCU的OSPI接口连接通讯,分配的引脚如下所示:
7.移植SFUD
- #include <sfud.h>
- #include <stdarg.h>
- #include <string.h>
- #include "gd32h7xx.h"
- static char log_buf[256];
- void sfud_log_debug(const char *file, const long line, const char *format, ...);
- typedef struct
- uint32_t spix;
- uint32_t cs_gpiox;
- uint32_t cs_gpio_pin;
- } spi_user_data, *spi_user_data_t;
- spi_user_data spi4 =
- .spix = SPI4,
- .cs_gpiox = GPIOF,
- .cs_gpio_pin = GPIO_PIN_6,
- static void spi_lock(const sfud_spi *spi)
- static void spi_unlock(const sfud_spi *spi)
- static void retry_delay_1ms(void)
- PLATFORM_DelayMs(1);
- static sfud_err spi_write_read(const sfud_spi *spi, const uint8_t *write_buf, size_t write_size, uint8_t *read_buf, size_t read_size)
- sfud_err result = SFUD_SUCCESS;
- uint8_t send_data = 0, read_data = 0;
- spi_user_data_t spi_dev = (spi_user_data_t)spi->user_data;
- if (write_size)
- SFUD_ASSERT(write_buf);
- if (read_size)
- SFUD_ASSERT(read_buf);
- spi_nss_output_enable(spi_dev->spix);
- if (write_size)
- for (size_t i = 0; i < write_size; i++)
- while (RESET == spi_i2s_flag_get(spi_dev->spix, SPI_FLAG_TP))
- spi_i2s_data_transmit(spi_dev->spix, write_buf[i]);
- while (RESET == spi_i2s_flag_get(spi_dev->spix, SPI_FLAG_RP))
- read_data = spi_i2s_data_receive(spi_dev->spix);
- if (read_size)
- memset((uint8_t *)read_buf, 0xFF, read_size);
- for (size_t i = 0; i < read_size; i++)
- spi_i2s_data_transmit(spi_dev->spix, send_data);
- read_buf[i] = spi_i2s_data_receive(spi_dev->spix);
- spi_nss_output_disable(spi_dev->spix);
- return (result);
- #ifdef SFUD_USING_QSPI
- static sfud_err qspi_read(const struct __sfud_spi *spi,
- uint32_t addr,
- sfud_qspi_read_cmd_format *qspi_read_cmd_format,
- uint8_t *read_buf,
- size_t read_size)
- return (result);
- #endif /* SFUD_USING_QSPI */
- sfud_err sfud_spi_port_init(sfud_flash *flash)
- if (!strcmp(flash->spi.name, "SPIx"))
- rcu_periph_clock_enable(RCU_GPIOF);
- rcu_periph_clock_enable(RCU_SPI4);
- rcu_spi_clock_config(IDX_SPI4, RCU_SPISRC_PLL0Q);
- gpio_af_set(GPIOF, GPIO_AF_5, GPIO_PIN_6 | GPIO_PIN_9);
- gpio_mode_set(GPIOF, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_6 | GPIO_PIN_9);
- gpio_output_options_set(GPIOF, GPIO_OTYPE_PP, GPIO_OSPEED_60MHZ, GPIO_PIN_6 | GPIO_PIN_9);
- gpio_af_set(GPIOH, GPIO_AF_5, GPIO_PIN_6 | GPIO_PIN_7);
- gpio_mode_set(GPIOH, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_6 | GPIO_PIN_7);
- gpio_output_options_set(GPIOH, GPIO_OTYPE_PP, GPIO_OSPEED_60MHZ, GPIO_PIN_6 | GPIO_PIN_7);
- spi_parameter_struct spi_init_struct;
- spi_i2s_deinit(spi4.spix);
- spi_struct_para_init(&spi_init_struct);
- spi_init_struct.trans_mode = SPI_TRANSMODE_FULLDUPLEX;
- spi_init_struct.device_mode = SPI_MASTER;
- spi_init_struct.data_size = SPI_DATASIZE_8BIT;
- spi_init_struct.clock_polarity_phase = SPI_CK_PL_LOW_PH_1EDGE;
- spi_init_struct.nss = SPI_NSS_SOFT;
- spi_init_struct.prescale = SPI_PSC_16;
- spi_init_struct.endian = SPI_ENDIAN_MSB;
- spi_init(spi4.spix, &spi_init_struct);
- spi_byte_access_enable(spi4.spix);
- flash->spi.wr = spi_write_read;
- flash->spi.lock = spi_lock;
- flash->spi.unlock = spi_unlock;
- flash->spi.user_data = &spi4;
- flash->retry.delay = retry_delay_1ms;
- flash->retry.times = 60 * 1000;
- return (result);
- va_list args;
- va_start(args, format);
- printf("[SFUD](%s:%ld) ", file, line);
- vsnprintf(log_buf, sizeof(log_buf), format, args);
- printf("%s\n", log_buf);
- va_end(args);
- void sfud_log_info(const char *format, ...)
- va_list args;
- printf("[SFUD]");
- va_end(args);
8.移植FlashDB
- #include <fal.h>
- #include <sfud.h>
- #ifdef FAL_USING_SFUD_PORT
- #ifndef FAL_USING_NOR_FLASH_DEV_NAME
- #define FAL_USING_NOR_FLASH_DEV_NAME "spiflash"
- #endif
- static int init(void);
- static int read(long offset, uint8_t *buf, size_t size);
- static int write(long offset, const uint8_t *buf, size_t size);
- static int erase(long offset, size_t size);
- static sfud_flash_t sfud_dev = NULL;
- struct fal_flash_dev spiflash =
- .name = FAL_USING_NOR_FLASH_DEV_NAME,
- .addr = 0,
- .len = 8 * 1024 * 1024,
- .blk_size = 4096,
- .ops = { init, read, write, erase },
- .write_gran = 1
- extern sfud_flash sfud_spiflash;
- sfud_dev = &sfud_spiflash;
- if (NULL == sfud_dev)
- return (-1);
- spiflash.blk_size = sfud_dev->chip.erase_gran;
- spiflash.len = sfud_dev->chip.capacity;
- return (0);
- assert(sfud_dev);
- assert(sfud_dev->init_ok);
- sfud_read(sfud_dev, spiflash.addr + offset, size, buf);
- return (size);
- assert(sfud_dev);
- if (sfud_write(sfud_dev, spiflash.addr + offset, size, buf) != SFUD_SUCCESS)
- return (-1);
- return (size);
- assert(sfud_dev);
- if (sfud_erase(sfud_dev, spiflash.addr + offset, size) != SFUD_SUCCESS)
- return (-1);
- return (size);
- #endif
9.FlashDB应用
- #include "bsp_spiflash.h"
- #include "sfud.h"
- #include "flashdb.h"
- sfud_flash sfud_spiflash =
- .name = "spiflash",
- .spi.name = "SPI4",
- .chip = { "W25Q64",SFUD_MF_ID_WINBOND, 0x40, 0x17, 8L * 1024L * 1024L, SFUD_WM_PAGE_256B, 4096, 0x20 },
- struct tsdb_param
- uint8_t status;
- uint8_t buffer[12];
- struct fdb_kvdb kvdb = {0};
- struct fdb_tsdb tsdb = {0};
- fdb_time_t fdb_time_stamp = 0;
- fdb_time_t fdb_time_start = 1;
- uint32_t fdb_count = 0;
- static void fdb_lock(fdb_db_t db)
- static void fdb_unlock(fdb_db_t db)
- static fdb_time_t get_time(void)
- return (++fdb_time_stamp);
- static bool query_cb(fdb_tsl_t tsl, void *arg)
- struct fdb_blob blob;
- struct tsdb_param param;
- fdb_tsdb_t db = arg;
- fdb_blob_read((fdb_db_t)db, fdb_tsl_to_blob(tsl, fdb_blob_make(&blob, ¶m, sizeof(param))));
- printf("\r\n[%s][%d] : status: %d, buffer: %s\n", __FUNCTION__, tsl->time, param.status, param.buffer);
- return (false);
- void bsp_SpiFlashInit(void)
- sfud_init();
- if (sfud_device_init(&sfud_spiflash) == SFUD_SUCCESS)
- printf("\r\n%s Success!\r\n", __FUNCTION__);
- else
- printf("\r\n%s Failed!!\r\n", __FUNCTION__); return;
- fdb_err_t result;
- fdb_kvdb_control(&kvdb, FDB_KVDB_CTRL_SET_LOCK, (void *)fdb_lock);
- fdb_kvdb_control(&kvdb, FDB_KVDB_CTRL_SET_UNLOCK, (void *)fdb_unlock);
- result = fdb_kvdb_init(&kvdb, "kvdb", "fdb_kvdb", NULL, NULL);
- if (result != FDB_NO_ERR)
- printf("\r\nkvdb error!!!");
- else
- fdb_kv_get_blob(&kvdb, "count", fdb_blob_make(&blob, &fdb_count, sizeof(fdb_count)));
- if (blob.saved.len == 0)
- fdb_count = 0;
- fdb_kv_set_blob(&kvdb, "count", fdb_blob_make(&blob, &fdb_count, sizeof(fdb_count)));
- else
- fdb_count++;
- printf("\r\nkvdb count : %d", fdb_count);
- fdb_tsdb_control(&tsdb, FDB_TSDB_CTRL_SET_LOCK, (void *)fdb_lock);
- fdb_tsdb_control(&tsdb, FDB_TSDB_CTRL_SET_UNLOCK, (void *)fdb_unlock);
- result = fdb_tsdb_init(&tsdb, "tsdb", "fdb_tsdb", get_time, 15, NULL);
- printf("\r\ntsdb error!!!");
- else
- if (fdb_count == 0)
- fdb_tsl_clean(&tsdb);
- fdb_tsdb_control(&tsdb, FDB_TSDB_CTRL_GET_LAST_TIME, &fdb_time_stamp);
- param.status = fdb_count;
- memcpy(param.buffer, "tsdb demo", 9);
- fdb_tsl_append(&tsdb, fdb_blob_make(&blob, ¶m, sizeof(param)));
- fdb_tsl_iter(&tsdb, query_cb, &tsdb);
10.运行结果
GD32H759I-EVAL板载了一颗8线SPI接口的SPI FLASH芯片,编程方式与我们之前的2线传统SPI接口的编程方式不同,而本次要实现的FlashDB数据库的移植,主要是基于SFUD开源库和FlashDB开源库实现的,当前还没有支持开发板上的这一个颗SPI FLASH芯片,上述的代码是基于普通SPI接口去操作SPI FLASH实现的,在其它项目已经应用实践,主要是分享一下移植的重点和应用部分;后续有机会,在搭载有普通SPI接口操作SPI FLASH的开发板上,可以进行一下测试,看一下运行结果。
11.软件工程
赞赏
查看全部赞赏
