94|0
139
【MCXA156开发板测评】-6-EDMA3例程代码分析 [复制链接]
例程:edma3_ping_pong_transfer
1. 首先进行EDMA3初始化:
 * brief Initializes the eDMA peripheral.
 * This function ungates the eDMA clock and configures the eDMA peripheral according
 * to the configuration structure.
 * param base eDMA peripheral base address.
 * param config A pointer to the configuration structure, see "edma_config_t".
 * note This function enables the minor loop map feature.
void EDMA_Init(EDMA_Type *base, const edma_config_t *config)
    assert(config != NULL);
    assert(FSL_FEATURE_EDMA_INSTANCE_CHANNELn(base) != -1);
    uint32_t tmpreg, i = 0U;
#if !(defined(FSL_SDK_DISABLE_DRIVER_CLOCK_CONTROL) && FSL_SDK_DISABLE_DRIVER_CLOCK_CONTROL)
    /* Ungate EDMA peripheral clock */
    CLOCK_EnableClock(s_edmaClockName[EDMA_GetInstance(base)]);
#endif /* FSL_SDK_DISABLE_DRIVER_CLOCK_CONTROL */
#if defined(EDMA_RESETS_ARRAY)
    RESET_ReleasePeripheralReset(s_edmaResets[EDMA_GetInstance(base)]);
#endif
#if defined(FSL_EDMA_SOC_IP_EDMA) && FSL_EDMA_SOC_IP_EDMA
    /* clear all the enabled request, status to make sure EDMA status is in normal condition */
    EDMA_BASE(base)->ERQ = 0U;
    EDMA_BASE(base)->INT = 0xFFFFFFFFU;
    EDMA_BASE(base)->ERR = 0xFFFFFFFFU;
    /* Configure EDMA peripheral according to the configuration structure. */
    tmpreg = EDMA_BASE(base)->CR;
    tmpreg &= ~(DMA_CR_ERCA_MASK | DMA_CR_HOE_MASK | DMA_CR_CLM_MASK | DMA_CR_EDBG_MASK);
    tmpreg |= (DMA_CR_ERCA(config->enableRoundRobinArbitration) | DMA_CR_HOE(config->enableHaltOnError) |
               DMA_CR_CLM(config->enableContinuousLinkMode) | DMA_CR_EDBG(config->enableDebugMode) | DMA_CR_EMLM(1U));
    EDMA_BASE(base)->CR = tmpreg;
#else
    tmpreg = EDMA_MP_BASE(base)->MP_CSR;
#if defined FSL_FEATURE_EDMA_HAS_GLOBAL_MASTER_ID_REPLICATION && FSL_FEATURE_EDMA_HAS_GLOBAL_MASTER_ID_REPLICATION
    tmpreg = (tmpreg & ~(DMA_MP_CSR_HAE_MASK | DMA_MP_CSR_ERCA_MASK | DMA_MP_CSR_EDBG_MASK | DMA_MP_CSR_GCLC_MASK |
                         DMA_MP_CSR_GMRC_MASK | DMA_MP_CSR_HALT_MASK)) |
             DMA_MP_CSR_GMRC(config->enableMasterIdReplication) | DMA_MP_CSR_HAE(config->enableHaltOnError) |
             DMA_MP_CSR_ERCA(config->enableRoundRobinArbitration) | DMA_MP_CSR_EDBG(config->enableDebugMode) |
             DMA_MP_CSR_GCLC(config->enableGlobalChannelLink);
#else
             DMA_MP_CSR_HAE(config->enableHaltOnError) | DMA_MP_CSR_ERCA(config->enableRoundRobinArbitration) |
             DMA_MP_CSR_EDBG(config->enableDebugMode) | DMA_MP_CSR_GCLC(config->enableGlobalChannelLink);
#endif
    EDMA_MP_BASE(base)->MP_CSR = tmpreg;
#if defined FSL_FEATURE_EDMA_HAS_CHANNEL_CONFIG && FSL_FEATURE_EDMA_HAS_CHANNEL_CONFIG
    /* channel transfer configuration */
    for (i = 0U; i < (uint32_t)FSL_FEATURE_EDMA_INSTANCE_CHANNELn(base); i++)
        if (config->channelConfig[i] != NULL)
            EDMA_InitChannel(base, i, config->channelConfig[i]);
#endif
#endif
2. 紧接着创建一个edma句柄,用于后续操作edma:
EDMA_CreateHandle(&g_DMA_Handle, EXAMPLE_DMA_BASEADDR, DEMO_DMA_CHANNEL_0);
 * brief Creates the eDMA handle.
 * This function is called if using the transactional API for eDMA. This function
 * initializes the internal state of the eDMA handle.
 * param handle eDMA handle pointer. The eDMA handle stores callback function and
 *               parameters.
 * param channel eDMA channel number.
void EDMA_CreateHandle(edma_handle_t *handle, EDMA_Type *base, uint32_t channel)
    assert(handle != NULL);
    assert(channel < (uint32_t)FSL_FEATURE_EDMA_INSTANCE_CHANNELn(base));
    uint32_t edmaInstance;
    edma_tcd_t *tcdRegs;
    /* Zero the handle */
    (void)memset(handle, 0, sizeof(*handle));
    handle->channel = channel;
    /* Get the DMA instance number */
    edmaInstance                        = EDMA_GetInstance(base);
    s_EDMAHandle[edmaInstance][channel] = handle;
    /* Enable NVIC interrupt */
    (void)EnableIRQ(s_edmaIRQNumber[edmaInstance][channel]);
    handle->tcdBase     = EDMA_TCD_BASE(base, channel);
    handle->channelBase = EDMA_CHANNEL_BASE(base, channel);
    handle->base        = base;
       Reset TCD registers to zero. Unlike the EDMA_TcdReset(DREQ will be set),
       CSR will be 0. Because in order to suit EDMA busy check mechanism in
       EDMA_SubmitTransfer, CSR must be set 0.
    tcdRegs                                         = handle->tcdBase;
    EDMA_TCD_SADDR(tcdRegs, EDMA_TCD_TYPE(base))     = 0;
    EDMA_TCD_SOFF(tcdRegs, EDMA_TCD_TYPE(base))      = 0;
    EDMA_TCD_ATTR(tcdRegs, EDMA_TCD_TYPE(base))      = 0;
    EDMA_TCD_NBYTES(tcdRegs, EDMA_TCD_TYPE(base))    = 0;
    EDMA_TCD_SLAST(tcdRegs, EDMA_TCD_TYPE(base))     = 0;
    EDMA_TCD_DADDR(tcdRegs, EDMA_TCD_TYPE(base))     = 0;
    EDMA_TCD_DOFF(tcdRegs, EDMA_TCD_TYPE(base))      = 0;
    EDMA_TCD_CITER(tcdRegs, EDMA_TCD_TYPE(base))     = 0;
    EDMA_TCD_DLAST_SGA(tcdRegs, EDMA_TCD_TYPE(base)) = 0;
    EDMA_TCD_CSR(tcdRegs, EDMA_TCD_TYPE(base))       = 0;
    EDMA_TCD_BITER(tcdRegs, EDMA_TCD_TYPE(base))     = 0;
3. 设置传输完成后的回调函数:
EDMA_SetCallback(&g_DMA_Handle, DMA_Callback, NULL);
/* User callback function for EDMA transfer. */
void DMA_Callback(edma_handle_t *handle, void *param, bool transferDone, uint32_t tcds)
    if (transferDone)
        g_transferDone = true;
4. 关联TCD 即传输控制描述符
EDMA_InstallTCDMemory(&g_DMA_Handle, g_DMA_Tcd, 2);
 * brief Installs the TCDs memory pool into the eDMA handle.
 * This function is called after the EDMA_CreateHandle to use scatter/gather feature. This function shall only be used
 * while users need to use scatter gather mode. Scatter gather mode enables EDMA to load a new transfer control block
 * (tcd) in hardware, and automatically reconfigure that DMA channel for a new transfer.
 * Users need to prepare tcd memory and also configure tcds using interface EDMA_SubmitTransfer.
 * param tcdPool A memory pool to store TCDs. It must be 32 bytes aligned.
 * param tcdSize The number of TCD slots.
void EDMA_InstallTCDMemory(edma_handle_t *handle, edma_tcd_t *tcdPool, uint32_t tcdSize)
    assert(((uint32_t)tcdPool & 0x1FU) == 0U);
    /* Initialize tcd queue attribute. */
    /* header should initial as 1, since that it is used to point to the next TCD to be loaded into TCD memory,
     * In EDMA driver IRQ handler, header will be used to calculate how many tcd has done, for example,
     * If application submit 4 transfer request, A->B->C->D,
     * when A finshed, the header is 0, C is the next TCD to be load, since B is already loaded,
     * according to EDMA driver IRQ handler, tcdDone = C - A - header = 2 - header = 2, but actually only 1 TCD done,
     * so the issue will be the wrong TCD done count will pass to application in first TCD interrupt.
     * During first submit, the header should be assigned to 1, since 0 is current one and 1 is next TCD to be loaded,
     * but software cannot know which submission is the first one, so assign 1 to header here.
    handle->header  = 1;
    handle->tcdUsed = 0;
    handle->tcdSize = (int8_t)tcdSize;
    handle->tcdPool = tcdPool;
5. 设置传输的源地址、目的地址、传输数据量等:
    EDMA_PrepareTransfer(&transferConfig[0], &srcAddr[0], sizeof(srcAddr[0]), &destAddr[0], sizeof(destAddr[0]),
                         sizeof(uint32_t) * HALF_BUFFER_LENGTH, sizeof(uint32_t) * HALF_BUFFER_LENGTH,
                         kEDMA_MemoryToMemory);
    EDMA_PrepareTransfer(&transferConfig[1], &srcAddr[4], sizeof(srcAddr[0]), &destAddr[4], sizeof(destAddr[0]),
    EDMA_SubmitLoopTransfer(&g_DMA_Handle, transferConfig, 2);
    EDMA_StartTransfer(&g_DMA_Handle);
EDMA进行传输前,Destination Buffer内容为:
第一次DMA传输完成后:
第二次EDMA传输完成后:
此帖出自NXP MCU论坛
